em5.3 baseplate cracked/broken around tripod mount
Started Jul 4, 2020 | Discussions
pukha23 New Member • Posts: 14
10
i keep my arca tripod mounting plate (from the PD capture clip) always connected to my camera, as i use the tripod alot and the PD capture clip sometimes. last night as i was attaching to my tripod, i noticed that the connection felt a little wiggly. i removed the mounting plate and found that the (plastic) baseplate of my em5.3 was cracked quite extensively!
cracked baseplate of my em5.3
i don't know when this happened, but assume it progressed over time as there have been no impact or obviously stressful events that i am aware of. i did find a couple other dpreview threads where similar damage was discussed. yes i have used the pd capture clip to mount the camera on a shoulder strap while hiking/ backpacking, though not likely more than 20 or so miles in total thus far. the heaviest lens in this use case would be the mz 12-40 pro. it has spent substantially more time mounted on a tripod, with the 75-300 ii likely giving the most torque.
neither of these are large / heavy lenses, nor is the em5.3 a massive body. the reason i bought into this system was very much centered around the light weight and specifically the use case of carrying the camera on long hikes / backpacking, in easy reach with the pd capture clip. so... yes i am feeling very frustrated at the moment.
i have just submitted a warranty claim and plan to send this in on monday. i really hope that a) it is covered by warranty and b) they can repair quickly. i spent quite a sum on this camera in november and have a lot of plans for it in the coming weeks and months.
anyhow, if the baseplate / mount design is inadequate for this use case (hiking with the pd capture clip) i will... i don't know what. there isnt another m43 camera (that i'm aware of) with this guys capabilites, weather sealing, and light weight. i guess i could sell it and go for a em5.2 (with metal baseplate), but i don't want to give up the improved autofocus.
i am wondering if it is possible the cracking has resulted from overtorquing the mounting plate screw. it doesn't seem likely but it is plausible. i suppose it is even possible that this is the result of bad luck and a rare defective unit. (maybe)
James Stirling
James Stirling Senior Member • Posts: 9,282
Re: em5.3 baseplate cracked/broken around tripod mount
7
You are not the first to report problems with the E-M5III base plate. I hope you are covered by warranty.
Jim Stirling:
Wittgenstein : Whereof one cannot speak, thereof one must be silent.
Feel free to tinker with any images I post
 James Stirling's gear list:James Stirling's gear list
Sony RX100 IV Panasonic Lumix DMC-GX8 Nikon Z7 Olympus E-M5 III Nikon Z7 II +10 more
JakeJY Veteran Member • Posts: 5,440
11
This is not bad luck or a one off case, but rather seems to be a consistent issue when using the E-M5 III with the PD clip plate. You are the 5th case I'm aware of that broke with using this exact plate with the E-M5 III in a relatively short while (such that it can't all be coincidence). There was only one other reported case that involved a different plate.
I don't think anyone using the E-M5 III should use it with the PD capture clip given this. You would need to figure out other carrying options that do not involve the tripod mount.
Best of luck on your warranty claim, there seemed to be mixed responses where some were covered and some not.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Bobby J Veteran Member • Posts: 5,189
Based on comments I've seen on this forum I think there is simply a structural problem with the 5.3.  I don't think you over torqued it or anything like that.  The lenses you mention are very light and should cause NO problem.  It should be repaired under warranty.  If possible I'd inquire to see if when repaired they reinforce the mount or replace it with a stronger one.  If not I'd get rid of the camera and get an EM1 MK2.  Can be had for a reasonable price and in my experience is very durable.  It is heavier however and that may be critical to you. If I had a 5.3 and I really liked it, I don't think I'd ever mount it on a tripod.  IMO this is unacceptable.
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +9 more
Bassam Guy Veteran Member • Posts: 4,829
Sorry you were unaware of the E-M5 III's fragile tripod mount - especially when combined with Peak Design clips. I use my E-M5 III on tripods frequently and treat it gingerly when mounted on one. I recently bought a half case with a metal bottom that may more evenly distribute torque on the socket.
I believe at least one other person was told that this combo (E-M5 III + PD) was not covered by warranty.
IQ & AF-wise, I could not go back to my E-M5 II which I have loaned indefinitely to my nephew. PDAF ROCKS!!!
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Melatonin New Member • Posts: 18
I always wondered if the PD plate could cause something like this.
Peter Del Veteran Member • Posts: 7,988
I do not know what a PD clip looks like, do you have a photo of it?
Peter Del
 Peter Del's gear list:Peter Del's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 +5 more
Joe Lynch Veteran Member • Posts: 3,173
8
Sorry you have this problem.  Hopefully, Olympus will replace your camera body.  However, your replacement will be the same design and will be subject to the same type failure.
It is not the size of the PD clip or tripod adapter plate that is the problem, it is repetitive  cyclic loading on the camera's plastic surrounding the tripod mount flange that causes it to fail.  Using any tripod socket attachment with the jostling while hiking and using the camera on a tripod with a zoom or manual focus lens that is adjusted during use can eventually result in enough load cycles to cause the plastic body to fail.
