Am I wrong on Panny 14-45?
Started Jun 29, 2020 | Questions
alcelc
alcelc Forum Pro • Posts: 19,003
14-45 is my first M43 lens which was bought with G1 back in early 2009. It had delivered very consistent result so far on various generation of bodies from G1, GF3, GX1, GX7 and GX85. Fast and accurate AF, IQ never raise alarm bell, unlike the low light wired performance of 12-32, it is an all round player... After upgraded to 12-35 f/2.8, it is generally stayed inside the auto dry cabinet.
IMHO it should be one of my best standard zoom lenses, equally good as 12-35 f/2.8, 14-140 f/3.5 mk-I, marginally better than 12-32 and on top of 14-42PZ.
Recently, it was recalled, mounted on G85 always on my desk (I have a habit of having a camera always ready for me to test it, or to take a picture if anything appearing interest). A couple of days ago, saw a beautiful rainbow after raining, took a few AEB shots for HDR.
The following is one of those AEB snapshots, SOOC jpg:
After I merged the shots into HDR, I found quite poor resolution of the shadow sections. Hence, I picked up one of those original shots, lifted the shadow, and my...... it was looking like an oil painting...
A dirty shadow lifting in FastStone
A crop of the above:
I am shocked... This is not the 14-45 I ever know.
The above was taken at jpg setting NR=0, so, basically it should have a good deal of fine detail been retained. On the shadow lifting, no NR been applied.
I had tested this lens on exact same body G85 on a sunny day and the result was very different:
I expect the IQ should be as below:
Am I wrong that 14-45 indeed also has its own problem when lighting condition going bad (I shot it at night time without issue so far)?
Or its age has started taking its toll?
Albert
** Please feel free to download the original image I posted here and edit it as you like **
Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85 Panasonic Lumix DMC-GF3 Panasonic G85 +11 more
Panasonic G85 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85
Albert Valentino Veteran Member • Posts: 9,767
Re: Am I wrong on Panny 14-45?
The only proper way to test it is with a raw file. Settings, like application of lens profiles, noise reduction... get applied differently in jpg engines and may mask the full potential of the tested lens.
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 Panasonic 8-18mm F2.8-4 +10 more
Lasse Eisele
Lasse Eisele Senior Member • Posts: 2,042
It's not the lens
6
Your lens is fine. The mushy foliage is most likely a result of heavy-handed NR. I know you had set NR to 0 but some NR seems to have been applied anyway.
By the way, I can see some mushy foliage in the other picture as well (outside of your crop).
You should really try shooting raw. It will solve these problems.
The Pana 14-45 is an extraordinary kit lens, just as good as my Oly 12-40 except for the extreme edges. I would use mine a lot more if it could go to 12 mm on the wide end.
Regards
Lasse
alcelc
OP alcelc Forum Pro • Posts: 19,003
Thank you.
I know RAW could get the best.
However as I had tested, particularly on G85, jpg NR setting at 0 could preserve fine detail very close to NR=-5 but having noise in control. And in another shot under good lighting condition the result is not best, but is far better.
For heavy shadow lifting in PP a lot of noise will be expected for that sereve underexposed image. Never expected that poor outcome...
Albert
alcelc
Re: It's not the lens
Regards
Lasse
Thank you.
However as in another shot under good lighting condition the result is not best, but is far better.
Albert
tkbslc Forum Pro • Posts: 17,526
motion blur / stacking
Regards
Lasse
Thank you.
Since this was a 3-shot merge, my guess is that the leaves where being blown around and the merged results was a smeared motion blur mess. Or your stack was not perfectly aligned.
alcelc
Re: motion blur / stacking
No dear friend, that poor image is a single shot, being the -1 stop shot out if a 5 Auto Exposure Bracketing sequence.
However thank you for participation.
Albert
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
The trick is to compare those same tree details on the two shots taken at the extremes of the bracket.
The lens is not causing the problem but the exposure is.
Dick Barbour
Dick Barbour Senior Member • Posts: 1,880
Lenses age?
Dick
 Dick Barbour's gear list:Dick Barbour's gear list
Panasonic Lumix DMC-ZS50 Sony RX10 IV Sony a6500 Panasonic Lumix DC-G9 Tamron 18-300mm F3.5-6.3 Di III-A VC VXD +4 more
Gnine Senior Member • Posts: 4,108
It could also be the OIS causing it, as the shutter speeds get really low, making it work harder, and perhaps uncovering any underlying issues with the OIS.
Dick Barbour wrote:
Dick
I've had OIS go bad on me. Age=usage=wear on mechanical components
Dick Barbour
Gnine wrote:
Dick Barbour wrote:
Dick
Yes, but he had just got it out of a cabinet where it had a rest:
"After upgraded to 12-35 f/2.8, it is generally stayed inside the auto dry cabinet."
So I guess what I'm saying is the answer to his query as to whether age had caused his observed problem, is "probably not".
Dick
kenw
kenw Veteran Member • Posts: 7,095
Dick Barbour wrote:
Gnine wrote:
Dick Barbour wrote:
Dick
Dick
Also the shutter speed is 1/640 which doesn't completely eliminate bad OIS group but makes it less likely.
Also the ridge line in the middle of the frame looks just fine as does the writing on the road surface.
I'm really suspicious of shadow NR being at work here and the root cause.  It's an underexposed shot with blurry shadows from an in camera JPG engine.  Just the kind of thing that takes out foliage detail typically.
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Panasonic Lumix DMC-GM1 Nikon Z7 Panasonic Leica DG Summilux 15mm F1.7 ASPH Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +46 more
Guy Parsons
At 1/640 sec?
alcelc
Lenses age?
Dick
It was bought in early 2009, so is 11 years old. Was my main standard zoom lens which was used extensively through the years over various bodies until I upgraded to 12-35 f/2.8 in 2017.
Should had produced 200~250K images so far... and been gone through all sort of weather condition from light to heavy rain, very cold, snowing to very hot and dusty...
But my mysterious is that it performed very normal during my last home testing a month before?
Albert
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
Time to permanently retire the 14-45.   Time marches on.
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 17mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 45mm F1.8 +4 more
alcelc
Albert
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
That is the product of combining shots in which the trees have moved between frames. Nothing to do with the lens. Common issue with HDR bracketing.
The issue relates to merging multiple frames containing moving subjects. It has nothing to do with lighting or the lens.
P.S.: Disregard my comments above. On rereading, I see that I misunderstood your post, but I cannot now delete my post. Never mind.
"I learned long ago, never to wrestle with a pig. You get dirty, and besides, the pig likes it." - George Bernard Shaw
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-GX9 +54 more
pannumon Veteran Member • Posts: 4,130
The original image is only 2 megabytes. It might be that the compression level is too high. I can see the algorithm maximizing the sharpness of the waves and sacrificing the sharpness on shadows (the trees).
Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GM1 Panasonic G85 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GF1 +21 more
Trolleyman Senior Member • Posts: 1,048
Everyone looks back with rose tinted glasses, summers were always hot and winters snowy.
I had the original 14-45, it wasn't bad for a kit lens, but cant expect miracles compared to someghing like the 12-35/2.8
 Trolleyman's gear list:Trolleyman's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Olympus 12-45mm F4 Pro Olympus 12-100mm F4.0 Panasonic 8-18mm F2.8-4 +3 more
