jalywol
Not as bad as you think they are :)
As others have said, these are actually fine, with some focusing issues that are a factor in your disappointment.
Now, some advice from someone who has used both versions of the 100-300mm and the 100-400mm, with all sorts of bodies:
1) The 100-300mm II is a pretty good long lens overall, especially given its low price. The current iteration has great OIS, and (IMO) is sharper in general than its predecessor. You do, however, have to work within its limitations, and be very careful to use good holding technique to get the most out of it.
2) Technique matters a lot with long lenses, no matter how good their OIS. The more stable you are when holding them, the better the output.
3) Don't forget the atmosphere....if you are shooting on a warm, humid, day, and you try and capture something far afield, you are going to get a mess. Atmospheric distortion can really rumple the light as it bounces from the subject through the air back to your sensor, and nothing will be sharp.
4) Given 2, and 3 above, the closer you are to your subject, the sharper your results can be,
5) Don't be afraid to sharpen carefully in post processing. My first gen 100-300 gave fairly soft shots straight out of camera, but I used a two step sharpening process that did quite a good job with bringing out the edges without making them look artificial. With the second gen one, I find I do not have to do that, so far at least, and a single sharpen pass, with a local sharpening tool for smaller areas, seems to do the trick.
6) Watch your exposure. Blown whites will tend to increase edge blur AND CA, so make sure you are not overexposing on bright objects.
7) Consider one of the 20MP bodies. The extra resolution and more modern sensor make a big difference when working with long lenses, esp if you want to blow up the photo in PP.
8) Practice on this lens for a while, get your technique together and your post processing in order and only then move on to the 100-400mm. The 100-400mm is a fabulous lens, but it is unforgiving of sloppy technique in a way that the 100-300mm is not. If you just jump to the 100-400mm expecting it to correct all the issues you see with the 100-300mm, you WILL be disappointed, as it will amplify any errors you are making with the 100-300,into worse results. There are quite a few posters on this board who have run into that over time....
9) Keep the ISO down and the speed up....and no need to go above F8 as a rule. If you are all the way out at the long end, I find stopping down just a bit can be helpful (f7.1) rather than shooting wide open. The Mk II seems a bit more forgiving about shooting wide open than the original, though, so you would have to experiment a bit yourself to find what works best for you.
10) Consider not using a filter on the front of the lens. They can do odd things, sometimes, even the good ones....
oh, and last but not least:
11) Shoot RAW and process the shots yourself. Unless you turn the noise reduction in camera down to the lowest level (usually -5), you will get blurry artifacts in all your JPG output from Panasonic cameras.
Here are a couple of shots from the 100-300II on a GX8 from the past few days, for you.
-J
