XT4 Adjusting ISO 1,2 and 3 settings in Auto ISO
topcat74 Forum Member • Posts: 63
Hi, I have the camera set to Auto ISO in Aperture priority mode.
The problem I have is I cannot select between the 3 Auto settings using the front command dial, on pressing the front command dial I should be able to select these but nothing happens. All I get is SS, and Exp. Comp.
I have tried the manual but to no avail.
The front command dial works fine in Manual mode, I can adjust SS and Iso no problem.
Any suggestions will be gratefully received
 topcat74's gear list:topcat74's gear list
Nikon D850 Fujifilm X-T4 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +5 more
Bob Tullis
MOD Bob Tullis Forum Pro • Posts: 39,792
ISO dial setting?
Do you have the ISO dial set on C(ommand)? If set on A(uto), that might be the problem.
"Well, sometimes the magic works. . . Sometimes, it doesn't."
------ Chief Dan George, Little Big Man
@ bobtullis.com & flickr.com/photos/bobtullis
My opinions are my own and not those of DPR or its administration.
 Bob Tullis's gear list:Bob Tullis's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Chandrahadi Junarto
Chandrahadi Junarto Regular Member • Posts: 445
Re: XT4 Adjusting ISO 1,2 and 3 settings in Auto ISO
Go to: button/dial setting->command dial setting then put the ISO option in there
Edit: if you already done that, i just rotate the command dial for the iso auto
Hope that helps
'See with your eyes - Shoot with your heart..'
http://www.flickr.com/photos/c_junarto/
 Chandrahadi Junarto's gear list:Chandrahadi Junarto's gear list
Nikon Df Fujifilm X-T10 Fujifilm X-T4 Nikon AF Nikkor 35mm f/2D Nikon AF Nikkor 180mm f/2.8D ED-IF +17 more
