The cream rises
Started Jun 11, 2020 | User reviews
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
The cream rises
12
What can I say about the 90 f2. It is a top notch lens. It is so go that I decided that since most of my shots at the track with my 50-140 90% of the shots were 85 to 95 mm focal length ( at step or two with the 90) to sell my 50-140 and use the 90 instead. It's faster, smaller and lighter. While the 50-140 is a cream d'la cream for a zoom the 90 is better at 90. . It is tack sharp from corner to corner and its overall rendering is nice and smooth. It is a 135 equivalent and it's not a focal length I use often but when you need it this lens is a wonderful flexible lens to use.
Positives:  Top of the class rendering.  A fast medium focal length lens for APSC.  Can be used for a lot of applications from sports to portraits.  It is a fast lens.
Negatives: Very difficult to find anything negative to say about this lens.  The only thing that might make this better is a 9 blade rounded aperture instead of 7 for even smoother transitions in out of focus areas.
An all a good solid A performer.
_____
"The winds of heaven is that which blows between a horse's ears," Arabic Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Fujifilm XF 90mm F2 R LM WR
Prime lens • Fujifilm X • 16463668
Announced: May 18, 2015
Truman Prevatt's score
5.0
Average community score
5.0
Ulrik Christiansen
Ulrik Christiansen Senior Member • Posts: 2,837
Re: The cream rises
Couldn't agree more. One of my favorites!
 Ulrik Christiansen's gear list:Ulrik Christiansen's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8 Fujifilm XF 56mm F1.2 R +3 more
dmaclau Veteran Member • Posts: 3,053
Re: The cream rises
I came by the 90 as there are surprisingly few fast mid telephoto options.  I moved from FF Nikon to the XP2 for the OVF and grabbed the 90, my only option,  hoping it would perform.  Wow.  What a lens.
Very fast dynamic changing action, low light, fast shutter speed high ISO.  This combo of camera - lens might be the only one capable.
For example this event occurred slightly out of "sensor view" but well within OVF view, transpired within a split second and then was over.
absolute power corrupts...absolutely
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Fujifilm X70 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
MrSee
MrSee Senior Member • Posts: 2,604
Re: The cream rises
Very nice. Love the B&W
Jim from Ontario Canada
Fuji X-H1
Fuji 18-55 2.8-4
 MrSee's gear list:MrSee's gear list
Fujifilm X-H1
Rod McD Veteran Member • Posts: 8,589
Re: The cream rises
Hi Truman,
Agreed.  It is indeed an excellent lens.   I've tried many an adapted legacy 85-90-100-105 and there are few that come near, especially at wider apertures.  (Some are very comparable at middle apertures.)
If the lens has a foible, it's flare.  It can flare if you get the sun close to the edge of the frame or included in the frame if you're shooting at sunset.  It's not alone in that though.....
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
Dean66
Dean66 New Member • Posts: 21
Re: The cream rises
I'm glad  to trade my xf55-200mm for the Fujifilm 90mm.
 Dean66's gear list:Dean66's gear list
Fujifilm FinePix S9100 Fujifilm FinePix IS-1 Fujifilm X-T30 Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +1 more
Geekapoo
Geekapoo Senior Member • Posts: 2,831
Re: The cream rises
I have used the 90mm but decided I'd much rather deal with the extra weight and stellar coverage/performance of the 50-140..IMO, easily one of Fuji's best lens options.  If owning the 50-140, no need (at least for me) to own the 90, plus I benefit from a wider focal length focal range!
 Geekapoo's gear list:Geekapoo's gear list
Sony RX10 IV Fujifilm X-E3 Sony a7R IV Sony a9 II Sony 35mm F1.4 G +15 more
