The Fuji S5 Pro, my most filmic camera
Started Jun 22, 2020 | Discussions
fPrime
fPrime Veteran Member • Posts: 3,727
13
Often I see the question raised "How can I get a filmic look?" My answer invariably is to buy a Fuji S5 Pro.
The reason is simple. Color negative film is known for being somewhat low resolution, a bit soft, having a wider dynamic range than traditional digital, and with the ability to roll off highlights gently instead of clipping to white.
That's pretty close to what you get from the S5 Pro by default. It's low resolution (6MP), a bit soft after being interpolated to 12MP, possesses an exceptionally wide dynamic range thanks to it's SuperCCD sensor, and (for the same reason) has a gentle highlight roll-off reminiscent of film.
Here's a quick example of this effect generated by Fuji's Hyper Utility HS-V3.
Fuji S5 Pro with the Nikkor 17-55mm/2,8G and on camera fill flash
The sunlight on my daughter's back would have clipped harshly with traditional digital cameras but the extra highlight pixels of the SuperCCD her shirt retains traces of detail in the brightest parts along with that gentle highlight roll-off as described above. I find this reminds me of film. Do you agree? Let me know!
fPrime
Half of my heart is a shotgun wedding to a bride with a paper ring,
And half of my heart is the part of a man who's never truly loved anything.
 fPrime's gear list:fPrime's gear list
Canon EOS 5D Fujifilm FinePix S5 Pro Leica M8 Nikon D60 Nikon D1X +3 more
Neil-O Contributing Member • Posts: 593
Re: The Fuji S5 Pro, my most filmic camera
6
I'm a relative newcomer to this camera and I was drawn to it by the remarks made on this and other forums regarding its film like qualities.  Admittedly, harsh sunlight is not an everyday problem here in Scotland... but I agree the way in which it renders highlights is unlike any other digital camera I have used.  I think the Nikon D810, from what I'm told, has similar characteristics but I can't justify the cost of one of those.
Much is made of the lack of resolution and sharpness of the sensor, a product of a strong AA filter apparently, but I haven't found it wanting at all - and I have a Sigma DPM to compare it with.  I don't have a huge portfolio yet but here's a couple of my attempts:
Of course the other issue that will put many modern day photographers off this camera is how sloooooow it is, but to repeat, I have a DPM...
What is a frustration is the necessity of using Hyper Utility 3 which is absolutely essential to get the best out of the raw files - it seems at first that ACR does a reasonable job but it isn't as good as the Fuji software, just more convenient.  Having said that, I've shot jpegs side by side with raw and most of the time there's little to be gained.  Fuji do have some magic dust when it comes to in camera processing.
Finally, why oh why didn't fuji make the s5pro battery the same as in the D200?  I have a D200 and others that used the ubiquitous EN-el3 or whatever it is called, so I have a host of these batteries which are useless in the s5pro.  I find like the D200 the s5 is quite power hungry so spare batteries are a must.
I am actually looking forward to using this camera in the Winter where I hope it might work well on the subtleties of white on white landscapes.  Though a bit of harsh sunlight would be very welcome at the moment..
fPrime
OP fPrime Veteran Member • Posts: 3,727
The dynamic range of the D810 may be similar, but the approach is completely different. With the S5 Pro one exposes normally and the camera pulls back the highlights either SOOC or in RAW. With the D810 one exposes for the highlights and then brings up the shadows but this must be done in RAW.
Nice shots. Thanks for adding them to the thread!
Haha, yes, I've heard war stories about the slowness of Foveon sensors.
Sometimes I prefer the Lightroom rendition, sometimes I prefer what Hyper Utility HS-V3 gives me. One thing for sure, I find that Hyper Utility's auto-WB is much more accurate than Adobe's auto-WB for the Fuji S5 Pro.
Indeed, it is so good that DPR should use a Fuji S5 Pro as their comparator camera for SOOC comparisons against all other cameras. Dare I suggest that a few more modern cameras would be embarrassed by the S5 Pro's color and auto-WB ?
I know. The S5 Pro uses the D200's body. It was foolish for Fuji to chip the NP-150 batteries, as the Nikon batteries are ubiquitous.
Please update the thread when you do. My problem here in California is the reverse... we have harsh sunlight 90% of the year here. This makes the S5 pro my favorite CCD to carry mid-day as it is so forgiving under those circumstances. Look at this shot, I am 1/4000 at f/2.8.
fPrime
fPrime
Ha ha, where I live I could wait a thousand years to take a picture like that...
Of course  everyone knows how popular these cameras were with wedding photographers, and I reckon part of this was how the camera deals with white fabrics (the strong AA filter helps I guess) in harsh light.  Since digital took over I have always struggled to get really convincing pictures of snowscapes, particularly those rare days when the sun shines in a cloudless sky.
Anyway it won't be long - you know we say in Scotland there are only two seasons, Winter and June...
Spazmaster Regular Member • Posts: 227
So why did Fuji stop making these sensors and is there any other recommended cameras to try using this tech?
 Spazmaster's gear list:Spazmaster's gear list
Fujifilm X-T20 Fujifilm XF 35mm F1.4 R XF 90mm Fujifilm X100S Fujifilm XF 18mm F2 R +3 more
fPrime
Fuji has never said why they stopped, but I have a good idea of what may have been involved.
Shortly after the S5 Pro was released the full frame Nikon D3 came out cutting deeply into Fuji’s wedding niche. The D3 offered a true 12MP full frame which, for resolution at least, bested the S5 Pro’s interpolated, crop 12MP. Thanks to its CMOS design the D3’s dynamic range was also much improved yielding less of a DR advantage to the S5 Pro.
