100-300 Panasonic not as Sharp as i wanted
Started Jun 10, 2020 | Discussions
(unknown member) Senior Member • Posts: 1,455
Re: A myth
jeffharris wrote:
AllFlawed wrote:
jeffharris wrote:
spike29 wrote:
F7.1 if i need the shutterspeed, f8 for starters and f9/11 for dof need
f9-f11 is squarely in the diffraction zone. Avoid using those, unless loss of sharpness and detail is what you’re looking for.
No diffraction below this? Instant onset of diffraction effect at f9? What exactly does diffraction zone mean?
Generally, after f5.6 diffraction begins. After that it gets worse the smaller the aperture used. Once you’ve passed the point where diffraction starts, I’d call that the diffraction zone.
That’s pretty simple, no?
If there’s a more official designation, enlighten me.
People do dig deep looking for diffraction sometimes and the blur from diffraction is a lot less than with anything but the subject itself being plain out of focus with a wider aperture. I think the diffraction side of things does overly scare people off from closing up the aperture when it is needed.
jeffharris
jeffharris Forum Pro • Posts: 11,409
Re: A myth
It depends on the subject and the lens, too.
When I first got my GH2 and 7-14mm f4 I was out shooting some landscapes… water, trees, etc.… and not being familiar with the camera, was relying on the camera to make exposure decisions. There were a bunch of shots at f9, f10, & f11 where foliage detail was obliterated using those apertures. I decided to go back to basics and shoot in M mode.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Re: A myth
bclaff wrote:
Eric Nepean wrote:
Consider this:
Diffraction is caused by light passing through a hole, and the effect is proportional to the hole size over the wavelength of the light. The limiting hole in a well desgned lens is the aperture mechanism.
But we don't really know how big the aperture is - not easily
We see the entrance pupil, which is the aperture seen through all the optical elements in front of the aperture. For telephoto lenses, this is usually slightly smaller than the diameter of the front optical element. (clearly not the case for the 12-100/4 however)
The sensor "sees" the exit pupil, which is the aperture seen through all the optical elements behind the aperture. The diffracted light is also affected by the optical elements behind the aperture, as is the light which is not diffracted.
The front focal length is often different than the rear focal length.
I think we best post this in the Photo Science and Technology forum.
Focal length is focal length regardless of front/rear, you may be thinking of a different distance.
In your Optical bench you report a quantity called "Back Focal Length"
Perhaps I was imprecise in using "rear" instead of "back"
Don't have much time for research to day. but Wikipedia defines
  • Front focal length (FFL) or front focal distance (FFD) (sF) is the distance from the front focal point of the system (F) to the vertex of the first optical surface (S1).[1][2]
  • Back focal length (BFL) or back focal distance (BFD) (s′F′) is the distance from the vertex of the last optical surface of the system (S2) to the rear focal point (F′).[1][2]
True, this is only Wikepedia, but the references quoted seem pretty solid.
If there is a reason to distinguish FFL from BFL, that would only be because they are not necessarily the same value. At least one of them will sometimes not be the same as the Focal length printed on the lens and stated in the specifications.
I recall seeing an equation relating focal length to BFL and FFL to magnification.
In any case, the ratio of exit pupil size over entrance pupil size is called pupil magnification. And this does affect diffraction (and depth of field and other things. It's often overlooked.)
(I followed your recent post on the exit pupil size and relationship depth of field  and the ensuing discussion)
Even if the magnification is 1, is the Aperture diameter the same as the entrance pupil diameter? Seems unlikely with those optical elements in front of the aperture.
It wouldn't maater, except that we derive the diffraction based on  the ratio of aperture diameter to the wavelength, and magniication of of the aperture isn't going to scale the wavelength.
We don't often know this value but you can get a sense by visual inspection.
In general pupil magnification is around 1 for lenses with and angle of view of about 30 to 50 degrees.
Wide angle lenses can have pupil magnifications that are quite high.
Telephoto lenses are usually below 1.
