Some advice on Nikon 500 f4G vr
tommiejeep
tommiejeep Veteran Member • Posts: 7,320
My lens has a few cracks in the rubber grip, item 3 in the lens manual diagram.  Thinking about filling them with some adhesive .  The lens is about 10.5 years old.  I would just like to stop them getting bigger.   I can no longer by parts from Nikon India and have found nothing on-line.  Getting it to my Nikon Service Centre is also problematic.
Advice, ideas?  Many thanks
Anticipate the Light and wing it when you get it wrong but always have fun
Tom
http://images.nikonians.org/galleries/showgallery.php/cat/500/ppuser/165169
tommiejeep
OP tommiejeep Veteran Member • Posts: 7,320
Re: Some advice on Nikon 500 f4G vr
I guess this a rare occurrence or a non-issue.  Will experiment on some old , similar rubber.
Cheers
Tom
FreeLB
FreeLB Contributing Member • Posts: 855
I think you may be able to buy replacement rubber for the focus ring.  I've had that lens before, and it's amazing.  I hope you post some images from it.
-Freeman
 FreeLB's gear list:FreeLB's gear list
Nikon D500 Nikon D850 Voigtlander 58mm F1.4 Nokton SL II Nikkor AF-S 300mm f/4E PF ED VR Nikon 200-500mm F5.6E ED VR +1 more
tommiejeep
Many thanks.  It is not the focus ring but thr "Rubber Grip" ar the very front.  Focus rings are readily avaliable.
Yes, great lens but getting a bit heavy for me, 74 years .  I bought it new in 2009.
I have tons of images and during lockdown I have been shooting birds in, and around, my property with D500 and Z6.   Mostly from a balcony.  Nothing very exciting .
Tom
lrv890 Regular Member • Posts: 164
Have you tried contacting Fixation in London , I've had a few spares from them and found them very helpful  . If they cant supply it they might be able to give you some part numbers
Hope this helps
Daren
 lrv890's gear list:lrv890's gear list
Nikon D600 Nikon D810 Nikon D750 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 500mm f/4G ED VR +8 more
notmyrealname Regular Member • Posts: 181
I would avoid going the adhesive route. If you are unable to find replacement rings, I would purchase a Lenscoat or use the reusable self-cling wraps that hunters use on their rifles (I've seen photographers use these wraps on their tripods as well).
https://www.amazon.com/McNett-Tactical-Protective-Camouflage-MultiCam/dp/B005ZTZU1A/ref=pd_lpo_200_t_1/147-1910921-0230307
 notmyrealname's gear list:notmyrealname's gear list
Nikon D750 Nikon D5 Nikon AF-S Nikkor 600mm f/4G ED VR Voigtlander 40mm F2 Ultron SL II Nikon AF-S Nikkor 58mm f/1.4G +3 more
tommiejeep
Looks interesting.  Thanks.
Tom
