G9 Affinity alignment example
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 17,093
I don't know if this is of any interest but it was to me. The pictures below of a common spotted orchid which sprung up on my lawn. Well not exactly sprung; the whole plant of which this is the top half was about and inch and a half/35mm high. Normal plants in their usual woodland/meadow settings are up to 10 times that size.
To photograph it with the Oly 60mm meant lying flat on the ground and unusually hand holding or steadying while I produced a 20 image focus bracketing selection. Not surprisingly I made a bit of a mess of keeping steady The first 6 pictures are samples to show the variation, the stack actually used 12 of the 20 original shots. . Not expecting much I ran it through Affinity and was staggered at how well the alignment was achieved. Picture 7 is the resultant stack. Many people may expect alignment like this but it was my first experience with such a variation on the source material. I'm not posting as a great picture , only to show how well the alignment was managed but it's not a bad shot.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic Lumix DMC-GX7 Panasonic G85 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Ken Yull
Ken Yull Senior Member • Posts: 2,344
Re: G9 Affinity alignment example
Well it would be a keeper if was mine. Did you only take one batch Trevor, I use focus bracketing or post focus, and would normally for a still subject take at least one set of each option. In the six posted I would try just #1, #2, #3, and #6, if they are the only ones that line up within the same tolerance.
But as I say the result you have is pretty darned good considering how much movement there seems between shots. Definitely worth the trouble taking.
Cheers. Ken.
 Ken Yull's gear list:Ken Yull's gear list
Fujifilm FinePix Real 3D W1 Panasonic LX100 Panasonic FZ2500 Panasonic G85 Panasonic G90 +2 more
IanYorke Veteran Member • Posts: 4,001
I had a similar experience when I was just playing about with focus stacking. Took a sequence of some flowers, just bent over and rattled off a burst. Flicking through the photos showed large movements but Affinity Photo did a remarkable job.
Considering the cost of dedicated apps for focus stacking AP is a no brainer at its modest cost for pixel editing, panos, HDR and focus stacking even without the recent 50% off.
Ian
Trevor Carpenter
OP Trevor Carpenter Forum Pro • Posts: 17,093
I've given up on post focusing for stacking, not that it is bad but just that I have found focus bracketing much better.  I still occasionally use post focus for subjects where I can see that focus might be iffy and just take the best one.  This flower is actually an example of where I might use it but focus bracketing and affinity stacking definitely seems the best of a number of options.
