IR photography with in-camera processing
Started Jun 8, 2020 | Discussions
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Last week there was a post by AlmostDoctor regarding handheld IR photography using cameras with IBIS. Since I have an IR720 filter, I gave it a try.
https://www.dpreview.com/forums/thread/4492445#forum-post-63994574
Taken with my Panny 20mm f1.7 and my EP5.
I captured the white balance for the IR shots and in-camera processed the resulting photos into B&W with my custom B&W Custom Mode.
I think they turned out quite good.
These sets are from the same raw. The first one is using my custom preset and the second is where I tweaked the preset.
With this one, I set the camera to the Dramatic Art Filter and took the image with the IR filter in place. I then processed the resulting jpeg file which gives a Dramatic Tone IR image.
1st one is the embedded jpeg, the 2nd is processed from the raw file and the 3rd one is processed from the resulting jpeg – interesting effect.
So, what do you think?
Allan
Olympus PEN E-P5
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
Re: IR photography with in-camera processing
Hi Allen, I think the results are "interesting".
Using an IR filter in front of an unmodified camera is sort of like driving a car on a freezing day with heaters on full blast and windows down...
But, it's also good to give you an idea of the potential you get with a camera that has it's IR cut filter removed. Over the years, I find myself going back to IR regularly, and if you do too, consider modifying a camera, perhaps an older one you don't use as much (like I have done with my first MFT cam, an Oly E-PM2).
Quick example from this past weekend.
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
AlmostDoctor Senior Member • Posts: 1,257
I like it. Granted, I too know very little about IR photography so I'm not sure if my opinion counts very much but isn't fun?
I'm planning on taking my IR filter for all my future travels. I'm not committed enough to take an IR converted camera, but I have a room for a filter in my camera bag and it gets good enough results for my needs.
 AlmostDoctor's gear list:AlmostDoctor's gear list
Panasonic Lumix DMC-GM1 Olympus PEN-F OM-1 Panasonic 20mm F1.7 II Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
