600mm f/11 or 800mm f/11 - which one would you buy?
Started Jun 21, 2020 | Polls
CanonKen Senior Member • Posts: 2,936
Assume the prices will be similar (as in, price if you could afford one, you could afford the other). All else being equal, which one would you pick?
My initial reaction was the 600mm, but I realized if I bought the 1.4x teleconverter, my 100-400mm would be a 560mm f/8, and I could see eventually buying the RF 100-500mm. As such, if I was 'limited' to f/11 on both, might as well get the 800mm and use it for special occasions. I have a heavy tripod with a Wimberley-style head, which would be useful on this lens.
 CanonKen's gear list:CanonKen's gear list
Canon EOS 5D Mark IV Sony a6400 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Sony E 50mm F1.8 OSS +5 more
POLL
600mm f/11
8.7% 2  votes
800mm f/11
91.3% 21  votes
  Show results
JasonTheBirder
JasonTheBirder Senior Member • Posts: 3,967
Re: 600mm f/11 or 800mm f/11 - which one would you buy?
I would go for the 800, assuming its sharpness wide open were on the level of the usual supertelephotos.
Ray Chen Veteran Member • Posts: 9,652
I buy either and then a battery powered strobe with long throw reflector.
Probably 800mm.
Ray
 Ray Chen's gear list:Ray Chen's gear list
Canon EF 40mm f/2.8 STM
H2ODoctor
H2ODoctor Regular Member • Posts: 340
How about neither?
 H2ODoctor's gear list:H2ODoctor's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 400mm f/5.6L USM Canon EF 17-40mm f/4.0L USM +5 more
Messier Object Forum Pro • Posts: 12,711
Neither
6
Neither would entice me to buy an RF mount camera
Message to Canon:
Sorry Canon,  if you want me to buy into the EOS R system, cheap long slow lenses won't do the trick. You need to offer me an APS-C EOS R7 as an upgrade to my 7D2, or you need to offer a very high Megapixel R camera which will have a seamless  in-built 1.6x crop mode to 32Mpix and with fps and AF performance better than the 7D2
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
pawn Veteran Member • Posts: 3,261
If IQ is "acceptable" at f/11, I would buy the 800mm since I already have 100-400mm II + 1.4x III
KevinRA Senior Member • Posts: 1,466
Neither. f/11 is too slow.
If they did a 600mm f/8 DO which was highly portable, perhaps.
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
arbitrage Contributing Member • Posts: 585
Now that we've seen what they look like and they are obviously retractable so the 800 is not too long to pack easily, there is no reason I can think of to buy the 600 over the 800.
If the 600 was f/8 that would be a different story.
But if I'm after "reach" for birds (which I am), the 800 is the only one that makes any sense to me.
I spent an entire day last week shooting at f/11 at 840mm (with my 600GM and 200-600) just to see what I could accomplish at that slow of an aperture.
One certainly has to pick one's battles carefully and background management is critical (which it should be anyways even with an f/4 lens) but I was able to accomplish a number of pleasing images at f/11 even shooting GHOs in forest with low light.
Not sure if I'd every buy the 800/11 but if price was $1500 or below I might consider one for a lightweight walk around option.  Of course I'd much rather have a lens like my 500PF that can get to 1000 f/11.
 arbitrage's gear list:arbitrage's gear list
Canon EOS 450D Nikon D500 Nikon Z50 Sony a1 Canon EF 100mm F2.8L Macro IS USM +15 more
Colin46 Senior Member • Posts: 1,700
5
Neither, too slow and lack of background separation at f11 renders these two useless for me.
just because modern cameras can go to high ISO’s doesn’t mean you want to.
 Colin46's gear list:Colin46's gear list
Nikon Z9 Canon TS-E 24mm f/3.5L II Nikkor AF-S 300mm f/4E PF ED VR Nikon AF-S Nikkor 500mm F4E FL ED VR Nikon 24-70mm F2.8E ED VR +6 more
OP CanonKen Senior Member • Posts: 2,936
Agree a 600mm f/8 would be my preference, but apparently not.
I'm just asking for what is on offer, what option?
Wildcard...what if the 600mm is actually f/8 and the 800mm is the f/11?  The math is nearly identical (73 vs. 75) if you divide the two numbers.  If so, then the 600mm would be my pick.
SkySpades Regular Member • Posts: 228
Big lack of background separation in this thread full of f/11 images.
https://www.fredmiranda.com/forum/topic/1649828/7
 SkySpades's gear list:SkySpades's gear list
Nikon D500 Tamron SP 70-200mm F/2.8 Di VC USD Tamron 15-30mm F2.8 Nikon 200-500mm F5.6E ED VR Sigma 50-100mm F1.8 DC HSM Art
jurci Regular Member • Posts: 118
That sounds like the Minolta 500 F/8.0 reflex mirror being versatile and highly portable. I have owned it and really enjoyed it. If you really want quality, then the we will have to wait for a RF400/2.8.
 jurci's gear list:jurci's gear list
Canon EOS 5D Mark IV Canon EOS R6 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +4 more
BirdShooter7 Veteran Member • Posts: 9,134
Yes it should be fine for setups if you’re into that.  Of course if you’re doing a setup why not just move a little closer and use your 100-400 mk2 at f/5.6 and avoid iso 3200 and 6400...
