PowerShot or EOS? Quadriplegic user
Started Jun 5, 2020 | Discussions
Ian_abaco
Ian_abaco Regular Member • Posts: 127
Hi there,
I am a nature photographer and have had my canon power shot for about 8 years. I upload my photos to a print on demand site that prints my images on different products. One product that I tried to print says the image needs to be 82500 x 6415. My current camera width is only 4200 width so my thought is I need to upgrade. But as I began looking at cameras I'm realizing a camera that can produce 82500 x 6415 may not be in my price range. But I'm still thinking a upgrade would be good.
I'm looking at the Canon PowerShot SX420 ( https://www.bhphotovideo.com/c/product/1210599-REG/canon_1068c001_powershot_sx420_is_digital.html ) as it's built similar to my current camera. I have hand function limitations as I'm a quadriplegic so can only really use one good hand, so I can't handle every camera.
I am also interested in the Canon EOS M100 ( https://www.bhphotovideo.com/c/product/1358090-REG/canon_2210c011_eos_m100_mirrorless_digital.html ) as a friend mentioned mirroless to me. Would this camera take better quality photos than the first one? Does the zoom work the same as far as just pushing the lever with my finger the same as the point and shoot? I appreciate your recommendations and if you think there would be a better choice for me please let me know.
Thank you. Sincerely, Ian
Canon EOS M100 Canon PowerShot SX420 IS
Swerky Contributing Member • Posts: 793
Re: PowerShot or EOS? Quadriplegic user
Ian_abaco wrote:
Hi there,
Hi. Interchangeable Lens Cameras won't give you the option to zoom using a lever with the same hand you're holding the camera. When it comes to Canon, only PowerShot cameras will give you that option. There are some models that would give you better image quality thanks to their larger sensors. Such as the G5X Mark II, G7X Mark III and G1X Mark III.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
Ian_abaco
OP Ian_abaco Regular Member • Posts: 127
I jut looked up the gx 5 mark 2, not in my price range today. Does the eos zoom by just turning the lens? Wondering if I could brace the camera against my body and zoom with my good hand???
RLight Senior Member • Posts: 4,426
Zoom lever will not work with the EOS M100, or any of the EOSM series.
However, they do have the wonderful 22 and 32 prime lenses... Those are wicked sharp and 22mm on a crop is 35mm FF which is the perfect "street" lens.
Depends what you want. If you plan to zoom though, Powershot.
If you want ultimate image quality, and 35mm works for you, M100 + EF-M 22mm f/2 STM is a vicious combo.
Both the M100 + 22 and a G series powershot should be on your (short) list. Comes down to reach though.
If you're not sure, Powershot is the safer bet.
I'm a former EOS M user and current PowerShot user. My gut says it depends on what kind of output you want.
Edit: Saw your price range.
What model do you have now? Gives me a feel of what you expect, what works, and if/what you should bother with...
 RLight's gear list:RLight's gear list
Canon EOS M6 II Canon EOS R3 Canon EOS R50 Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
I guess it will depend on you. You can try that with a friend's camera if available. Or check the G7X Mark II as it might suit your budget. As for the m100,  f you wouldn't mind using it with only a prime lens and thus getting rid of zooming, you'll have to see if you can find it body only and buy a separate prime lens. Or look on the used market. The m100 will give you even better results than any PowerShot camera.
Ian_abaco
Right now I think I have the sx 20. The zoom is very important as my wheelchair limits how close I can get to certain places. I photograph lots of flowers and outdoor scenes including beaches and woodsy parks. Quality is important but zoom just as much. I think any upgrade from 8 years ago will be an improvement. What do you think of the first one I posted? $200 looks nice to me but is there a similar camera with more pixels? I doubt it but thought I'd ask. Thank you.
Ian_abaco
That's the main reason I'm looking at it, better results. But zoom is needed so I have to weigh my options. Perhaps I can test one at best buy.
Hmmm. This is a tough one.
The SX30-50 doesn't give you much.
The SX60 gives you a 16MP BSI, but at nearly $400
The SX70 gives you 20MP BSI, but once again around $400.
You might want to have a peek at used copies of the Panasonic Lumix FZ1000 or PowerShot G3X
https://www.cpricewatch.com/product/05817/Canon-PowerShot-G3-X-price.html
$484 is a good price (used) for the G3X. EVF not included though.
$419 used for like new on the FZ1000 is a good gig if you're willing to look outside Canon.
A $200 budget for a bridge camera is a unique problem.
Truthfully, not a lot has changed with image quality on "bridge cameras" unless you go 1" ala the FZ1000 or G3X. The SX70 is definitely a "level up" with the 20MP BSI sensor, but at nearly $500? Ouch. You can do half the reach but more than double the image quality with the FZ1000 or G3X but half the reach. However, it's on par with the reach you have now I believe.
