How to deal with light and shadow in shooting?
lisaliliiliu New Member • Posts: 3
How to deal with light and shadow in shooting, which camera is more suitable, too large camera is very difficult to carry.
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 18,082
Well, now
8
Dealing with light and shadow is the whole point of photography. Please be more specific about your issues.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony RX100 III Nikon D300 Nikon D750 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +12 more
KCook
KCook Forum Pro • Posts: 18,208
Re: Well, now
That
Plus, all cameras will deal with light and shadow.  This is more a matter of technique than camera selection.
Kelly Cook
 KCook's gear list:KCook's gear list
Canon EOS 50D Olympus PEN E-P5 Panasonic G85
PhotoTeach2 Forum Pro • Posts: 11,100
Re: How to deal with light and shadow in shooting?
T-he difference between bright-highlights and dark-shadows is referred to as Dynamic-Range (DR).
I am not an expert on that but I think it is safe to say that a larger-sensor (aka FF), and "newer" (aka more expensive), does have a DR advantage.
However, as long as highlights are not blown, Post-Processing (PP) techniques can still be required to lighten (dark) shadows in more difficult situations, and they can also make even smaller sensor cameras sufficient.
And there are other methods like HDR (High Dynamic Range) techniques and Fill-Flash (if close enough).
If you are not familiar w/ HDR, it is a method of shooting 2-3+ exposures that separately optimize both highlights and shadows that then are (software) combined into one-image.
softmarmotte
softmarmotte Senior Member • Posts: 1,221
HDR or bracketing. Nearly all cameras have the ability to take a bracket of 3-7 photos with ev ranging from .3 upwards. I sue it a lot when dealing with bright skies and shadows. then merge in lightroom
typical example
x 3 bracket at 1 ev with electronic shutter handheld
anyone is welcome to do anything they want with my images except sell them for profit
https://www.flickr.com/photos/softmarmotte/
 softmarmotte's gear list:softmarmotte's gear list
Sony RX100 Nikon D5500 Olympus E-M1 II Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +13 more
D Cox Forum Pro • Posts: 26,745
The main thing is to avoid overexposure, which gives blank white areas. If shooting in bright sunshine with deep shadows, you may need to use -1 on the Exposure Compensation control to avoid overexposure -- it depends on how clever the metering is on your camera.
You can always lighten the shadows by using a computer program. You can't do anything about the white patches.
Sigma fp
typical example
Nice photo. Where is it ?
Sigma fp
To answer the "too large" question, my opinion is that the Sony A6000 series cameras are a good compromise between sensor size (should be as big as possible) and camera body size (should be small and light).
There is a very big range of sizes and weights of lenses.
Sigma fp
lehill
lehill Veteran Member • Posts: 5,722
This is a big question like "How should I prepare food?"
Photographers can deal with light and shadow before, during, and after a photo is taken. But I think you're asking about cameras. You're right, cameras with larger sensors are more capable to deal with extremes in light and shadow (dynamic range).
A lot of us here will shoot in raw format, instead of JPEG, then edit the raw file with image editing software, then make our own JPEGs. Raw files are better than JPEG for light and shadow. Check and see if the camera you have right now will shoot in raw.
Lance H
 lehill's gear list:lehill's gear list
Sony RX100 III Sony a77 II Sony a7 II Sony a99 II Sigma 10-20mm F4-5.6 EX DC HSM +30 more
softmarmotte
Ooidonk castle near Deinze in Belgium
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 15,548
Please tell us...
Tell us a bit about yourself and what you want to photograph. Do you have any experience in photography? If so, have you run across specific problems that you'd like to solve? If you do have a few problematic photos, maybe you could upload them here so that we can analyze what might be wrong with them.
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +2 more
Thanks.
Sigma fp
graybalanced Veteran Member • Posts: 6,751
Light and shadow is about the choices you make about dynamic range and contrast control, no matter what camera. For example if you are photographing in the sun so there is too much contrast, you can make many choices like add flash, add reflector, or have subject step into the shade. Those will all work with any camera, large or small.
If you want to learn about this, read a book or watch a video about lighting techniques for photography or video.
You cannot solve these problems by buying the most expensive or largest camera. You must know what to do with the camera, in terms of light control in your scene.
Thandiwe Tsotetsi New Member • Posts: 2
I am no expert but I think you should consider using f/8 at 1/250 of a second and place your iso on a 100 (adjust your shutterspeed according to your light meter.)
If your normal exposure is f/8 then you will shoot at f/8, f/5.8 and f/11 with the same shutter speed. In order to achieve light and shadow images consider your 1.light direction; where it comes from in relationship to your subject. 2. The intensity the brightness of the light source in relationship to your subject. 3. Your contrast, how bold and strong or soft and subtle they are. 4. The hardness whether it is soft or hard edges and lastly the color (is there a cast to the light.)
skyglider Veteran Member • Posts: 5,501
Hi Iisalililiu, still here?
A good way to deal with hi-lights and shadows, is to get a camera with an electronic viewfinder. Then learn how to use zebras (set to 100%), use exposure compensation, and use the ETTR (Expose To The Right) technique to adjust for maximum brightness without over exposing (clipping) the highlights. (This cannot be done using a DSLR with an optical viewfinder.)  Alternatively, instead of adjusting exposure compensation, one can adjust aperture and/or shutter speed manually to also use the ETTR technique.
Then in your graphics editing program, you can raise the shadows while still retaining detail in the highlights for a nicely exposed picture.
If the dynamic range of the the scene is too great (when the ETTR technique above is done but the shadows get clipped and lose detail), then you can take bracketed shots and combine them in post processing using HDR (high dynamic range) software. That will preserve both shadows and highlights and combine them into one picture.
How do you know whether the shadows will be clipped? Display the histogram overlay in the viewfinder (along with the zebras) and see if the histogram mountain is clipped on the left side. Experience will make judgement better.
Finally, the bigger the sensor (with appropriate resolution), the more dynamic range can be captured. A good compromise at the low end is a camera with a 1 inch sensor. Better is a micro four thirds sensor. Better yet, some cameras with APSC or full frame size sensors have electronic viewfinders. But cameras with 1" sensors can have longer optical zoom range without having to change lenses so are a good compromise if one does not want to carry and change lenses.
Sky
