100-300 Panasonic not as Sharp as i wanted
Started Jun 10, 2020 | Discussions
rashid7
rashid7 Veteran Member • Posts: 7,011
Re: 100-300 Panasonic not as Sharp as i wanted
rashid7 wrote:
very funny (sarcasm obviously)!
Nice pix Carlo
I honestly thot u were joking. These pictures are definitely sharp, and obviously you got a good copy of the lens.
Let me address some questions that keep popping up.
Obviously everyone has diff standards and priorities. But there is a tremendous amount of wishful thinking here (as everywhere). None of us is immune.
Example: FF vs M4/3. Those of us who love this format are often accused by outsiders of having our heads buried (ostrich-like) in the sand. I have owned more than one FF camera, and i prefer m4/3.
But PLEASE, lets be real about these lenses. After owning 35 m4/3 lenses, this much seems certain:
Olympus small kit lenses are sub-standard... except perhaps for the plastic 40-150.
Oly Pro lenses are superb, but perhaps 'bloated'
Version ii of panasonic lenses offer very little upgrades at all. They are optically the same. I doubt they even have improved front glass coating. Most offer WR... although already there in f2.8 zooms. Several upgrade from Dual IS to Dual IS2 = a very minor dif.! Some offer increased rate of AF 'sampling' to 240x/sec. A few adopt smoother aperture transitions for video.
I did a careful but unscientific comp. of both 100-300 versions. There was absolutely no diff in sharpness (no surprise)! For SAF they were identically quick on my G9. Also on G9, there was no apparent difference in stabilization, even though the ii has dual IS and the i does not!
I almost bought a used 100-400 for $800. But what a pig! There was all kinds of dirt visible in photos, at normal apertures. [This is hard to accomplish, as you can scratch the front of a lens w/ no visible effect!] The zoom action was very stiff. The mount tolerance, {reportedly so tight as to scrape metal off Olympus camera mounting sfc.} was not tight enough on my G9 to inspire confidence. This lens is notorious for being irreparable by Panasonic... at least outside Japan. Early adopters who had problems were reportedly given refurb copies, and if not covered by warranty, at a cost of $1400!
I love my panasonic gear. But I try to tell it like it is. Assuming you don't get a faulty copy     [and I have yet to encounter an unacceptably faulty lens, new or used - w/ the exception of the 100-400 above]  ... there are very few lemons out there. I would say that the original lumix 14-42, and the 45-200 were rather bad. To add insult to injury, both 45-200 and the original 14-140 f4- were 'obese'. The 14-42 and 14-140 were the only Lumix lenses to get a total redesign, making them much smaller while improving sharpness!
All other Mkii versions are not redesigns at all!
Beware some compact lenses. While most f1.7/1.8 primes are more than decent, the 17f2.8 is v. weak. The 2 pancake 14-42 pwr zooms are also weak, esp the Oly.
Now if you are itching to own, say, a 45-200 ... be my guest.  Just don't say i didn't warn you,  ha ha ha
As for the controversial 100-400 ... when i find one of those good used copies for <1k you can count me in (-:
Keep it fun!
davidedric Veteran Member • Posts: 7,339
Carlo11 wrote:
spike29 wrote:
I have the same combo and i discovered that at 250-300mm F7.1 F8 helps to keep up the DoF sharpnes. Diffraction isn't your problem at that focal length so even F9 or good havens god forbit F11.
On horizontal shots of birds on the grass at 300mm you notice the dof limitation the most. I try to keep it f8 as long as i can.( for longer focal length.
the focus i mostly use single box. pin point, the little plus, is less usefull. you can use backbutton focuslock to avoid mis focus due your own wobbling at 300mm.
It's softer at 300mm then 270mm but just a bit.
So 280mm and some feed zoom is better then lazy 300mm. 😋
As shuttertime. In the old day's it was 1/focallength as guideline. The dual IS2 helps to get slower shutterspeeds but not for motionblur as moving leafs or animals.
And indeed with raw you have more wigglespace.
-2EV underexposure for bumping shutterspeed for instance or keeping ISO down.
Manual sharpening and much better auto lens modules in the software.
Mind you that editing RAW is not somthing you learn in a week. Shoot jpeg plus raw so you have a example, a benchmark.
I still do so i can use 1,4x EZ modes and other jpeg depending features in the G80. Just throw the ooc jpegs away after a quick look.
Thanks! So much response to this sample Photo’s! time to learn RAW editing...
jpeg + RAW is a good suggestion. I Wil do that. Will take time to learn. Any tips on an RAW editing programme? ( paid of free)
LIghtroom?
In my opinion DxO PhotoLab gives the best raw conversion of my m4/3 photos.  However, I do think that its PRIME noise reduction, which is excellent, can only be used on raw files.
At the moment I start in PhotoLab, and then pass the resulting file to Lightroom, which I am more proficient with.  However, I'm pretty sure I could get by with just PhotoLab, except perhaps for printing.
 davidedric's gear list:davidedric's gear list
Sony RX100 VII Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic 12-35mm F2.8 +3 more
Wigelii Contributing Member • Posts: 657
Re: Nothing wrong with those --->
spike29 wrote:
The one with no goverment?
We ,north of you , offer a change to be free and be "brabant zuid" 😂
I think that's a very good idea. Unfortunately there are not so many people in Belgium that like your food and your beer, so I am not sure we'll find enough people in favour😀
And by the way, this country seems to work better without government than with a government. Maybe we just send our politicians your way and we stay independent (well.... servants of France and Germany)
Or you live in the south part then your eh bound to a larger type of Europain country.
knowledge is addictive, every time i get some i want more.....
