Anyone good at electric?
Started Jun 19, 2020 | Discussions
nonproshooterdad Senior Member • Posts: 1,105
Got a car charger head, wondering how to connect it.
The ad photo is not so matched.
This is the real item photo.
jma60 Regular Member • Posts: 142
Re: Anyone good at electric?
The side prongs are ground and where the resistor connects before the LED is positive 12V.
OP nonproshooterdad Senior Member • Posts: 1,105
Thanks for the quick reply.
Here is the ad photos.
I just can't trust this photo. The arrows for the screw cap and spring are wrong. And when I opened it, the spring and the fuse switched in position.
Here are my questions:
1. There are two curved copper pieces. It supposed to be connected as negative pole. One of them connecting to the positive pole through an electric resistance and the RED light, one of them is stand alone. Which one should I connect to?
2. Should the fuse connect to the "contact head" or the spring connect to the "contact head" ?
The original one to be replaced by this item is very simple. The two side curved copper is actually one piece of copper as negative pole, and the positive pole is directly connect to the "contact head". No light, no fuse. With the new item, I have two pieces of curved coppers, and they're not connected. It seems totally different.
jvc1 Senior Member • Posts: 2,202
5
You know, they sell those that don't require assembly.
I keep some of my favorite pictures here,
https://www.flickr.com/photos/129958940@N03/
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
Glad to help. See below for answers.
It shouldn't matter. Use whichever one is easier to solder to. One of them is attached to the LED so that whenever the adapter is plugged in, the LED's circuit is completed and it lights up.
Ideally the fuse connects to the contact head first, so when you remove the cap the spring pushes the fuse out so you don't have to shake the fuse out. Otherwise it doesn't matter too much,
stevo23 Forum Pro • Posts: 24,758
This photo shows it right.
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
trungtran Senior Member • Posts: 1,747
No idea what OP is trying to do. But I agree, buy them with the wires already soldered on.
Cigarette Lighter Plug Cable Car
My experience with these things is buy a lot of fuses. You are sure to blow them.
 trungtran's gear list:trungtran's gear list
Olympus OM-D E-M10 Sony a7 II Canon EOS M6
mamallama
mamallama Forum Pro • Posts: 60,058
Here is the ad pho
All is OK except the spring and screw cap labels are reversed in error.
Where did you buy this from, Heath Kit?
 mamallama's gear list:mamallama's gear list
Panasonic Lumix DMC-GX85 +1 more
I bought it from eBay, to replace the one used on my air pump. Original one doesn't have fuse, but it said 12V, 15A. I only found this one that's more than 15A.
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Give or take the wire coloring code....  Whichever wire went to the center in your old connector is the + wire here.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Entropy512 Veteran Member • Posts: 6,016
I just stopped by these forums after a long break - it looks like the OP was trying to repair something.
Just for future reference if others show up, my personal recommendation when trying to repair somethiing like this:
Cut the wires
Put Anderson Powerpoles on the cut wires
Buy a preassembled cig lighter plug to Powerpole adapter, or buy a lighter plug with cables preattached and terminate Powerpoles onto it.
I have an air pump and a portable cooler that now both have Powerpoles, and can either be powered by a CL plug, or a big 200+W 12v supply.
Anderson Powerpoles have become the de facto standard for amateur radio emergency service 12v power wiring.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
Will T
Will T Regular Member • Posts: 425
In this photo the coil spring is in the wrong position!
Do not use the coil spring as a conductor as it will act as a resistor and create heat under heavy current. (Think of the cigarette lighter you unplugged to insert this plug!)
Will T.
"Galleries don't hang DxO charts" David Hull
I gave up already. I finished the welding and my efforts didn't pay off. It didn't work. The welding work is pretty hard. I don't need the LED, don't need the fume, they make things complicated.
I am thinking to buy another one. I bought this one in eBay because of its high amp number. Others seem too delicate.
I was thinking to buy another compressor instead. But I don't use the car so often now because the pandemic. I have time. So I can make another attempt.
Let me know if you have any recommendations. Thanks.
Don't always believe specifications. As the poster indicated, the design of this is such that the high amperage specification is questionable due to the spring carrying current.
I know I found a reasonably well-designed plug somewhere, but it's been nearly a decade since I replaced the plug on a thermoelectric cooler and I don't remember where I got the replacement. I'm pretty sure it was using screw terminals or crimps for the high-amperage wiring.  As I said, I've generally moved to using Anderson Powerpoles, and an off-the-shelf (from a trusted source, Powerwerx) pigtail to go from a cigarette lighter socket to Powerpole.
