100-300 Panasonic not as Sharp as i wanted
Started Jun 10, 2020 | Discussions
Carlo11 New Member • Posts: 21
Hallo, First contribution To this site! I have bought The Panasonic 100-300 mii in combination with a G80. Here are Some pictures. It lacks real sharpness in my opinion. I keep Shutter speed fast enough to reduce motion blur. And use AFS and 1-area for focussing. Any thoughts?
F6.3 1/640 iso 640
F8 1/640 iso 400
F7.1 1/2000 iso 800
F11 1/640 iso 2500
Panasonic 100-300mm F4-5.6 II Panasonic G85
AdamT
AdamT Forum Pro • Posts: 62,285
Nothing wrong with those --->
13
Nothing wrong with those whatsoever for a lens which is a 1st generation design and can be bought for as little as just over £200 secondhand ......
I`ve seen worse examples from the expensive PanaLeica 100-400 (which has a very Polarised reputation)
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
kalisti
kalisti Senior Member • Posts: 1,181
Re: 100-300 Panasonic not as Sharp as i wanted
Looks great to me, detail and composition! Nice shots, and they dont look over sharpened/NR/cropped like most of the shots I see.
 kalisti's gear list:kalisti's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +3 more
KenTel
KenTel Senior Member • Posts: 2,567
6
The first one has a lot out of focus due to the dof required with all the foliage surrounding the main subject, which actually is not bad focusing on the bird, the other pics are as good as it gets. I'd be quite happy with them.
Cheers. Ken.
 KenTel's gear list:KenTel's gear list
Fujifilm FinePix Real 3D W1 Panasonic LX100 Panasonic FZ2500 Panasonic G85 Panasonic Lumix DC-S5 +8 more
pannumon Veteran Member • Posts: 4,130
First of all, a very good set of example photos, both artistically, but also regarding the issue. It's nice to answer to these kind of threads.
I think these images are a little bit soft, but OKish. Considering that mammal, it looks quite sharp , but the depth-of-field is not deep enough, and the focus point is not at the head or 'tail' but in between (near front legs; it's well focused and F-value is also good, assuming it was not taken for no pixel-peeping purposes).
With lenses like this, I would recommend shooting raw and tweaking the sharpening parameters, in Lightroom, especially the sharpening diameter. Heavier and more expensive kits can produce sharper images straight out of camera.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
OP Carlo11 New Member • Posts: 21
Thanks for quick and positive respons. Havn’t had such a long lens before. Didn’t know What to expect . Glad to Hear There is nothing wrong with The lens. I Will be happy with it now  thanks to you all!!!
it’s not The 1st generation, its The mark ii (480 euro’s)
i Will try to shoot raw! GOOD TIP. Havn’t done That before. I Will find Out.... lots of tips on this forum i suppose.
The G85 is oké, but maybe i Will look for a g9. Pinpoint focussing Will be more accurate i think.
one thing i noticed is the Need for relative fast shutter speeds with these subjects. Stabilisation is useless with moving animals. So with low light it can be difficult to get Sharp images.
If you have someone to give you good advice, you will get better results by using raw with a half day training, but that is very very positive thinking. Raw simplifies things, but developing your own workflow takes some time. Also, raw development won't do miracles, but saving the results of careful analysis of lens/shutter speed/ISO combinations makes it quick and easy in the future. In principle, but I think it's also good to understand what's going on with the processing.
For static subjects there is no reason to upgrade to G9. G85 is already really good. G9 is better for sure, but it's also larger and heavier and more expensive.
kcdogger Veteran Member • Posts: 4,356
F6.3 1/640 iso 640
F8 1/640 iso 400
F7.1 1/2000 iso 800
F11 1/640 iso 2500
Last three look pretty sharp to me.  Missed focus on the first one (branches futher down from tthe bird look OK
Peace.
John
 kcdogger's gear list:kcdogger's gear list
Olympus Stylus 1 Panasonic ZS100 Sony RX100 VA Panasonic Lumix DC-ZS80 Olympus TG-6 +37 more
OutsideTheMatrix
OutsideTheMatrix Veteran Member • Posts: 9,876
Re: stop down that aperture
hey I love those heron and swan shots!!
Just curious, what aperture do you like to use at the tele end? I have been testing the Oly 75-300 which is very similar and rated about the same.....it is not sharp wide open at the tele end...you should stop the aperture down by one stop, which is what I do with the Oly lens. I did some tests and found f/6.7 and f/7.1 not that good at the tele end.... f/8 is better but f/9 is the best. f/10 is also very good but just below f/9 in sharpness and f/11 is also very good but needs more light. I keep the lens at f/9 by default. what is the best aperture for your lens at the tele end?
also how much do you have to stop down the aperture to get rid of the shadows in the corners?  I find that I need f/10 to get rid of them completely at the tele end, but since I crop I am fine with f/8 and beyond.  When I use the 2x digital teleconverter I find that there are no shadows in the corners even at f/8.  I would never go faster than f/8 with this lens at the tele end.
