New Italian review of K1 II is...
Started Jun 27, 2020 | Discussions
brett nz
brett nz Contributing Member • Posts: 597
kinda impressive imo and seems to show a feature using the gps and sensor that I am not aware of shooting at 24mp and having sensor adjustment?
Turn on the English translation in settings: https://youtu.be/dYT629zZktg
 brett nz's gear list:brett nz's gear list
Pentax K-1 Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 77mm 1.8 Limited Pentax FA 70-200 F2.8 Pentax FA 150-450mm F4.5-5.6 +2 more
Pentax K-1 II
JensR Forum Pro • Posts: 17,971
Re: New Italian review of K1 II is...
I am not 100% sure what you are referring to,
But I assume you mean the astrotracer function that uses GPS and the gyros to calculate the sensor movement to follow the stars .
https://youtu.be/dYT629zZktg?t=455
The second thing is not 24MP, but shifting the sensor by 24 "units" to slightly correct perspective (shift lens effect)
https://youtu.be/dYT629zZktg?t=485
ozdean
ozdean Forum Pro • Posts: 28,665
I didn't know you could rotate it.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
brett nz
OP brett nz Contributing Member • Posts: 597
Hi - sorry, I didnt explain myself very well: the second thing - is it changing angle of sensor - like a tilt shift lens?
andrew britten Senior Member • Posts: 1,495
Hi Brett
It's a shift along the 'x' or 'y' axis, not a rotation around those axes.
It does 'rotate' around the longitudinal 'z' axis though, for horizon and general movement correction.
So, no, it doesn't tilt the sensor in the vertical plane. Pulling that off would be a major coup for the brand.
Who knows, maybe that's to come?
Cheers
AB
 andrew britten's gear list:andrew britten's gear list
Pentax K10D Pentax K-7 Pentax K-x Pentax K-5 Pentax K-01 +2 more
Conjure
Conjure Contributing Member • Posts: 891
Hi Brett
Cheers
AB
Ricoh has a tilting sensor patent:
https://pentaxrumors.com/2017/10/24/the-latest-ricoh-patents-tilting-sensor/
Cheers
Anton
Hi Dean,
yes, it has been a feature since the very first Pentax SR in the K100D:
https://www.dpreview.com/reviews/pentaxk100d/12
The K10D review also has a larger image for the set-up:
https://www.dpreview.com/reviews/pentaxk10d
Apart from SR and AstroTracer, on the K-1 and probably many other recent cameras, there is "auto level correction" that rotates the sensor to get the horizon level (within limits of course).
Generally that rotation is not as crucial for shake reduction in still photos, but it does help and is something that lens-based systems cannot do.
Cheers
Jens
DougOB
DougOB Veteran Member • Posts: 3,176
Hi Brett
Cheers
AB
Ah ha!  So we can expect it on the K-new then!  Excellent news
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax K-70 Pentax KP +36 more
brett nz
Thank you for explaining it to me - yes, wouldnt it be a coup!
