A Landscape comparison of the iPhone with Canon APS-C and FF
Started Jun 3, 2020 | Photos
Iron Mike
MOD Iron Mike Contributing Member • Posts: 540
(at the request of Benji)
Intro and Image set 1
I got a new iPhone 11 (the pro model with 3 cameras) a week or 2 ago and I wanted to take some test images with it to compare with my current DSLR (5DIV) as well as my older 7D. Unfortunately my old Rebel XS is locked away in my office at work and I don’t have access to it at the moment, but my 7D has an APS-C sensor that is similar in image performance to the T2i-T5i rebels that came after it.
In particular I was interested in how the Phone cameras handled tonality, dynamic range, as well as rendering of fine details (I shoot mostly landscape/travel as well as portraits these days). I wanted to assess both the raw performance (using dng raw file captures out of LR mobile) as well as the default camera of the phone with it’s hyped up computational photography. For the various scenes I captured I’m presenting the default phone camera image as-is untouched (except conversion of heic to jpg). The raw files from the two DSLRs are processed and converted with either Lightroom Classic or ACR (via Bridge) and are left at their default resolution (expect more detail from the DSLRs proportional to their MP count). The DSLR’s were tripod mounted and I used manual exposure settings to optimize the capture and try to maintain highlight detail. All shots are at base ISO (100 for DSLR and 32 for the iPhone)
In this first series of images i captured a small scene in my garden of a Hosta, concrete owl figure, coloured glass bottles, grey cards, and my hand (for skin tones) in open shade. In all cases the camera was focused on the owl.
This first image is the raw image (daylight balanced) from the 5D (16-35 f/4L) to show the basic scene for reference.
Next, I processed the image using just the WB, exposure sliders, basic sharpening, CA removal and colour correction with the HSL sliders to taste. I find the the default greens in Lightroom area bit weak and shifted a bit into yellow spectrum and usually require some correction in most of my shots. Skin tones are pleasant, good detail and no noise in the shadows as I would expect.
The image from the 7D with the same lens and processed similarly to above. I’m shooting at a wider angle on lens due to the crop factor. The camera held up quite well, but I am starting to see a bit of banding and noise on the grey card (minimized by masking the sharpening in Lightroom). This is one of the issues that annoyed me about my 7D, I can sometimes get banding that is difficult to remove (Nik/Google/DxO DeFine helped remove it), even at base iso with processing. Blue sky often showed noise even at ISO100 as well. The default rendering in lightroom is pleasantly saturated in the greens (good for landscape) but a bit too much in the oranges (and shifted a bit red as well). When doing portraits with the 7D I had to do a lot of skin tone adjustments.
The raw image from the standard wide angle lens of the iPhone11, surprised me and looks quite nice. Fine detail is good, and the colours are nice, but did require a bit of fussing with the WB and HSL sliders to get them where I was happy. There was apparent noise in the grey card even at the base ISO32, but it was easily masked out retaining nice detail through the rest of the image. I would be quite happy with this image if I had only brought my phone with me.
The default iPhone camera is next. To be honest it’s not that great… it’s been over processed, most of the fine detail lost due to noise reduction and has a lot of highlight compression (white card is almost the same shade as the grey card). Overall it just looks like a “cell phone” image, similar to what I would have gotten from my old iPhone6. I was rarely happy with my phone as a camera in the past, usually wishing I had brought my DSLR instead.
I think the iPhone camera is promising as an alternative to my DSLR, as long as I remember to use LR to capture a raw image for later processing as home (at least for this low contrast scene). I won’t get as much resolution for printing, but small prints and web presentation will be fine with the phone's camera.
I’ll follow up this post with 2 more series of images taken at the riverside to show more dynamic range comparisons.
Comment & critique:
Iron Mike
OP MOD Iron Mike Contributing Member • Posts: 540
Image set 2
Image set 2
I went for a small hike on Monday and brought my gear with me to do further testing. This next series of images includes both highly shaded areas as well as some sky and clouds to test the useful dynamic range of the sensors. I avoided doing any HDR bracketing for the raw captures (instead choosing an exposure to just avoid clipping in the white clouds). The iPhone default cam used HDR algorithms by default.
