100-300 Panasonic not as Sharp as i wanted
Started Jun 10, 2020 | Discussions
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Re: 100-300 Panasonic not as Sharp as i wanted
rick in vegas wrote:
hence the cheap price. I sold mine.
To replace it with what? Oly 300 F4 ($$$), Panny 100-400 ($$)? Or superb Oly 75-300 ($) ?
Maybe if you had tried to use it correctly...
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
pannumon Veteran Member • Posts: 4,130
WhiteBeard wrote:
pannumon wrote:
If you have someone to give you good advice, you will get better results by using raw with a half day training, but that is very very positive thinking. Raw simplifies things, but developing your own workflow takes some time. Also, raw development won't do miracles, but saving the results of careful analysis of lens/shutter speed/ISO combinations makes it quick and easy in the future. In principle, but I think it's also good to understand what's going on with the processing.
I beg to differ. Since I crossed from the 36 exposure 35mm film era to the "all-you-can-eat" digital era, I found that the number of pics I took on any given trip was mind-boggling. Just the classifying and renaming of the pics takes days. If I were to shoot everything in RAW + JPEG, it would take me years of PP per month of travel. Even doing RAW on very specific venues is almost overwhelming and defeats the purpose of having fun with your photography. Now ideally, if I could get back to the time when every shot - out of 36 - counted, then, yeah, I'd be a RAW fan. With 3000 pics?
Good workflow means automatization of post-processing. It's a friend. Basically you select batch of photos and apply a preset. "Developing" the set of presets is somethong that takes time, but when done, it's quick (I am not there yet).
Wildlife photography is one of the few areas of photography where sufficient technical quality is difficult to achieve. I can assure that it won't happen that there would be too many excellent wildlife photos in the hard drive/SSD. But those who are saying that 100-300mm lens does not provide good results are either not trying hard enough, they lack the know-how, or they have a bad copy of the lens.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
I find that with ISO 800 will destroy a lot of the detail, at least when using 10-bit electronic shutter. But sometimes it is necessary. With my G7 and electronic shutter, 1/300s shutter speed was the minimum I wanted to use, even if it meant that I had to use ISO 400 or 800. I was perfectly happy if I could shoot at 1/300s ISO 200.
darrinlingle
darrinlingle Senior Member • Posts: 1,028
Re: Nothing wrong with those --->
AdamT wrote:
Wigelii wrote:
AdamT wrote:
Nothing wrong with those whatsoever for a lens which is a 1st generation design and can be bought for as little as just over £200 secondhand ......
I`ve seen worse examples from the expensive PanaLeica 100-400 (which has a very Polarised reputation)
Is the 100-400 not worth buying?
opinion on whether its worth the money is polarised also whether or not its sharp at 400mm wideopen given that it`s already 1/3 of a stop too slow at F6.3 (even F5,6 is starting into diffraction) and not exactly cheap at £1100
I have no personal opinion on it, I live in the UK where its dull 90% of the time, F2.8 rules here - LOL
the olympus pro lenses are a little more, but sharper, more expensive, and a little better built.
i really got some great shots with the PL 100-400 but these two new Oly lenses (40-150 f/2.8 and 300 f/4 pro) are amazing with and without the TC-20.
Darrin Lingle, Colorado
 darrinlingle's gear list:darrinlingle's gear list
Fujifilm X-T3 Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 23mm F2 R WR +5 more
zwagner New Member • Posts: 12
FWIW, I think the shots look pretty good, and I realize I'm a bit late to the party here. I recently had the Panasonic 45-200 lens, using it on a M1 III, and I didn't like the slow AF and at 200 it didn't look amazing (to be expected), plus 200 really isn't long enough for birds IMO.
So I updated to the Oly 75-300 II in hopes I'd get a good copy (seems to be lots of sample variation), and that the AF would be better than the Pana (I didn't have any illusions it would be a speed demon).
I have to say I have been nothing but pleasantly surprised, both with the AF (it can still be spotty, and mis-focus abysmally, but it's faster for sure) and with the sharpness at 300mm. By all accounts I'd thought it would be not great at all at 300, but with the right settings, I find I have no trouble getting sharp shots at 300, even down to 1/40 shutter speed. The IBIS of the M1 III is truly astounding in this regard. That said, I also use either silent shutter, or anti-shock (0 sec). It's nice you can use the anti shock for rapid fire as well.
I'm not sure what settings Panasonic has that might be similar, but that's often the more important part of the process to getting sharper shots.
Here are some dragonflies *ehem* doing something...at 300mm.
Oly 75-300, E-M1 III, 1/400, 300mm, ISO200, edited in Lightroom and Luminar
KenTel
KenTel Senior Member • Posts: 2,567
Great shot, that lens is a good one in your hands. Studying the subject the lower one must use a lot of left rudder to counteract the wear and tear to its wings. Fascinating creatures and masters of their flight. Glad you posted.
Cheers. Ken.
