A couple of x-t200 operational questions
csnite
csnite Regular Member • Posts: 153
I have two questions about the new x-t200 I picked up. First, the camera "processes" and the screen goes black after every shot. Also, it will not allow me to put it in raw+jpg. It only has fine or normal jpg as a selection, with all raw options grayed out. ISO is set to auto 3, so not extended ISO range. It doesn't matter whether I am in M,A, etc.
Any ideas what could be causing this weird behavior? I have read through the manual, and if it is there, I must have missed it.
 csnite's gear list:csnite's gear list
Olympus TG-5 Fujifilm X-T200 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II Fujifilm XC 35mm F2
sirkhann Regular Member • Posts: 330
Re: A couple of x-t200 operational questions
Film simulation bracketing turned on? Look it up under bracketing/drive settings.
csnite
OP csnite Regular Member • Posts: 153
I believe that was the issue. It isn't obvious that the bracketing was on, so I eventually had to reset the shooting menu, which is not ideal, but it fixed it. Thanks.