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
gavin
gavin Veteran Member • Posts: 8,242
Same here (100-400II + 1.4xIII). 800mm or bust It could be a reason I switch to RF system.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
Andy Blanchard Senior Member • Posts: 1,349
Re: Neither
Message to Canon:
Peter
"Neither" was my first instinct too, but that's possibly just because I'm used to thinking that superteles need to be f/4 for use in low light. Set that preconception aside and think afresh and maybe there is a usage case for both of these.
You need that kind of wide aperture speed when you are shooting at have low light levels and are limited in your ISO by when noise becomes a problem. When I first started with digital, anything above ISO800 was problematic, and I managed just fine with f/4 super teles most of the time - actually I had too, because it's as good as it got.
Yesterday evening, I was out in my garden getting perfectly usable shots of bats (pipistrelles) in flight at ISO 25600 f/5.6 with a 1DX MkIII at well after 22:00. That's *six* full stops over the f/4 ISO800 combo, whereas f/4 to f/11 is just three. f/11 also gives you a lot more usable DoF, especially at 600mm or 800mm where it can be a challenge to get larger animals sharp front-to-back if you're not stopped down to f/8 or f/11 anyway.
So, if Canon can pair these with a sensor with the ISO performance of a 1DX III, provide acceptable AF performance at f/11, *and* give decent image quality for the money, then I can well believe that a lot of wildlife, and especially bird photographers, that can accept the loss of background seperation will be all over these. From what I've seen of the rumoured specs though, neither the R5 or R6 is going to be that body, and there's still not even a really plausible hint of an R1.
Andy
Re: Neither
Message to Canon:
Peter
Andy
I think iso tolerance must be subjective, I’ve never been happy with any camera over 3200 for birds and fine feather detail. Topaz mask AI does an incredible job with high iso images but I prefer to not have to use it.
i will stick with the big guns for now until canon release something similar to Nikon’s 500 f5.6 pf. A 600 f5.6 DO would be amazing and something I would definitely go for.
Re: Neither
Definitely, but it does depend on the camera as well, and the 1D-series has always been Canon's flagship in this area, although a lot of birders do seem to prefer the 7D, so there's multiple angles of YMMV there.  I'm personally quite happy to go to ISO 6,400, but after that I'm starting to give serious thought as to how I really want to balance DoF, ISO, and shutter speed.
I'm not seeing any personal use for either of these either,I'm too used to at least have the option of using a shallow DoF to separate the subject from the background, but for those on a budget a relatively compact 600mm or 800mm that at least provides a shot without breaking the bank could be just the ticket.
That said, I am also very interested to see how well Canon has developed their DO tech since the 400mm and 70-300mm.  There was quite a bit of interest in DO versions of the EF mount lenses, so if these f/11 lenses are intended to be the superteles for those on a budget, then f/4 and/or f/5.6 DO versions of the big guns might sell quite well to pros who need a more compact and lighter solution.
Andy
John Crowe
John Crowe Veteran Member • Posts: 3,476
Not sure where this idea is coming from.  Nikon once offered a 600/5.6 and 800/8, so it seems these would be more appropriate for Canon too look into.
Also in the past f11 was generally acceptable for lenses in the 1200 to 2000mm range.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
800mm f/8 and 2000mm f/11 lenses are some seriously big, heavy lenses.  In those examples that aperture is more or less necessary to make them usable.  Even at that, they are VERY specialized pieces of equipment.
The purpose of these two new DO lenses seems different to me.  They seem to be all about giving lots of FL while staying pretty small and hopefully relatively inexpensive.  Unfortunately, like the lenses you mentioned I think they will be very specialized.
John Sheehy Forum Pro • Posts: 26,698
One should never think of background blur in terms of f-ratios, except when all you're varying is the f-ratio and maintain every single other thing the same.
The background blur comes from subject distance, background distance, and the size of your entrance pupil. Cropping 4x from a 200/2.8 lens gives the same background blur as 800/11.
People tend to read too much into f-ratios and lose sight of apertures.
The main downfall of an 800/11, compared to shorter lenses with cropping or crop factors, is that you can't zoom out, or remove a 2x TC and drop to 400/5.6.
Another way to look at this is that 800/11 on FF is like 500/7.1 on a 1.6x crop sensor, only 1/3 stop slower at 500mm than many 3rd-party zooms, but probably sharper and AF-ing faster.
Of course, when some people see these slow long lenses announced, they will fear that this means that faster ones are less likely to come any time soon, which may or may not be true.
