Photos of moonlit clouds with moon in frame
MacM545 Contributing Member • Posts: 585
I have tried photographing an extremely high contrast scene of clouds with the moon in frame. Although the results were dramatic, the photos were much more artistic than, in a sense, technically perfect. I could overexpose as well as underexpose but the extreme dynamic range was literally daunting to overcome. HDR was in practice not feasible as the clouds moved very quickly- I was trying to use a long focal length of about 230mm to get at least some lunar detail. You might be able to imagine why getting the scene in a single photo was daunting, but if at all possible, can it be done without resorting to composite?
 MacM545's gear list:MacM545's gear list
Sony RX100 II Canon EOS 500D Fujifilm X-T2 Canon EF-S 18-55mm f/3.5-5.6 Fujifilm 50-230mm II +1 more
Trollmannx Veteran Member • Posts: 6,684
Re: Photos of moonlit clouds with moon in frame
Try again in twilight before the sky becomes too dark.
If that is not possible take a separate image of the moon and blend in post. Cameras have limited dynamic range, no way around that in a single shot.
bmike
bmike Senior Member • Posts: 2,251
Moon over clouds
Moon rising over Glarus alps.
Moon through clouds
Digitaliz
Digitaliz Regular Member • Posts: 358
Shoot the moon däringa daylight and turn it into black and white.
/Stefan
 Digitaliz's gear list:Digitaliz's gear list
Tamron 15-30mm F2.8
nighthiker Regular Member • Posts: 321
Hi!
Try to reduce the contrast (e.g. twilight sky, thin clouds in front of the moon, etc.) of the scene and increase the dynamic range of your camera (e.g. use low ISO). Example from a single frame below.