I'm currently working on a survey article regarding pupil magnification across a large number of lenses. Stay tuned.
Cheers
Eric
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
bclaff Forum Pro • Posts: 13,939
Re: A myth
Eric Nepean wrote:
bclaff wrote:
Eric Nepean wrote:
Consider this:
FFL and BFL are of no practical use in ordinary photography. They are optical design values.
No because pupil magnification is exit over entrance and has nothing to do with the physical diaphragm. However, see below.
It wouldn't matter, except that we derive the diffraction based on the ratio of aperture diameter to the wavelength, and magnification of of the aperture isn't going to scale the wavelength.
The Airy disc that originates at the physical diaphragm is projected onto the image plane as a different size. That size is not pupil magnification per se but as you allude to above exit pupil over diaphram.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
(unknown member) Senior Member • Posts: 3,290
Re: 100-300 Panasonic not as Sharp as i wanted
I don't think your shots are at all bad - better than my early attempts by some way.
I remember other threads on this forum about the 100-300 which caused me to review my use of the lens ( I have the Mark 1 Mega ois which I used on em5.1 and em1.1)
In absolute terms it it not as sharp as the other m43 suspects but, In my case, I realised by looking at stuff that I had shot, most of the issues were my fault:
- shooting at too low a shutter: I found that 1/800 min, even for static subjects, was what I needed. Whether this was my handholding technique or whatever is another matter.
- I therefore let the ISO go relatively high, shoot in RAW ( as usual ) , and use some minimal NR in post - nowadays Prime NR on on DXO Photolab.
- I also, as many are saying, dropped to f6.3-f7 in general or whatever DoF requires, and usually backed off to 280 mm ( not sure the latter was really necessary )
- there was also my not taking account of atmospheric haze and expecting too much at distance. Whether from this or other causes, I generally get better results closer in, say 50-200 m ).
I suppose what I am saying is that I found getting the best from this lens took more care than with most for some reason. ( I also use a tam 150-600 G2 and sig 100-400 on Nikon FF and DX as well as a CX 70-300 and other Nikon long glass on Nikon 1 bodies + FT1 and those systems seem more forgiving somehow ).
I had the PL100-400 for about a week until it broke and my impression was that it was sharper but not as sharp as the Tam G2 on D500 ( EFL 750 ) or the CX 70-300 at 300 ( 810mm EFL ).
I still have the 100-300 but it doesn't get a lot of use these days but that is not because of the lens but my deciding to leave long reach photos to other systems.
The 100-300 maybe classed as a consumer grade / beginners lens but I don't care: it was cheap when I got it in about 2013 and it has had pretty heavy use with no visible or optical sign of degradation - zoom is smooth and no wobble. I have had much more expensive lenses not of a 'plasticy' construction which have shown more wear.
Now, its nice to have, still, as a light and compact lens for occasional use on my remaining m43 body.
richard
PS - as an alternative: I wonder how the 40-150 Pro + MC2.0 compares with the 100-300 ? No longer have the former. I suppose that combo is for Oly shooters but with no lens stabilisation I wonder how IBIS copes.
OutsideTheMatrix
OutsideTheMatrix Veteran Member • Posts: 9,876
Re: A myth
The majority of M4/3 lenses hit optimum sharpness at f4 or f5.6.
Of course at 100mm f7.1 or f6.3 is fine.
Actually, f7.1 is ideal, regardless of zoom range used.
It's al about Dof related sharpnesfield and AF point placement.
At f7.1, your equivalent f-stop is f14.2, so depth of field really isn’t (much of) an issue.
When shooting with the 100-300mm, the simplest way to ensure optimum image quality, is to simply set it at f7.1 and leave it there. Adjust shutter speed and ISO accordingly.
