Does anyone know what type USB plug Oly E-M10 Mk II uses?
Started 6 months ago | Questions
Michael Meissner
Michael Meissner Forum Pro • Posts: 26,897
Re: .._. _...
JacquesC wrote:
..._ _.__ __. .._ _..
Though I'm not sure what FBUYGUD means. I never learned morse, but I used an internet Morse Code Translator and that is what '.._. _... ..._ _.__ __. .._ _..' translates to.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus E-5 Olympus OM-D E-M5 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus 14-150 F4-5.6 II +22 more
jfiresto Junior Member • Posts: 46
Re: Does anyone know what type USB plug Oly E-M10 Mk II uses?
Michael Meissner wrote:
Peter 1745 wrote:
Perhaps the Arduino should borrow from the days of Royal Navy battleships, where the command was "Shoot". "Fire" was reserved for reporting a conflagration, often as a consequence of enemy shells hitting the ship.
Since "fire" is what I use, and I wrote the sketch for my own amusement, fire is what I use. As I said, it is easily changed in the source.
I saw "steampunk" in your post and thought the device might have a wider audience. (My sister attends steampunk cons.)
-John
 jfiresto's gear list:jfiresto's gear list
Olympus PEN E-PL1 Olympus PEN E-PL3 Olympus E-PL7
Michael Meissner
-John
It is a sketch that I wrote for my steampunk camera that has been evolving over the last 8 years or so.  I wrote the app, but never really used it.
Here is a picture of the current large version of the camera:
Steampunk camera
The idea is to have representation of things in a modern cell phone camera.
  • In this case, the camera is E-m5 mark I
  • Lens is classic 4/3rds 14-54mm mark II + MMF-3 adapter
  • The two squirrels (Livinea & Nutzo) are an artist and photographer couple
  • The dragon (Snap) is the lookout
  • The angry birds and ballista are for playing games
  • The octopus (Madeline Pomphrey III or MP3) does music
  • The beaver (Eva) does math with a slide rule and has a sextant for location
  • The raccoon (Racky) has a telegraph key and tool box
  • The rubber duck (Dr. quackenstien) is a mad scientist.
In this case, the telegraph key is not hooked up, but I could add the Teensy to re-enable the setup.
cvhmanchester New Member • Posts: 7
E-M5 II + Capture + Arduino + PC. How?
Thank you for your recent input.
I am running my E-M5 II from a PC with a Python program issuing commands to an Arduino running GRBL.  At the appropriate event, the Arduino sends a focus then a shutter command using relays to ground the appropriate USB wires on a cannibalised manual remote shutter lead.
However, I should like to use the excellent Olympus Capture software to set up then monitor the process - which means splitting the lead between the Arduino and the PC outputs.  So I asked Olympus customer service (normally very helpful) which connectors do what on their USB camera socket.  But they would not tell me because it is not "normal" camera use, except that dpreview has a lot of normal people like me.  Can anyone advise?
An alternative solution would be to use the Python program or the Arduino in order to trigger Capture and issue a focus-shutter command through the intact USB lead.  Is there a way to hack Capture?
 cvhmanchester's gear list:cvhmanchester's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro
Re: E-M5 II + Capture + Arduino + PC. How?
Perhaps you could control Olympus Capture on the Windows(?) PC with a Python GUI automation library, for example, pywinauto, and do everything in software.
techie takes pics Senior Member • Posts: 1,162
Set your camera to wifi.
Use a laptop to connect to the wifi of the camera.
Open a browser and navigate to:
http://192.168.0.10/get_commandlist.cgi
Now you get a commandlist.
You can retrieve images.
Browse to http://192.168.0.10/get_imglist.cgi?DIR=/DCIM , or try
http://192.168.0.10/get_screennail.cgi?DIR=/DCIM/100OLYMP/<filename>.ORF
It also has commands to operate focus and shutter.
 techie takes pics's gear list:techie takes pics's gear list
Olympus PEN E-PL1 Olympus OM-D E-M10 II Olympus E-M5 III Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus 12-40mm F2.8 Pro +4 more
