The 60/2.4, she is not so bad
Started Jun 16, 2020 | Photos
CeeDave
CeeDave Senior Member • Posts: 2,208
7
Okay, few of my shots go near the max mag of the lens, and f you need higher mags then you do. But it is sharp, small, and affordable, and even good at infinity-ish focus.
Chris
A couple of Fuji cameras and assorted X-mount and adapted primes
 CeeDave's gear list:CeeDave's gear list
Fujifilm X-E2 Fujifilm X-H1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +12 more
Comment & critique:
Don Davis
Don Davis Contributing Member • Posts: 902
Re: The 60/2.4, she is not so bad
Very nice!
 Don Davis's gear list:Don Davis's gear list
Fujifilm X100F Sony RX100 VII Fujifilm X100V Nikon D700 Fujifilm X-T2 +1 more
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
I'm not so sure whether it's the lens that makes these impressive.   Sure it helps. . . that's v.good photography.  Well done.
"Well, sometimes the magic works. . . Sometimes, it doesn't."
------ Chief Dan George, Little Big Man
@ bobtullis.com & flickr.com/photos/bobtullis
My opinions are my own and not those of DPR or its administration.
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
CeeDave
OP CeeDave Senior Member • Posts: 2,208
Don Davis wrote:
Very nice!
Thank you for viewing and commenting, you are very kind.
Chris
CeeDave
The lens definitely helps, it is very, very good. Now I need to learn to use flash properly! Thanks for your kind comment.
These shots were in the Audubon refuge at Allens Pond and the Trustees property at Rocky Narrows, both in MA. Thanks to both of those organizations.
Chris
bclaff Forum Pro • Posts: 13,932
For techies, here's the Fujifilm Fujinon XF60mm F2.4 R Macro in the PhotonsToPhotos Optical Bench
One interesting thing is that it does not focus breath.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
CeeDave
Thanks, interesting to me, especially seeing the extension as it goes from infinity to closest focus.
Chris
