Spinning beachball Mac and lightroom
lou Capeloto Senior Member • Posts: 1,339
HI
Lately I have had the spinning beachball on my mac only when using lightroom. Happened very recently
I read where turning of the graphics processor may help, it doesnt work
Would great appreciate any help since it is very frustrating
I am running Catalina 10.15.5
Other detailsMac
(Retina 4K, 21.5-inch, 2019)
Processor 3 GHz 6-Core Intel Core i5
Memory 16 GB 2667 MHz DDR4
Graphics  Radeon Pro 560X 4 GB
LIghtroom Classic 9.3
Any help is greatly appreciated
 lou Capeloto's gear list:lou Capeloto's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-M1 Fujifilm X-T20 Leica M-E +11 more
Ken Seals
Ken Seals Senior Member • Posts: 1,298
Re: Spinning beachball Mac and lightroom
Do you have face recognition or address lookup working? If so pause them both and see if that helps.
Check in activity monitor to see what is keeping the machine busy.
Ken - LR ACE
FAA Remote Pilot Certificate, ATP ASMEL
Mizzou PJ '66
www.kenseals.com
 Ken Seals's gear list:Ken Seals's gear list
Nikon D700 Nikon D500 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED +7 more
pixelgenius
pixelgenius Senior Member • Posts: 4,208
lou Capeloto wrote:
HI
Other detailsMac
Try resetting preference:
https://helpx.adobe.com/lightroom-classic/help/setting-preferences-lightroom.html
OP lou Capeloto Senior Member • Posts: 1,339
Thank you
I have neither one of those programs running
Have 16gb memory 13gb used
Thank you
Tried it and didnt seem to help
Couple times it worked then after started again
lightnchade Regular Member • Posts: 258
The 10.15.5 update included fixes for some recently discovered security vulnerabilities and it seems (to me) there are some glitches under the hood. 10.15.4 seemed to finally be getting stability under control but it regressed with 10.15.5.
10.15.6 is already in beta.
JPAlbert Contributing Member • Posts: 897
Important questions:
- What kind of DRIVE is inside the iMac?
- How much free space remains on it?
If it's a platter-based hard drive, it's going to be slow.
Particularly if you are "pushing the memory". The OS is going to start swapping RAM to disk, page ins and page outs, and if it's a platter-based drive this is going to be as slow as molasses.
There's a relatively cheap and easy fix:
Plug in an external USB3 SSD and make that your boot/applications drive.
Things will then go much faster.
Hi
The drive inside the mac is
APPLE SSD SM0512L Media
Free space 160gb
https://500px.com/corot2
pixelgenius
lou Capeloto wrote:
Thank you
You might try actually shutting down the Mac. Restart and see if there is any improvement.
LarryRC Contributing Member • Posts: 714
lou Capeloto wrote:
HI
Other detailsMac
Upper left do you see any background processes running like building 1:1 previews?
 LarryRC's gear list:LarryRC's gear list
Sony a7R IV Sony FE 100-400mm F4.5-5.6 Sony FE 12-24mm F4 Tamron 28-75mm F2.8 III Sony FE 600mm F4
Andy Hewitt Veteran Member • Posts: 4,257
lou Capeloto wrote:
HI
Other detailsMac
My only really bad experience of Lightroom causing this is with a dying HDD.
I keep my master image files on an external USB3 HDD, and the catalogue on the internal SSD.
When I was getting various beach-balling, it turned out to be a HDD starting to get reallocated sector counts. I installed DriveDX, and found the drive was starting to show signs of failure (indeed, I discovered more than one in my entire collection).
Once I'd replaced the drives showing errors in the SMART data, I've not had any issues since. I now keep DriveDX installed and running, and have since replaced other drives showing signs of failure before it got too disastrous.
Such errors aren't always a sign of a failing drive if they're constant, and a low count, but an increasing error count often is. My tendency is to simply replace the drive if it has any errors.
It can also cause general OS sluggishness and beach-balling too. I gather that such errors cause slowdowns as the OS, or apps, will keep reading/writing until it can find a good sector, and recover data from the bad sector.
It might not be that, but something worth checking.
Andy H
 Andy Hewitt's gear list:Andy Hewitt's gear list
Nikon D5100 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +6 more
