Samsung NX and manual lenses - don't match
Started Jun 30, 2020 | Discussions
Pablo 1979 New Member • Posts: 4
Hi there!
It's my first post here, but I've been visiting dpreview for years. I've decided to start a new thread, as I have a problem with both my NX300M and NX30. They don't want to work with manual lenses. I've managed to force them via service menu to take shots, but they still lack magnification option or focus peaking.
I've found the hack to get to service menu here, but I didn't find anything about my other problems.
Thanks in advance.
Samsung NX30
CBVickery
CBVickery Forum Member • Posts: 89
Re: Samsung NX and manual lenses - don't match
I have a NX300 and a NX3000.  I use both with MF lenses.
I prefer the NX300 as it has good magnification and strong focus peaking.
When you attach a MF lens you must switch the AF setting to MF to get the focus peaking.
My OIS lenses have a AF/MF switch that switches to MF mode automatically.
With dumb manual lens you must manually switch to MF.
I have had much success attaching older Minolta primes to my NX300.
 CBVickery's gear list:CBVickery's gear list
Nikon Coolpix P900 Sony RX100 V Olympus OM-D E-M5 Olympus E-M5 II Olympus E-M1 II +1 more
shutterbugnx
shutterbugnx Regular Member • Posts: 168
Skip to 2:00 for information on manual focus assist. (use the OK button while taking a photo)
Samsung cameras may fail to detect the presence of a manual lens due to an aspect of the NX mount. https://www.dpreview.com/forums/post/55784403
If you don't like using the hidden menu, an adapter from a different manufacturer might work.
Hope this helps.
 shutterbugnx's gear list:shutterbugnx's gear list
Panasonic Lumix DMC-ZS60 Olympus PEN E-PM1 Sony Alpha NEX-7 Samsung NX2000 Fujifilm X-M1 +46 more
kypfer Contributing Member • Posts: 985
This does sound like an adaptor issue, some adaptors are very poorly manufactured.
Do you have a different adaptor to try?
I have over a dozen different-fitting adaptors, from various manufacturers. Most work flawlessly, but one is very difficult to 'lock' onto the camera body and a couple of the others don't allow infinity focus, so manufacturing tolerances are obviously 'loose'.
YMMV - good luck!
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP Pablo 1979 New Member • Posts: 4
Unfortunately non of the above hepled.
Neither NX300M nor NX30 have magnification with manual lenses:
- 2 different adapters
- MF switched of before attaching manual lens
OK button isn't responding, no magnification, no focus peaking.
shutterbugnx
Ensure you have peaking and MF Assist enabled. I haven't tried with "no lens release enable" set, perhaps that needs to be reverted.
armin304 Contributing Member • Posts: 740
I think you have adapters, that will work well with the older NX10/20/100. With later models, Samsung changed to tighter tolerances for the little switch in the mount, which tells the camera that a lens is mounted. Of my old adapters, bought for the NX10, some work with the NX30, some don't. If you look through the threads here in the Samsung Talk forum, you will find some posts, where the adapters were modified, to actuate the switch of the newer cameras. I never tried it myself,  I just took part in the adapter lottery with another cheap adapter from China and got myself a Sony A7 II for my manual lenses, when it became available. Not that there was no lottery with adapters too, since the A7 II got a more sturdy mount than the previous NEX and A7 models, one of the adapters I got for the Sony did not fit at all. Unfortunately the NX series is dead, so you will have to take what's still available.
 armin304's gear list:armin304's gear list
Nikon Coolpix P900 Sony a7 II Panasonic Lumix DC-GX9 Nikon Z6
wpstl Senior Member • Posts: 1,251
I had this problem with Fotodiox brand adapters. Switched to Fotasy brand and all of those have worked perfectly.
"Sometimes I like to throw a grenade and run away."
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
This might be the problem. I've noticed this switch and I'm not sure if any of my adapters can push that pin down.
P.S.
No NX to PK or M42 adapters by Samsung?
Pablo 1979 wrote:
P.S.
Not quite sure what you're asking here, but for the price Samsung were asking for their own-brand ED-MA9NXK PK-NX adaptor I'd be surprised if they sold any at all! They seem to be almost as scarce as the GPS adaptor!
Fooling the little lens-sensor switch with a bit of plastic is easy enough and will soon demonstrate if it's your adaptors at fault.
I've found the solution. I will cut of the NX mount from the converter and ad an original one from one of my macro NX rings, as my macro rings work perfectly with manual lenses.
MichaelP828 New Member • Posts: 1
Hi I have a Samsung NX3000 and so far I haven't found a video that explains how to get over the no lens issue , can you please help ?
markyboy81 Veteran Member • Posts: 4,778
I don't think there is a solution. With some cameras such as the nx1000 you press a sequence of buttons to enter the developer menu and one option is to shoot without lens. However, I don't believe you can do this with the NX3000, at least I never figured out a way how to.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
shutterbugnx
https://www.ifixit.com/Guide/Disassembling+Samsung+NX3000/55943#s121695
You simply need to have this pin pressed down.