This is the raw capture of the 5D of the scene (with default LR tone curve, daylight WB and default sharpening) for comparison.
I processed the 5D image to taste, using all of the tools available in ACR to adjust the colour and tonality throughout the image.
I repeated the same process with the 7D (which is unfortunately zoomed in a bit too much, missing a bunch of the sky and clouds). I was surprised how well the 7D did here, noise in the shadows looks ok and the sky recovered fine. Masking the sharpening helped keep the blue sky tones to a low noise level. The river shadows are not bad as well.
The iPhone wide angle lens (26mm equivalent) when captured in raw is struggling a bit more in this image. To bring the shadows up to a similar level introduces a fair bit of noise that has to be aggressively removed with NR in ACR.
The default iPhone camera applies an HDR algorithm that does a great job, with clean shadows, but has a lot of compression in the highlights. The clouds in the sky look good, and the sky brightness is ok (although the tone is off slightly). The bright sunlit foliage is ok, but is a bit mushy because of the highlight compression, where the processed dng shows a greater range of tones. I think the phone did well for itself here. I would be curious to do a manual HDR bracket set with the LR raw dng capture to see how well i could improve the results.
Iron Mike
Image set 3
Image set 3
In this final set of test shots I took a series of images of the river near a pedestrian footbridge. I used some longer focal lengths to match the tele (52mm) lens on the iPhone. The exposures were chosen to try and avoid clipping the highlights in the sunlit foliage.
This is the raw capture of the scene with the 5D (with default LR tone curve, daylight WB and default sharpening) for comparison.
The 7D image looks similar here, although the greens and oranges are quite punchy again (I desaturated them a bit for this shot). There is a bit of shadow noise again but it’s pretty good actually.
The raw capture from LR mobile looks similar in overall tonality, but has a lot more shadow noise and is not very sharp in the corners on the left side. I would greatly prefer either DSLR here, but at small sizes it's ok.
The default iPhone cam capture has good overall tonality, but a bit too much highlight compression (sunlit trees) compared to the raw processing. Left corners are still very soft (tele lens is not great, but should be fine for portraits), but the noise is better with the HDR processing.
Iron Mike
Conclusion and a Final image
Conclusion and a Final Image
Overall I think that the iPhone 11 standard wide camera has a lot of potential especially for scenes with a lower DR (and raw capture) or those with a wide DR and the default camera. I would still like to take a look at manually capturing and converting a HDR bracket set of dng’s made with Lightroom. I’m not going to get rid of my 5DIV anytime soon, especially for larger prints and telephoto images, but the phone may be “good enough” for an everyday carry-arround. The iPhone 11 ultra-wide camera quality is even worse in the corners than the telephoto unfortunately, and doesn’t support dng output.
I was also surprised by how well the 7D stood up. Banding and noise even at base iso, oversaturated oranges and a wonky autofocus system led me to abandon the camera for the 5DIV, but there are work-arounds with careful processing for the IQ issues and it still takes nice photographs (I couldn’t get past the autofocus problems though).
I’d be happy to hear your thoughts on these comparisons.
I’ll leave you with a final image I took of the last scene with the 5D, attaching an ND filter to blur the water and applying some further processing in Photoshop CC to add a bit of Orton glow to the trees behind the bridge, and clone out some distractions.
Mike
cdmazoff
cdmazoff Senior Member • Posts: 2,826
Re: Conclusion and a Final image
Wow!!!! Thanks for doing this!!!!  I still don't know how to put one person on hold on my phone to answer another incoming!!
https://www.flickr.com/photos/cdmazoff/
When I'm not playing birds, I'm shooting my accordion....or is it the other way around?
 cdmazoff's gear list:cdmazoff's gear list
Canon EOS 90D Canon Extender EF 1.4x III Canon EF 100-400mm F4.5-5.6L IS II
Iron Mike
No worries, to be honest I don't think I know how to do that either...
benjilafouine Veteran Member • Posts: 3,875
Re: Some comments and a few questions.