I use my second 5.3 daily, but I never use the tripod mount.  And no, the size of the tripod adapter doesn't make any difference if it spans the camera body in the lens axis direction.  It is the accumulation of load cycles over time that results in the failures.
Just work with Olympus.  Hopefully, there are very few additional failures and hopefully Olympus will work with your like they worked with me.  I'm still a happy Olympus customer.
Joe
 Joe Lynch's gear list:Joe Lynch's gear list
Sony a1 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro +5 more
MOD Tom Caldwell Forum Pro • Posts: 46,190
I hope that the owners of the E-M5iii will get to know that the tripod mount seems compromised as a camera support and will either be very careful with it or not even use it for that purpose.  Otherwise it seems that every E-M5iii will sooner or later need a replacement body part. Unless of course some neat re-inforcing part can be designed and issued.
These are the times when good warranty support is most needed. But how does one know that they might need the broken mount replaced when it does not fail during warranty?  This might be bordering on a “mechandisable quality“ issue.
However replacing destroyed like-part with new like-part might not be the best solution.
Tom Caldwell
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 5,424
Design flaw, not your fault.  Common problem with 5.3.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,832
pukha23 wrote:
Sorry for your misfortune.
Thank you for the picture. You are now the 6th member of this group reporting this exact failure. If you search the forum, you will find how much previous victims were charged for the repair. Some got part of the cost waived, but most had to pay up in full.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
Chuck221 Forum Member • Posts: 71
Looking at this I believe the design intention was that the plastic baseplate would be sandwiched between the metal tripod mount and whatever the camera was attatched to, creating only a compression load. This has not happened. It is possible that the adapter cushioning rubber is so soft that tightening of the adapter screw is able to cause flexing of the baseplate, which over time could cause cracking. It is also possible that a front to back rocking load of the adapter could create a prying type action that would cause flexing of the baseplate and cracking over time. Cylical loading would hasten the cracking, as would leaching of plasticizer from the adapter cushioning material, which could cause stress cracking.
If you are able to get the baseplate replaced, the trick will be to avoid loads that can cause flexing of that area. Are there other Arca plates that might have a firmer cushioning material? Beyond that, it would probably be wise to take the adapter off when not in use in case it is stress cracking that is causing the failure.
OP pukha23 New Member • Posts: 14
these pics are from peak design's website. the first shows the arca mounting plate, and the capture clip (into which the plate can be clipped). the second shows someone carrying there camera the way hiking with a camera should be done
Joe
That seems like a lot of speculation. 5 out of 6 reported cases involved the PD clip plate. In the other case it's unknown what the tripod plate was (perhaps it would be helpful to find out). Not sure how you can say with such confidence that the plate size (or plate design) doesn't have anything to do with it.
Interesting theory on the plasticizer. From the thread where the PD clip plate broke a Nikon D5600 baseplate also, there was mention oil leaking (also by someone using X-T3 that reported weird oil, although no baseplate breakage). Someone also reported the rubber part falling off in the PD Clip and it leaving a lot of markings on the camera body (so it could do with adhesive also).
https://www.dpreview.com/forums/thread/4382677
gary0319
gary0319 Forum Pro • Posts: 10,498
Not trying to let Olympus off the hook, but that PD clip plate seems to be at least a big part of the problem.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
rashid7
rashid7 Veteran Member • Posts: 7,007
10
a well-documented issue here on the forum!  Shame on you Olympus
Keep it fun!
Thanks for the image.
The QR plate on my tripod also has rubber inserts, which protrude very slightly from the metal mount. They are very hard and can't be compressed, they just add grip without marking the base of my camera.
I wonder if this rubber is a little soft, and, as the screw is tightened, it pulls up the tripod bush to compress the rubber. Just a thought.
Peter Del
cba_melbourne
Whilst Polycarbonate used for molding indeed readily absorbs plasticires leaking from soft PVC etc, this is of absolutely no consequence here.
The cracking of the baseplate is NOT the problem, it's just the first and readily visible consequence of the problem.
The problem is the threaded tripod insert being ripped out of its anchor.
And this is also why the repair is so expensive. If it was only the baseplate, it would be very cheap to repair, 10 minutes labor and $30 parts. But this is a catastrophic failure. The camera has to be fully disassembled to replace the parts into which the tripod nut anchors, costing about $250-300, or about 1/4 to 1/3 of what this camera is worth to begin with.
larsbc Forum Pro • Posts: 18,281
7
It's linked to the problem, yes.  My own experience is that they don't cause any issues.  I've used them extensively for years with my GX7, G85 and now my G9 and GX9.  Despite my great experience with them, I *DEFINITELY* would not use them on an EM5.3 though.  Olympus dropped the ball on the design of their base plate.