(If i can remember 1/1000 of everything i learned/read in the past i will be happy as a monky with........)
 Wigelii's gear list:Wigelii's gear list
Olympus E-M1 Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus OM-D E-M1X +13 more
meow
meow Veteran Member • Posts: 5,794
I hadn't read
Carlo11 wrote:
for this time no copyright infringement 😏
thanks, i Will try this later on!
Actually, I hadn't read the threads about the changed rules when I snatched your image and made that joke. I saw them later. Just want to say my intention wasn't to challenge the rules, as I realize it may look like. Just assumed it would be OK to modify the image, as it usually is when someone asks for help. I know you are OK with it, but others may think I'm an obstinate b*stard.
Well, I know better now. No harm intended.
 meow's gear list:meow's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Venus Laowa 7.5mm F2 MFT 7artisans 7.5mm F2.8 Fisheye +2 more
AdamT
AdamT Forum Pro • Posts: 62,285
Same here in Belgium (that's in Europe 😉)
I know where Belgium is, that bit inbeween France and the netherlands which speaks both languages and the people sound either french or dutch - and was the only European country who accepted the EURO as currency who were cunning enough not to get ripped off by the conversion demands
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
jeffharris
jeffharris Forum Pro • Posts: 11,409
Carlo11 wrote:
Thanks for quick and positive respons. Havn’t had such a long lens before. Didn’t know What to expect . Glad to Hear There is nothing wrong with The lens. I Will be happy with it now thanks to you all!!!
it’s not The 1st generation, its The mark ii (480 euro’s)
i Will try to shoot raw! GOOD TIP. Havn’t done That before. I Will find Out.... lots of tips on this forum i suppose.
The G85 is oké, but maybe i Will look for a g9. Pinpoint focussing Will be more accurate i think.
Pinpoint focus is slow! Single point, smallest box.
one thing i noticed is the Need for relative fast shutter speeds with these subjects. Stabilisation is useless with moving animals. So with low light it can be difficult to get Sharp images.
Try a monopod. Stick it in your belt of front pocket. Makes a big difference.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
jeffharris
kalisti wrote:
Looks great to me, detail and composition!
Composition? The shots are decent enough, but the subjects all dead center? That’s “composition” for field guides or catalogues.
Keepers, sure, but not very interesting.
Nice shots, and they dont look over sharpened/NR/cropped like most of the shots I see.
kalisti
kalisti Senior Member • Posts: 1,181
you must be having a bad or boring day, I hope things look up for you.
 kalisti's gear list:kalisti's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +3 more
jeffharris
It's a fine day. All is well here.
I wasn't being nasty. An honest critique isn't a bad thing.
Studying composition won't hurt either. 😛
Stizzu68 Regular Member • Posts: 483
Re: Contrast
meow wrote:
You can take it a step further by increasing local contrast. I do this pretty much manually by creating three masks, one for highlights, one for mid tones and one for shadows. Then I use a curve to increase the contrast, i.e. make the light pixels lighter and the dark ones darker, within each tone range with the help of the masks.
Maybe I overdid it a little (it's fun to play with other people's stuff!), but I think the deer got a little more life in her eye. You can see the image looks sharper (contrast = sharpness) and the colors look more vivid.
I haven't touched saturation, sharpness or anything else. Just those two things I've tried to describe.
and the colors looks more vivid.
Your lens looks fine. The main problem with this photo is that the focus point is wrong. Mammals are very difficult subjects for AF, their fur and their color are made to hide between grass or tree
The focus is on the shoulder and not on the head. A good RAW conversion and good post-processing will help to improve the results but you cannot fix problems like this, and you will see it if you print large or view the picture on a big screen.
The depth of files at m43-300mm is shallow. With long focal lenses need some time and exercise to get good and consistent results.
kalisti
OP Carlo11 New Member • Posts: 21
Re: Not as bad as you think they are :)
thanks for your repons. Verv Good tips on technique and equipment and how it is relaxed! Nr.6 : set in for the whites! I’ll try to remmende that. Sometimes there is juist so little time!  And nr.  7 & 8 are to be judget later!
Re: Raw developing
Thanks, next week i have time to check Silkypix!
#2 was focus , no crop, straight Out of the camera. I Will look at the jpeg settings, and check it with your settings  ( fine jpg, NR -5, sharpening was at 0 I)
I get som tips on hand holding technicus. Always good! My experience is that movement of the object is more important. You’ll need 1/250 sec at least, and Then  hand holding technique is not so important anymore. Or am i missing something?
Very fine pictures from you and the former responder! ! A benchmark for me! Very capable lens. You need to be close, i noticed already! 😏
Thanks. I’ll start with  SILKYPIX!
Ha, ha, no joking at all. New in this business. No expectations (no, high expectations😏)
Good to read on these Pany lenses! My 18-35 mi (the only other lens i have ) is very fine! a pleasure to use.
Re: I hadn't read
No offence!  As i said just test pictures for the lens shapness!
Re: Contrast
I do point at the eyes. With little succes (took a lot of pictures of these deers, not one tack sharp in the face/eye). Mostly one-area, AFS
have to practice some more😊
Re: Contrast
Another option is to refine the autofocus manually taking advantage of the in-camera focusing aids.  I haven't found it easy on the 100-300, but worth a try with a static subject.
