Next "more pro" Pen - EP5 design flash or evr
Started Jun 7, 2020 | Polls
(unknown member) Forum Pro • Posts: 47,805
Henry mentioned here
https://www.dpreview.com/forums/post/64000498
he would like to see an E-P6 in the vein of the Ep5, with an EVF that extends.
I like his idea, was wondering if in the name of keeping small you could pick only EVF or Flash (look where the flash is on EP5 and that's where the EVF would be stored/pop up), what would you prefer?
POLL
EP5 design just like EP5 was, but modern innards. This design has no built in EVF, but has built in flash. I *prefer built in Flash over EVF*.
15.8% 6  votes
EP5 design with POP up EVF where the Flash goes, pack the EM5MKIII/PenF small flash with the camera. No built in flash. *I prefer built in EVF over Flash.*
28.9% 11  votes
EP5? No, I want a PenF Mark II designed as the Pen F currently is (this means EVF and no built in Flash).
23.7% 9  votes
I honestly don't care.
31.6% 12  votes
  Show results
Olympus PEN E-P5
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: Next "more pro" Pen - EP5 design flash or evr
What I want is an Ep6 with the same* body as the ep5 with a pop-up EVF on the left. Weather sealed with the newer processing engine and IBIS.
I wonder if it would be possible to have both an EVF and pop-up flash if the flash popped up vertically - as in "giving the finger"
Since they already have (or should have) the tooling for the EP5 body, it should be cheaper to make it for an EP6.
* Exactly the same, no plastic crap.
Allan
OP (unknown member) Forum Pro • Posts: 47,805
Allan
I would imagine doing built in flash and EVF would be challenging. But maybe they could just do a non pop-up fixed flash a-la Fuji X100 series, but only guarantee it works with the small primes.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
3dwag
3dwag Veteran Member • Posts: 4,674
Allan
Yes, Ricardo, what Allan said except with your comments about a small fixed flash more likely being doable.
But such an “EP6” would be moving into “Pen F Mark II” territory, so I’d just say to the Olympus designers “頑張れ” and hope they come up with a jewel as close as humanly possible to having those features in a form factor with design queues like the original film Pen F:
I’d be a goner for sure with such a camera, after my wife notices that I haVe one!
-Dennis W.
Austin, Texas
¯\_|’_’|_/¯
http://www.pbase.com/3dwag/image/97156660.jpg
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
3dwag
Strange new rumor?
Allan
After the above subthread which ventured into both Pen F Mark II and E-P6 wishing territory, a little later I see this rumor suggesting that both new Pen cameras are coming: https://www.43rumors.com/ft2-too-good-to-be-true-two-pen-f-coming-in-late-2020-i-doubt-so/
However, I should point out that it is only an FT1 rumor, and personally if it were my site I wouldn’t even print it, as it appears to be the sort of anonymous message to the site guru that anyone could write just because it’s something they would like to see, with absolutely no real world basis whatsoever.
(And NO, I did NOT author the rumor!)
-Dennis W.
Austin, Texas
¯\_|’_’|_/¯
-Dennis W.
Austin, Texas
¯\_|’_’|_/¯
Henry Richardson Forum Pro • Posts: 21,959
Some new thoughts about E-P6
I added some more thoughts to my thread:
Using left eye for viewfinder
https://www.dpreview.com/forums/post/64018704
And here is an idea for having both a pop-up EVF and flash:
Both pop-up EVF and flash together
https://www.dpreview.com/forums/post/64020865
Henry Richardson
http://www.bakubo.com
3dwag
Re: Some new thoughts about E-P6
Pop-up EVF and flash together a good idea to consider.
I started to mention the possibility of combining EVF with flash in a pop-up in my first reply above, but then I started thinking - would I rather have that (combined pop-up EVF + flash)? Or, would I rather have a fixed in-body flash with a flash shoe above it (I don’t think there is room for a combined pop-up + a hot shoe).
One other possible challenge...shielding the plastic EVF housing (and the flash compartment well enough that the light from the flash doesn’t leak through the plastic materials into the viewfinder section...needs to be safe and also not annoying.
Just hope we see some worthwhile new Pens somewhat along these lines by sometime late 2020 or early 2021.
Henry Richardson
-Dennis W.
Austin, Texas
¯\_|’_’|_/¯
Yes, I would like to see an E-P6, PEN-FII, GX7IV, and GX8II.  No idea whether they will ever appear though.
Henry Richardson
Cornflake7 Regular Member • Posts: 257
No matter what will be released ppl on forum will moan about "old tech inside".
Yes, some will. Personally, I am pretty satisfied with the tech, but there are often ergonomic mistakes, firmware bugs, usability issues, etc. that bother me.
Henry Richardson
april fox Contributing Member • Posts: 862
Or complain like this poster that the camera maker didn't make the camera to fit their personal needs. Even worse than that they never consulted the poster when developing the camera
robgendreau Forum Pro • Posts: 10,931
I'd be happy with an add-on EVF and/or add-on flash. Like the PL up through the 8. Kind of hard to find a viewfinder now, as they aren't made, but really helps in bright light and some other situations. And then in the pocket when not needed.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