 KenTel's gear list:KenTel's gear list
Fujifilm FinePix Real 3D W1 Panasonic LX100 Panasonic FZ2500 Panasonic G85 Panasonic Lumix DC-S5 +8 more
Thanks Ken!
Yeah dragonflies are completely alien, fascinating creatures. Love them. Here's one more, blue heron in flight. This one wasn't *quite* tack sharp... I'm still trying to figure out the best settings/way to capture birds in action, but overall I'm happy with it.
Oly 75-300 @300mm, E-M1 III, ISO200, 1/800
KenTel
Well on my Pannys I set the shutter button to work on half press, but not to take an exposure until subject is in focus. This works better than I can, though if you don't have the focusing area over the subject chances are it will focus on something else, so a bit hit and miss though better than I can do any other way at present. And quick. I do use the Olympus RDS, expensive but far better than others I have tried. But due to this epidemical nightmare and my shelf life I'm not as active away from home as I would like.
Cheers. Ken.
Yeah that sounds similar to what I'm doing. I have it on focus priority as well. Sometimes it slows things down a bit but I'd rather have a greater chance of getting sharp shots.
I had to look up the RDS you mentioned. That is some cool stuff!
WhiteBeard
;-)zwagner wrote:
Thanks Ken!
My - somewhat uneducated - guess is that for BIF that are close, i.e. cover a lot of frame space rapidly, 1/800 might not be fast enough. I personnaly set the default ISO at 800 on my GX8/100-300 MkII combo and I back off if the subject is so far I know I may need to crop heavily. The noise handling on the E-M1 III being excellent - for µ4/3 - you could have traded higher ISO for speed. Try settings between 400-800 ISO next time he flies around.
Then again, better check with real BIF experts...
WhiteBeard wrote:
;-)zwagner wrote:
Thanks Ken!
Hahaha no that's sound advice. I did end up bumping to 400 ISO, as I was trying to capture some egrets battling over hunting territory. It did work pretty well although I still only got a few real keepers out of a fairly ridiculous number of shots. The focus on the one below, for example, is a bit out but I was at a much faster 1/3200 and iso 400.
Oly 75-300, E-M1 III, f7.1, 1/3200, ISO 400
grcolts Veteran Member • Posts: 3,914
Carlo11 wrote:
Thanks for quick and positive respons. Havn’t had such a long lens before. Didn’t know What to expect . Glad to Hear There is nothing wrong with The lens. I Will be happy with it now thanks to you all!!!
it’s not The 1st generation, its The mark ii (480 euro’s)
i Will try to shoot raw! GOOD TIP. Havn’t done That before. I Will find Out.... lots of tips on this forum i suppose.
The G85 is oké, but maybe i Will look for a g9. Pinpoint focussing Will be more accurate i think.
one thing i noticed is the Need for relative fast shutter speeds with these subjects. Stabilisation is useless with moving animals. So with low light it can be difficult to get Sharp images.
I use the G9 with my 100-300ii and it works vert well. It is nice to have the option to quickly set the pinpoint AF on it. The size of the G9 fits great with the lens too.
OutsideTheMatrix
OutsideTheMatrix Veteran Member • Posts: 9,876
does the electronic shutter have less bits? I wasn't aware of that.  what happens with silent shutter if you use longer shutter speeds?  is it good for long exposure night time photography?  I thought thats what live composite mode uses.
In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist. We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
-Dwight D. Eisenhower, 1961
 OutsideTheMatrix's gear list:OutsideTheMatrix's gear list
Nikon Coolpix P900 Olympus PEN E-PL6 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +9 more
OutsideTheMatrix
thats excellent!  reassuring for those of us who are using the 75-300 with silent shutter on the EM10Mk2 in burst mode for BIF (like me lol)
OutsideTheMatrix
this gives to me because I am using the silent shutter for birds (and dragonflies) in flight too, in burst mode (11 fps) with the 75-300 lens on the EM10Mk2.  Trying to find the right shutter speed to use.  I wonder if this combo can also be used for hummingbirds?
jalywol
jalywol Forum Pro • Posts: 12,301
Depends on the body. The GX8 electronic shutter is 12 bit, but the GX7, for instance, and GM5 were 10 bit.  You'd have to look it up for the particular body you were interested in, to find out.
Can't help you with the long exposure questions though, as I don't know the answers.
-J
OutsideTheMatrix
-J
thanks I wonder where I would find the info for my camera- it's the EM10Mk2.  I'd like to see this info for all M43 cameras as well as read out speed!
Is the following correct:
all JPG is 8 bit
all M43 RAW is 12 bit
jeffharris
jeffharris Forum Pro • Posts: 11,409
Nope. GX7 has delivers 12 bit with the silent/electronic shutter
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
jalywol
Hmm, I thought it was 10.  My error.
-J
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
Can you please send me the link for that 200 second hand offer??? I have been looking for mk2 and can’t find it below 350-400!!
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