In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist. We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
-Dwight D. Eisenhower, 1961
 OutsideTheMatrix's gear list:OutsideTheMatrix's gear list
Nikon Coolpix P900 Olympus PEN E-PL6 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +9 more
kbouk
kbouk Regular Member • Posts: 402
I have the same lens, you have to be careful when you have long distances targets , use 280mm rather 300mm and crop after or if you use 300mm close the aperture 1-2 clicks. Do a comparison to see how your lens copy behaves.
No problem at 300mm with open aperture when the target is close enough. From 100-240mm my copy gives very good results wide open. I’m very satisfy with lens performance and I have compare it with more expensive lenses (old 50-200/2.8-3.5 SWD, LEICA 200/2.8 with 1.4X TC)
Cheers
Costas
 kbouk's gear list:kbouk's gear list
Leica Digilux 3 Olympus E-M1 Panasonic Lumix DC-S1R OM-1 Olympus Zuiko Digital 25mm 1:2.8 Pancake +14 more
meow
meow Veteran Member • Posts: 5,794
Dynamic range
I don't have this lens, but am interested in the subject since I myself sometimes find it hard to see when a digital image is sharp enough. So FWIW...
I think the first bird photo is unsharp. The rest of the photos look OK to me.
The two latter bird photos are fine, I think. The photo of the deer is a little dull, but I don't think that's because of lack of sharpness, but because it has low dynamic range. The tones go from black to about 75% gray.
If you expand the dynamic range so it goes from black to white the image lightens up and gets more punch. I hope you don't mind that I borrowed your image to try that.
With expanded dynamic range.
 meow's gear list:meow's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Venus Laowa 7.5mm F2 MFT 7artisans 7.5mm F2.8 Fisheye +2 more
Trolleyman Senior Member • Posts: 1,048
Wildlife photography especially small targets at distance is an expensive hobby .There is a reason the pros use the gear they do, because its required to get consistent results.
I had a dabble a few years ago when I used Canon, gave up because I realised it would take more money and effort than I was able to commit.
If I were to try again on m4/3 reckon I would go with the 300mm or at a pinch the 100-400. I have the 100-300 ii and its ok, nothing more than that. Think you will have to accept its limitations or invest more money for the next step up
 Trolleyman's gear list:Trolleyman's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus 12-100mm F4.0 +3 more
Thanks! I haven’t done Much tests. Here are Some samples shots (almost)  wilde open and with bigger f-stops. I dont see much difference (a good thing😀)
F 5.3
F8
F9
F5.6
Good advice! I Will keep it in mind ( and €€ in the pocket 😏)
Re: Dynamic range
Wow! Thats the right word; dull. I big difference! I’m a jpeg shooter for now, there is Work to do! Thanks for the usefull feedback
meow
Re: Dynamic range
Good! I won't go to jail for copyright infringement then.
JPG is no hindrance for this. Many "dull" looking photos gain by expanding the DR. It doesn't fit all images of course, but provided there should be something all black and something all white in the image, see to it there really is and the photo "lifts".
And even if you don't want the tonality to stretch from 0 to 100, you can nudge it until it looks right to you.
Note: I don't use a mainstream editor. This function is probably called something else than  the self explanatory "Expand Dynamic Range" in your software, but I think most editors should have it.
meow
Contrast
You can take it a step further by increasing local contrast. I do this pretty much manually by creating three masks, one for highlights, one for mid tones and one for shadows. Then I use a curve to increase the contrast, i.e. make the light pixels lighter and the dark ones darker, within each tone range with the help of the masks.
Maybe I overdid it a little (it's fun to play with other people's stuff!), but I think the deer got a little more life in her eye. You can see the image looks sharper (contrast = sharpness) and the colors look more vivid.
I haven't touched saturation, sharpness or anything else. Just those two things I've tried to describe.
and the colors looks more vivid.
joeletx Veteran Member • Posts: 4,125
No need to shoot at F11.0
Because F8.0 is more than adequate for m43 cropped factor is 2. F8.0 is FF F16.0 in term of DOF, and F11.0 is equivalent to F22.0 in DOF. If anything, F8.0 can help you to maintain adequate shutter speed without going to high ISO.
 joeletx's gear list:joeletx's gear list
Olympus E-500 Olympus E-M1 Olympus E-M1 III Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus Zuiko Digital ED 18-180mm 1:3.5-6.3 +10 more
davidedric Veteran Member • Posts: 7,339
I've done quite a bit of wildlife shooting with that combination, and been happy with the results.
Tey look fine to me so far as the lens goes.
 davidedric's gear list:davidedric's gear list
Sony RX100 VII Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic 12-35mm F2.8 +3 more
The first version of the lens was a bit more picky, and really needed to be used at f7.1, IIRC, but the second version seems more forgiving to me