If you look at thread after thread in the forum (rotten search engine be damned), you’ll find the same technique recommended over and over. I was skeptical at first, but in real-world use, it proved to be accurate.
with the Oly 75-300 the ideal f stop seems to be f/9.....probably because it's a slower lens than the Panny 100-300.....max f stop at 300mm is f/6.7 on the Oly while it's f/5.6 on the Panny.  On these long zooms it is often recommended that the sweet spot for f stop is 1 stop slower than the max, so f/9 for the 75-300 would be along those lines.
In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist. We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
-Dwight D. Eisenhower, 1961
 OutsideTheMatrix's gear list:OutsideTheMatrix's gear list
Nikon Coolpix P900 Olympus PEN E-PL6 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +9 more
OutsideTheMatrix
Re: A myth
I would though diffraction increases as aperture decreases and pin hole sharpening goes the other way and there is just an optimum point somewhere rather than any specific zone. Also given that the aperture will vary at different focal lengths for the same f number, with a different proportion of total light running over the aperture blades, the actual optimum points expressed in f numbers for such a long zoom lens seems difficult to understand,
well put!  for the Oly 75-300 the common wisdom seems to be that the sweet spot is one stop below max f stop....and since max is f/6.7 at the long end, f/9 would follow that rule, and I did about 64 GB worth of testing and that's what I confirmed.
OutsideTheMatrix
Re: A myth
bclaff wrote:
Eric Nepean wrote:
Consider this:
Bill, I hope you do one for the Oly 75-300 lens.  I did 64 GB worth of testing and found f/9 to be the "sweet spot" at the long end.  It goes along with the general wisdom that the ideal f spot on these long teles is one f stop slower than max (which is f/6.7 on that lens.)
OutsideTheMatrix
Re: A myth
bclaff wrote:
Eric Nepean wrote:
bclaff wrote:
Eric Nepean wrote:
Consider this:
Bill, with telescopes and eyepieces the airy disc is used to collimate and determine optical quality of the instruments being used. Can this be used with camera lenses too to determine their worthiness for astrophotography?  Is that why primes are better for this usage?
OutsideTheMatrix
Re: A myth
But thats a much faster lens than these long teles, where one stop below max aperture is often recommended.  Thats how I got f/9 at 300mm with my 75-300mm lens which is f/6.7 max at the tele end.  I confirmed it after doing about 64 GB worth of testing.....f/9 seemed to produce the most detailed images.
Re: A myth
OutsideTheMatrix wrote:
Bill, I hope you do one for the Oly 75-300 lens. ...
Sure. If I ever locate an appropriate patent.
Re: A myth
I would think so.
There are compromises in the design of a zoom lens that in general make them inferior to a prime. (There are exceptions I'm sure.)
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Re: Nothing wrong with those --->
Wigelii wrote:
AdamT wrote:
Wigelii wrote:
AdamT wrote:
Nothing wrong with those whatsoever for a lens which is a 1st generation design and can be bought for as little as just over £200 secondhand ......
I`ve seen worse examples from the expensive PanaLeica 100-400 (which has a very Polarised reputation)
Is the 100-400 not worth buying?
opinion on whether its worth the money is polarised also whether or not its sharp at 400mm wideopen given that it`s already 1/3 of a stop too slow at F6.3 (even F5,6 is starting into diffraction) and not exactly cheap at £1100
I have no personal opinion on it, I live in the UK where its dull 90% of the time, F2.8 rules here - LOL
Same here in Belgium (that's in Europe 😉)
Is it now?
But I have to disagree; as so-so the weather in Belgium is, my experience of the UK is worse. Beer not as great either but they make it up with the  Scottish whisky...
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
WhiteBeard
Wigelii wrote:
spike29 wrote:
The one with no goverment?
We ,north of you , offer a change to be free and be "brabant zuid" 😂
I think that's a very good idea. Unfortunately there are not so many people in Belgium that like your food and your beer, so I am not sure we'll find enough people in favour😀
And by the way, this country seems to work better without government than with a government. Maybe we just send our politicians your way and we stay independent (well.... servants of France and Germany)
Hum, might be a good idea that.... But then we stay servants - or more so - to Trump Country...
Or you live in the south part then your eh bound to a larger type of Europain country.
