Am I wrong on Panny 14-45?
Started Jun 29, 2020 | Questions
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Re: Am I wrong on Panny 14-45?
The pedestrian is sharp, the text on the road is sharp, the building edges=s are sharp, the ridgeline is sharp.
Every bit of dark green foliage (in many parts of the image) is blurred.
This is not an optical problem. (or the all parts of the image would be affected)
This is not an image stabilisation problem. (or the all parts of the image would be affected)
This is an image processing problem.
I think the there is very little detail in the shadows because of the underexposure, and the JPEG conversion made it worse by reducing the dynamic range. On top of that there some noise reduction may be contibuting to lack of detail.
The underexposed green foliage makes up a big portion of the image, and so this is now very vissible.
My HDR merges always work significantly better when I start from raw images.
Cheers
Eric
(Any image that I post in a DPR forum may be editted and posted in a DPR forum)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
alcelc
OP alcelc Forum Pro • Posts: 19,003
No problem, it happened. Thank for looking at it 😊.
Albert
** Please feel free to download the original image I posted here and edit it as you like **
alcelc
The cropping was made from full 16MP resolution image.
Albert
alcelc
Thank you Eric, it sounds you have the answer.
Those were the mysterious to me.
But it is a SOOC jpg, as said had NR=0. As per my testing (under reasonable lighting condition) basically is close to NR=-5 but less noise. I keep the setting on all of my Pannys without problem as bad as this time.
Something likely had happened. If so, I might have also misunderstood the 12~32 under poor lighting condition.
Thank you for your head up.
Cheers
Eric
Albert
millardmt Regular Member • Posts: 494
The Panny 14-45 is a GREAT lens.
Marc
alcelc
Never doubt it and despite it was on a retiring status (because I love 12 over 14 only), I regard it as one of my best standard zoom lens even better than 12~32.
Over last 11 years never find similar issue over G1, GF3, GX1 GX7 and so I classified it as an all round player.
But it was not used as often after GX85 and G85. I suppose it could be a compatibility issue on G85 that some can't explained performance was observed. I had similar issue on 12~32 & GX85 but never find the samd again on GX7 or G85... 🤔
Could also be suggested by Eric that severe underexposed and lack of DR in shadow would be a possible reason.
Albert
Eric Nepean
I have found it very informative to read the description of JPEG compression in Wikipedia. Not the high level description - the example of the encoding process.
  1. Convert from RGB to YCbCr (Y is luma, Cb and Cr are chroma)
  2. Chroma subsampling - average the color values over 2x2 or 3x3 blocks of pixels (removes color detail)
  3. Make the Discrete Cosine Transform of 16x16 blocks of pixels for each channel (result is a matrix)
  4. Divide each element of the DCT result by each element of the Quantization matrix (the Quantization matrix suppresses "unnecessary" fine detail)
  5. Round to the nearest integer (rounding removes detail, and reduces dynamic range, has the biggest effect in the shadows.)
  6. Use run length encoding to losslessly compress what is left.
You have a large dark areas with uniform lightness (darkness) and with detail mostly in the color.
Step 2 removes half the color detail, Step 4 de-emphasizes fine detail, and then rounding in step 5 removes more detail and removes the bottom part of the dynamic range.
It is often said that the information discarded by JPEG compression is stuff the human eye doesn't see well; humans don't have good color perception in low light, we have black and white receptors for low light conditions.
Cheers
Eric
alcelc
Thank you.
And therefore the same could be happened to any lens on any body if the condition be met?
It might not be limited to 14-45 on G85 or my earliest experience on 12-32 on GX85.
I would try to use RAW if similar lighting condition would be appeared to verify this. Thank you so much for your help.
Albert
brentbrent Veteran Member • Posts: 5,766
Trolleyman wrote:
Everyone looks back with rose tinted glasses, summers were always hot and winters snowy.
I had the original 14-45, it wasn't bad for a kit lens, but cant expect miracles compared to someghing like the 12-35/2.8
My first MFT kit was off eBay, a used GF1, 20mm, and 14-45. The 14-45 seems to have a cult following of sorts, but I was never that taken with it. Later when I got the 14-42 II as part of a kit, I found that lens preferable and sold the 14-45.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
