Change Nikon Set Lens to fixed one
Started 7 months ago | Discussions
amarokWPcom
amarokWPcom New Member • Posts: 11
Who got the Z6/Z7 with the Z 24-70 mm f/4 S in a set?
Did you change fast to a fixed one and if yes to which one?
What was your experience with the difference of the image qualities regarding the set lens?
Nikon Z6
BenQ SW2700PT
HP Elitebook 830 G5
 amarokWPcom's gear list:amarokWPcom's gear list
Fujifilm FinePix F31fd Nikon Z6 Nikon Z 24-70mm F4
Stu M New Member • Posts: 23
Re: Change Nikon Set Lens to fixed one
The 24-70 S f/4 kit lens is the best kit lens I've ever used and would go so far to say it's one of the best Nikon lenses I've ever used, and I've worked through quite a few of them.
It's small, lightweight, very sharp across the frame, constant f/4 and makes use of the excellent IBIS system. It'd take a really good midrange 24-70/24-105 type zoom to make me want to swap it.
 Stu M's gear list:Stu M's gear list
Nikon D300S Nikon D750 Nikon Z6 Nikon AF-S Teleconverter TC-14E II Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +6 more
Henrik Ger New Member • Posts: 4
I came from a D5300 with 35 1.8, 50 1.8, 85 1.8 and the 18-105.
Now I got the Z8 with 24-70 F4 and the 50 1.8.
This Zoom lens is so supersharp that I only use the 50mm for faster aperture.
 Henrik Ger's gear list:Henrik Ger's gear list
Nikon Z6 Nikon 85mm F1.8G Nikon Z 24-70mm F4 Nikon Z 50mm F1.8
MikeDale Regular Member • Posts: 277
7
How are you finding the Z8? They're in very short supply I hear.
 MikeDale's gear list:MikeDale's gear list
Nikon Z7 Nikon Z6 Carl Zeiss Distagon T* 2,8/15 Nikkor AF-S 300mm f/4E PF ED VR Nikon 500mm F5.6E PF +6 more
Blanche Bovine Contributing Member • Posts: 505
I was going to get the Z8 but found the features on the Z9 a little bit better.  The built in USB 4.0 with data transfer rates of 2TB a second are outstanding.  The 4 card slot and the 6TB built in memory with the 200 Frames per second shooting is just what I need.
 Blanche Bovine's gear list:Blanche Bovine's gear list
Nikon D500 Nikon Z7 Nikon Z50 Nikon AF-S DX Micro Nikkor 40mm F2.8 Sigma 150-600mm F5-6.3 | C +3 more
I meant Z6
Im sure I skip the Z8 because Z6 is fine for me.
Maybe i will buy a Z10
Brian Homer
Brian Homer Contributing Member • Posts: 547
Like others have said the kit lens is superb. So good I sold my 24-70 2.8 (non-VR). I have got the 50mm 1.8 Z lens which is also great. Just depends on light and circumstances which one I use.
Brian Homer
 Brian Homer's gear list:Brian Homer's gear list
Fujifilm X30 Fujifilm X100F Nikon Z6 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 28mm f/1.8G +8 more