WhiteBeard
Carlo11 wrote:
Thanks for quick and positive respons. Havn’t had such a long lens before. Didn’t know What to expect . Glad to Hear There is nothing wrong with The lens. I Will be happy with it now thanks to you all!!!
it’s not The 1st generation, its The mark ii (480 euro’s)
i Will try to shoot raw! GOOD TIP. Havn’t done That before. I Will find Out.... lots of tips on this forum i suppose.
The G85 is oké, but maybe i Will look for a g9. Pinpoint focussing Will be more accurate i think.
one thing i noticed is the Need for relative fast shutter speeds with these subjects. Stabilisation is useless with moving animals. So with low light it can be difficult to get Sharp images.
Yes, technique is everything with this lens. Although the MkII improved the OIS, the weather sealing and autofocus, optically it is the same as the original 100-300 from 2010. So on a good,recent camera, I would suggest shooting at 800 ISO most of the time and F7.1 or F8 at the long end. Notice that your 3rd shot at 800 ISO seems the sharpest...
BTW, your G85 should provide you with pinpoint focusing as my older G3 did that already. And also BTW, I seldom use pin-pont but rather the smaller focusing "box" as it provides more area for the contrast-detect focusing to work on.
WhiteBeard
If you have someone to give you good advice, you will get better results by using raw with a half day training, but that is very very positive thinking. Raw simplifies things, but developing your own workflow takes some time. Also, raw development won't do miracles, but saving the results of careful analysis of lens/shutter speed/ISO combinations makes it quick and easy in the future. In principle, but I think it's also good to understand what's going on with the processing.
I beg to differ. Since I crossed from the 36 exposure 35mm film era to the "all-you-can-eat" digital era, I found that the number of pics I took on any given trip was mind-boggling. Just the classifying and renaming of the pics takes days. If I were to shoot everything in RAW + JPEG, it would take me years of PP per month of travel. Even doing RAW on very specific venues is almost overwhelming and defeats the purpose of having fun with your photography. Now ideally, if I could get back to the time when every shot - out of 36 - counted, then, yeah, I'd be a RAW fan. With 3000 pics?
For static subjects there is no reason to upgrade to G9. G85 is already really good. G9 is better for sure, but it's also larger and heavier and more expensive.
OutsideTheMatrix
Re: A myth
I dont know how to find that either, I was hoping it was in the EXIF info somewhere.
OutsideTheMatrix
kbouk wrote:
I have the same lens, you have to be careful when you have long distances targets , use 280mm rather 300mm and crop after or if you use 300mm close the aperture 1-2 clicks. Do a comparison to see how your lens copy behaves.
No problem at 300mm with open aperture when the target is close enough. From 100-240mm my copy gives very good results wide open. I’m very satisfy with lens performance and I have compare it with more expensive lenses (old 50-200/2.8-3.5 SWD, LEICA 200/2.8 with 1.4X TC)
I like the closing aperture trick (for max resolution too). I find on the Oly 75-300 you need to close it down to f/9 for best results. Have you done tests with the Panny, and what did you find was its best aperture setting at the tele end? What did you need to close it down to to completely remove shadows from the corners? With the 75-300 I needed to go all the way to f/10 to completely remove shadows, but the best resolution was actually at f/9 so I keep it there, getting a slight amount of corner shadowing.
be careful w/ m4/3 lenses. Closing down more than 1 stop seldom works best. (even aside from the reduction of light!)
Central sharpness almost always suffers! And you need every bit of light u can get from a long lens. F7.1 would be the smallest f-stop to use on 100-300, and only at 300mm in good light
unfortunately the Oly 75-300 lens is rather slow and max aperture is only f/6.7 at 300mm, so f/9 ends up being just about 1 stop less.
WhiteBeard
Re: A myth
Ditto! Mine is set at F7.1, 800 ISO, grain be damned !
(unknown member) Senior Member • Posts: 1,452
hence the cheap price. I sold mine.
