Is there a way to take pictures without Provia?
Started Jun 20, 2020 | Discussions
teenaxta Junior Member • Posts: 47
Just new into fuji system. Now when I go into film simulation it's set to provia/standard. Is there a mode where you can capture without any film simulation?
digital-freak
digital-freak Senior Member • Posts: 2,815
Re: Is there a way to take pictures without Provia?
There's a standard profile or shoot raw
 digital-freak's gear list:digital-freak's gear list
Fujifilm X-T4 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Samyang 12mm F2.0 NCS CS Fujifilm XF 16-80mm F4 +2 more
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
I suppose that would be the "Standard" simulation.
"Well, sometimes the magic works. . . Sometimes, it doesn't."
------ Chief Dan George, Little Big Man
@ bobtullis.com & flickr.com/photos/bobtullis
My opinions are my own and not those of DPR or its administration.
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
OP teenaxta Junior Member • Posts: 47
So is provia the standard profile or is it something different?
Erik Baumgartner Senior Member • Posts: 6,893
You can select an alternate film simulation/profile, but without one the is no image. You will have a RAW file otherwise. The are lots of in-camera tweaks to tailor the built-in sims to your liking. Provia is the “standard” profile
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
James H MacAllister
James H MacAllister Regular Member • Posts: 150
While shooting in RAW the film sim doesn't matter and can be changed in post. Turn "live view" on, to get a closer representative of the RAW file on the LCD & histogram. The file will still be marked with whatever film sim you have selected when brought into the RAW editor, but it can be changed to another film sim or linear if a sim is not wanted. In my case, I set Capture One to import in linear by default.
 James H MacAllister's gear list:James H MacAllister's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Bobo Hodls
Something different.  There are a few profiles that can be selected, "STD" or Standard is one of them.
Doug MacMillan Veteran Member • Posts: 3,695
I just went to the Q menu on my X-E3.  Select "STD".
Since you are new, have some fun and take some different types of photos with the different film simulations.   I suggest you shoot RAW + JPEG, but for the moment use the RAW files as safety negatives.  I don't know what kind of system you are coming from, but Fuji film simulations are in a league of their own.  You may be pleasantly surprised with SOOC. Later on, you can learn how to use the brightness/shadow adjustments to refine the film simulations.
One thing I've learned as well as the film simulations look better with the appropriate white balance.  AWB is OK, but I think it struggles when there is a lot of blue skylight. That's when using the shade/skylight WB works better.  Of course, you can also use a target and set a custom white balance if you really want to get down in the weeds.
Have fun!  You're going to love the X-E3.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
saltydogstudios
saltydogstudios Senior Member • Posts: 2,451
There is no such thing as a RAW conversion* that does not have opinions.
Whether it's Nikon's "Standard" or Canon's "Standard" or "Adobe Standard" - they all have opinions.
Fuji has just made theirs explicit with their naming.
* in camera JPG counts as a RAW conversion.
 saltydogstudios's gear list:saltydogstudios's gear list
Ricoh GR Digital Sigma DP2s Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp3 Quattro +13 more
jhorse Veteran Member • Posts: 5,913
Hi, every camera has a profile to determine a JPEG image, even if they don't have different selections as many do. As many responders have said, if you want to change the profile shoot RAW and adjust in post. Standard/Provia is the baseline, from which other profiles are available or which in RAM and post you can adjust to taste.
Personally, I use Provia (I use RAW + JPEG Fine) most of the time and then if needed adjust in post. Hope that helps.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
Ad12 Senior Member • Posts: 1,514
Provia is labelled “Provia/standard” in Lightroom. I think its standard.
Im new to Fuji too, but I LOVE classic chrome. I can not explain why. It’s not saturated or anything, just looks, so good to my eye. I cant it my finger on why I love it so much! It’s more natural than Provia I feel, but also has an artistic vibe.
 Ad12's gear list:Ad12's gear list
Nikon D500 Nikon Z6 Sigma 150-600mm F5-6.3 | C Sigma 100-400mm F5-6.3 Nikon Z 24-70mm F4