If Fuji wanted to have stayed competitive back then they would have had to have developed both a full frame SuperCCD sensor and secured a third generation Nikon body to put it in. Nikon may not have been willing to release its flagship D3 body to Fuji nor may Fuji have wanted to use a DSLR that big. The combined challenge seems to have been too great. Moving forward Fuji decided to build their own bodies and stick with APS-C.
fPrime
Giovanni_1968
Giovanni_1968 Veteran Member • Posts: 3,916
Nikon didn't want to have an at home competitor so they simply quit the agreement on camera bodies and that was the end of the S-CCD era, unfortunately the X-Trans, for those who like me thought it might be the follow-up, has been a big disappointment in comparison.
Giovanni - 70% GAS affected
http://www.flickr.com/photos/giovanniaprea/
Nikon D850 - Nikon D800 - Nikon D2Xs - Fuji X-Pro1 - Fuji S5Pro - Nikon F - Nikon F3
J.A. Michell Gyrodec - Audio Research SP-9 - Aeron AP-890 - JBL4311B - JBL L220
JN70CN - 14.14.30E 40.32.40N
 Giovanni_1968's gear list:Giovanni_1968's gear list
Fujifilm FinePix S5 Pro Nikon D2Xs Nikon D800 Nikon Z6 II Nikon AF-S Micro-Nikkor 60mm F2.8G ED +20 more
Would it have been so difficult to accommodate the S-CCD sensor in something like the X100 chassis?  The film-like output combined with the retro look would surely have been a winner.
Giovanni_1968
As far as I know the development of the S-CCD has been long time interrupted and, generally talking, CCD left room to CMOS technology long time ago
Serge 07
Serge 07 Regular Member • Posts: 447
Hi, fPrime:
The S5 does a fantastic job in highlight  recovery and their smooth roll off but the depth and richness of the colors is also there in spades. It is the combination of these two attributes of the Super CCD  that makes the camera special, IMO. Special mention also goes to the excellent AWB which makes life a heck of a lot easier.
A couple of snaps:
Great photos and thread!
Have a good one,
Serge
 Serge 07's gear list:Serge 07's gear list
Fujifilm FinePix S5 Pro Nikon D40 Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8
SamfromAL Regular Member • Posts: 242
Yes they are!
A good example, I shoot Kelvin mostly using an XE or XT to find it
subtleties of white, trips to AK
fPrime
Serge 07 wrote:
Hi, fPrime:
Have a good one,
Serge
Hi Serge,
Thanks for chiming in... and with some beautiful example photos to boot!
Yes, I agree that in bright sunlight (like the first example in your post) the S5 Pro holds onto deep, rich colors incredibly well thanks to its SuperCCD sensor. This is where many modern cameras can clip colors even if purposefully set to expose for highlights. The reason for this is that certain color channels (like red in particular) often reach a saturation clipping point well before there's an overall highlight clip.
I meant to ask you earlier, but what are you using these days to do your S5 Pro RAW conversions with?
fPrime
fPrime
Re: Yes they are!
Wow! Look at how the S5 Pro holds the orange tones from dark to bright in that Lambo. Thanks for adding, Sam.
fPrime
Re: Yes they are!
Agree and that is pretty much how i remember the car that day in that light.  The orange is a very impressive color and paint application by Lamborghini.  Was very happy it came out as obvious from the pictures
Serge 07
fPrime wrote:
Serge 07 wrote:
Hi, fPrime:
Have a good one,
Serge
Hi Serge,
fPrime
Hi, fPrime:
I mainly allow the S5 to do its thing and use the JPEG files with a bit of tweaking in Lightroom. The settings are default with color +1, noise reduction low and DR set to auto, firmware 1.09.
Since I have Hyper Utility, may start experimenting with the raw files which should be fun.
Take care,
Serge
Ringwraith69
Ringwraith69 Veteran Member • Posts: 3,407
Just chiming in as a former S5 Pro (and S3 Pro before it) owner. I found that CaptureOne could handle the S5's RAW-files very well. It really allowed you to optimize the filmic look this camera could produce.
By the way: calling the S5 a slow camera made me smile just a wee bit. Because as I said, I also had an S3 before. That was definitely glacial compared to the S5
(We are only immortal for a limited time)
 Ringwraith69's gear list:Ringwraith69's gear list
Sigma DP1 Fujifilm FinePix X100 Fujifilm X-S1 Sony RX10 II Sony RX10 IV +42 more
fPrime
Serge 07 wrote:
fPrime wrote:
Serge 07 wrote:
Hi, fPrime:
Have a good one,
Serge
Hi Serge,
fPrime
Hi, fPrime:
Hi Serge,
Thanks for sharing your processing details. So basically you are enhancing the JPEG’s straight from the camera. People don’t believe me when I tell them the SOOC output from the S5 Pro is so good that it’s hard to beat in RAW but that’s the truth!
For what it’s worth I’m also on firmware 1.09, standard profile, sharpening STD, NR org. I do vary my color and DR settings dependent on what I’m shooting, though.
You’ll find Hyper Utility to be full of quirks compared to LR, but it is the only way to match the SOOC output. It does allow you to change the exposure, WB, and DR settings at will so nothing is lost from tweaking.
fPrime
PeterFXCassidy Contributing Member • Posts: 792
Indeed, images from the S5 have real texture. No camera has excited me more to print since I left black and white dark rooms. When I saw the first images out of the S5, my first thought was I have to get these in prints. Still running the Canon PixmaPro and it's here because of the S5
fPrime
 PeterFXCassidy's gear list:PeterFXCassidy's gear list
Fujifilm FinePix E900 Zoom Olympus TG-810 Fujifilm FinePix S5 Pro Fujifilm X-E1 Fujifilm X-M1 +11 more
H1ndot New Member • Posts: 14
Where can I get the Fuji Hyper Utility HS-V3?