Tough.
Ian_abaco
$200 isn't y max just thought that was a good deal. I'd say $400 might be my max. I feel safer buying things like cameras new.
Ian_abaco
I'm looking at mirroles cameras on bet buy with retractable lenses. What does that mean? To me it looks like they might zoom similar to powershot.
It's not a power zoom... Means it retracts, with your help, so it's out.
I personally would be really stoked if they made a mirrorless with a retracting lens, be good for video application.
What about refurbished?
Ian_abaco
best buy has open boxed items that are pretty decent priced. Do mirroless camera have the best image quality in general? And are there any downsides to that type of camera?
I2K4
I2K4 Senior Member • Posts: 1,441
If I had to replace one of my antique Powershots I'd be at least looking at the Panasonics, e.g. the Lumix FZ1000 currently reviewed here.  Canon bridge cams still seem to lead in out of camera jPEG processing and the user interface / menu, but the optics, a 1" sensor and fast lens for all that zoom, and better screen and EVF could tip the scale to Panasonic.  Can't say about ergonomics for a disability.
Mirrorless will be small, light, and powerful (good image quality), but for your ergonomics? I wouldn't. You probably should stick to a point and shoot, but a powerful one.
Let me ask you this...
What focal lengths do you shoot at most? What do you shoot most? What do you want to shoot but can't? I gather this started with your printing pictures but has morphed into a greater desire to upgrade an 8 year old camera. Ironically both much has changed, and, not much at all in that time frame.
I in your shoes, I'd have a hard-hard look at the PowerShot G3X and Panasonic FZ1000... They both carry the Sony 1" BSI sensor which will give you a huge lift in image quality, and bump you to 20MP.
An important differentiator; do you do much video? And, do you do any RAW edits/post processing?
Also, touchscreen use. The FZ1000 (mark I, which is around $400 used) lacks touchscreen. The G3X, has a touchscreen. How do you feel about touchscreens? That can be a deal breaker for the Panasonic. Likewise if it's not, I don't want to say the FZ1000 is just a better camera (the mark I) than the G3X, but well, it is?
I think for someone like you, the fine details are really going to matter so I'd do your homework and try to hunt one down in store to play with (the G3X and FZ1000)
Ian_abaco
Not sure of the length but I usually am a short distance away from the subject and zoom all the way in if it's a subject like a flower. I like some landscape style shooting as well. If you look at https://abacoian.threadless.com/ it will give you a small sample of what I shoot. Not even close to everything I shoot but it might give you an idea. You are correct, my initial reason has turned into a desire to upgrade:) I think a new camera would make my images better. The canon you mentioned is a bit high for me and the other one at $500 might be possible if I knew it would work for me and be worth the extra few hundred in image quality. Right now I'm wishing I could afford a great mirroless but leaning toward a powershot. But not decided yet.
tkbslc Forum Pro • Posts: 17,522
Ian_abaco wrote:
Hi there,
I am not sure if this is a typo, but there are not any cameras that can make an image that large. It would be 529 Megapixels, and an extremely long panorama photo. 12:1 aspect ratio.
Even if you added an extra zero and it is 8250x6415, that's 52MP, which is very uncommon. Was this a wall sized print or something?
As for cameras, what are your priorities? Do you need long zoom?
Could you use a tripod? Or, I am assuming you are in a wheelchair, would it be possible to mount the camera to the chair? If your camera is on a tripod or some other mount, then you are free to operate the buttons with your one hand without having to worry about holding it, too.
I2K4
On your use case and in that $500 range I'd think about the Panasonic FZ300 . Same caveats about JPEG rendering (I'd mainly shoot RAW with it) and menu friendliness, and a typical bridge cam small sensor. But the brilliant thing is f/2.8 for the full telephoto length, that means fast shutter (handheld) regardless of zoom e.g. indoors. I often think of that in the greenhouse lighting of Allen Gardens Conservatory here in Toronto. The way apertures slam shut on zoom is the biggest problem with zoomers, unless you fancy ISO noise.  A 600 mm telephoto isn't to sneeze at except for birders, and I recall from long exchanges here years ago that it supports lens extenders and filters if wanted.
Ian_abaco
Yes I wonder if the print on demand site is giving me an error but it says it every time. It's for custom leggings.
Ian_abaco
With the use of my good hand I've found it's best to use a camera I can handle, I think a mount on my chair would get in my way.
requa
requa Contributing Member • Posts: 860
Don't overlook the possibility of a refurbished model direct from Canon. I've bought several pieces of gear this way and never been disappointed. Right now, you could get a refurbished G7 X Mark II for $399, if the last model version does what you need.
https://shop.usa.canon.com/shop/en/catalog/powershot-g7-x-mark-ii-refurbished
 requa's gear list:requa's gear list
Olympus Stylus Tough TG-870 Canon G5 X II
