Canon 1000D Reduced Raw File Size
Started Jun 8, 2020 | Discussions
kd6vm Regular Member • Posts: 408
I have recently been playing with my older Canon XS/1000D and have been shooting in Raw+jpeg. Although the jpeg pictures are the correct size (3888 x 2592), the Raw picture size is only 1936 x 1288 in some picture viewers, such as Irfanview, but is normal in DPP.
Is that normal for an older Canon Raw format?
 kd6vm's gear list:kd6vm's gear list
Canon PowerShot SX40 HS Canon EOS 1000D Canon EOS 60D Canon EOS 77D Canon EOS RP +11 more
Canon EOS 1000D (EOS Rebel XS / Kiss F Digital)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Canon 1000D Reduced Raw File Size
kd6vm wrote:
I have recently been playing with my older Canon XS/1000D and have been shooting in Raw+jpeg. Although the jpeg pictures are the correct size (3888 x 2592), the Raw picture size is only 1936 x 1288 - about half of what the manual says it should be. This also happens when I shoot in Raw only.
The Raw file size is about 10 mb, what would be expected, but the display size is half of what would be expected.
Not normal. 1936 x 1288 is the S (small) jpg size. RAW is always the full 3888 x 2592. Some bodies have smaller sized M-RAW and S-RAW choices, but not the XS/1000D. You're sure it's the xxxxx.CR2 file that has 1936 x 1288 size?
How are you viewing the RAW files? Perhaps your RAW software is defaulting to processing/displaying the full RAW file as 1936 x 1288 output?
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
benjilafouine Veteran Member • Posts: 3,875
The best way to know is to use DPP from Canon. Some “free” software doesn’t allow saving in full res. Or, I just looked at my 7D setup. I see that there are some choices for RAW file sizes (along with jpeg): full RAW, mRAW and sRAW. Make sure in your menus that you are using the full raw. I’ve seen resets not resetting everything.
There is always something to shoot/snap, you just have to know how to do it and have the right gear.
Benji
 benjilafouine's gear list:benjilafouine's gear list
Canon PowerShot S5 IS Canon PowerShot SX110 IS Panasonic Lumix DMC-FZ35 Canon PowerShot G16 Canon EOS 40D +12 more
OP kd6vm Regular Member • Posts: 408
The files do show full size and resolution in DPP.  The free Irfanview, even though it has a plug-in for Canon raw, displays the file at half size.  Irfanview displays the correct size for raw files from my 60D and 77D.
I guess the plug-in just doesn't work for the older Canon raw.
Could be, I use irfanview but usually, it is only for a quick view. But it is possible that the EXIF info on a raw file is wrong. I assume you have the very latest version of irfanview and plugins.
Benji
It is not only the exif data that shows the smaller resolution, but the picture itself displays at half size.
I have a recent version of Irfanview, but maybe not the latest.
