X-T100/X-A5 Exposure Compensation in Manual Mode/Auto-ISO?
Started Jun 9, 2020 | Questions
il_alexk Senior Member • Posts: 2,867
Is it possible to do Exposure compensation in Manual Mode with Auto-ISO? X-T1 and X-T2 seems to support it , but on X-T100/X-A5 the EC dial controls the shutter in the Manual mode, there might not be enough dials to do that.
So, Does anyone know if this is possible with X-T100? I guess X-A5 is even less likely to have this.
PS. Let's try avoiding unnecessary debates why Manual mode with Auto-ISO and EC is blasphemy, this topic was already beaten to dust on many forums, and the bottom line is that it is supported by many camera vendors, including Fuji.
Alex
 il_alexk's gear list:il_alexk's gear list
Pentax K-5 IIs Sony a7R III Fujifilm X-A5 Fujifilm X-T100 Pentax smc FA 50mm F1.4 +9 more
Fujifilm X-A5 Fujifilm X-T1 Fujifilm X-T100 Fujifilm X-T2
sshapiro Senior Member • Posts: 1,018
Re: X-T100/X-A5 Exposure Compensation in Manual Mode/Auto-ISO?
Alex
I believe you can configure the leftmost dial for that function. If that dial is currently set to change film simulations, you can move film simulations to the Q menu.
OP il_alexk Senior Member • Posts: 2,867
Yeah, I already checked that with the user manual. The Exposure Compensation mode is not listed as a valid option for button settings.
http://fujifilm-dsc.com/en/manual/x-t100/menu_setup/setup_menu2/index.html#button_setting
Is this something that was added during by a later FW?
Alex
Hold down Disp/Back until the button settings appear. Move to the left dial config and see if you find the exposure compensation as an option. I suggest you update your firmware to the latest version first.
Don't have X-T100 yet, hence my question
Checked on X-A5, latest FW. Exposure Compensation can not be assigned to any button or dial except the default EC dial. In manual mode this dial controls the shutter and I can;t find a way to control EC then.
So do you know if X-T100 supports it?
Alex
I just tried this on my X-T100. I was able to assign EC to the left dial, but iso did not change when I turned the dial. I had the camera in manual mode and iso was set to auto with a max value of 6400. I then switched to a program mode and the left dial did adjust EC by changing the shutter speed. It appears that while you can configure the leftmost dial for EC, it will not change iso when in manual mode with auto iso enabled.
boogisha
boogisha Senior Member • Posts: 2,858
Unrelated to ISO itself changing or not, while in manual mode with EC assigned to that left dial - upon turning the dial, does exposure (compensation value) change...?
From your response I would think not (as you say ISO did not change), but checking in case that ISO change was just _not shown_, where if exposure (compensation) was changed still, then the only thing that _will_ (eventually?) change is ISO (on shutter button half-press, or maybe only once the photo is taken).
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
I moved the dial a significant amount and took multiple photographs. The values in the EVF display did not change. Upon review, each photo showed the same ISO value and I didn't see any obvious change in exposure.
I just tried this on my X-T100. ... It appears that while you can configure the leftmost dial for EC, it will not change iso when in manual mode with auto iso enabled.
Thanks a lot.
My understanding that on other Fujifilm cameras the compensation only happens after you half-press the shutter. So X-T100 behaves differently, right?
Alex
Thanks a lot.
No, the X-T100 shows the updated/actual iso value when you half press the shutter button. For example, if auto iso is 6400 max, the EVF or LCD will display that iso value until the shutter is half pressed, then the iso value changes to indicate the actual iso.
Thanks a lot for your help and answer. I still want X-T100's sensor over X-T20 despite extra weight, size and stupid omission of extra features.
Alex
boogisha
Understood, mentioning ISO not changing got me thinking, as seeing EC not working (in EVF or on LCD) should be enough to signal the assigned dial EC function not working in the first place (and no exposure compensation change further means no ISO change, either, but in that specific order).
Thanks for confirming.