Thanks Mike. Great analysis. Using the grey card was a great idea. I’m still looking for mine that is somewhere in a box following the selling of my Montreal house... In the absence of a grey card I have been using Mother Nature as a reference (like snow for example).
Comments
My experimentation was a bit like yours, meaning that I started using Lightroom to take pictures in the DNG format Along with the built-in app. Unfortunately, Lightroom doesn’t support the ultra wide camera in the DNG (RAW) format. I usually use the standard wide lens more than often and since I have the basic iPhone 11 (not Pro), I do not have the telephoto extra lens, not that it bothers me because I don’t seem to be missing it unless I need some serious reach (then I use my 7D). Actually, I was not even supposed to buy a new iPhone but when my mom’s iPhone 6 battery started acting up, I decided to give her my iPhone 7 equipped with a brand new battery and get a new one. I was not even expecting getting better pictures! For me, smartphone pictures were just... well... smartphone pictures...
Most of the time, the default app on the iPhone is adequate and it’s true that sometimes, it has a tendency to over saturate colors. When that happens, I use the Lightroom app to take the shot. However, Lightroom doesn’t support Live Photo’s and in a few instances, Live Photo’s saved my day due to motion blur (my dog running). I just selected another key frame. I could always set my 7D in burst mode and keep the shutter pressed but then the sorting becomes tedious.
In another instance, the iPhone was way off As you pointed out. I tried to take a landscape picture with large trees where the sky was showing on a overcast day and the iPhone app completely missed the shot as it misinterpreted tree leaves and skies. I had to use the Lightroom app to get the shot correctly. So I’m not surprised that it missed a shot with you grey card. I suspect that the ground was clearer than the iPhone expected (just like my overcast day).
Also, I don’t know if this is your first iPhone, but it is my sixth one (first one was a 3GS) and I can tell you that this latest one showed the most dramatic improvement. My iPhone 7 was telling me when it was using HDR but this new one doesn’t. I guess HDR and image stacking are now essential components of the default iPhone photo app. In some instances with the iPhone 7, I would ignore the HDR photo as it was more than often less good than the standard one (highlights were too extreme). However, I must point out again that this iPhone is a huge improvement over previous models.
You are talking about noise and banding with your original 7D. I must say that I have never experimented banding with my copy of the 7D. However, yes, noise is an issue as soon as I raise the ISO. Under 400 it is usually OK, between 400 and 1600 it is acceptable and above 1600, it is really a last resort thing. Also, my copy of the 7D seems to be plagued by a slight underexposure issue. For several years, I have been systematically using the bracketing function and from time to time, I am using these images or bump a bit the exposure of the “default shot”. That could explain blown out skies. Maybe the lens as well.
You are referring to print sizes in your comparison. In my case, printing is really not important. The only uses I have for my pictures are for myself, here on DPReview and for Facebook friends. Also, I am rarely printing, usually no more than 9x12 and my printer is 10 years old (a 13x19 Epson printer that is as outdated as my cameras).
For my tests, I used my 7D and my G16. Wish I had the 5DIV. Anyone can see my work here but just uploading it is a big task for me as I am stuck with a 1 mbps upload speed and a 5 mbps download speed. This means that when I get home and I add the pictures to my iPad (Lightroom, Photos or Pixelmator), I must take a one hour break before 10 photos are uploaded to my iCloud Drive and distributed across all my devices! I do have an older Windows Server here but manually transferring files remains tedious. Just transferring the DNG files to my local setup is complicated enough.
Questions
First things first, I do not have opportunities to go on trips and get too far of the house because my wife is disabled for the rest of her life and requires constant care and since this pandemic started, I am also sheltering my 85 years old mom from Montreal. Basically, the only photo opportunities I have are on the water on the Sea-Doo and the latter is very incompatible with my 7D (forget the telephoto lenses, by the time I assemble them and if I’m lucky to not drop it in the water, wildlife is long gone...). For that reason, along with the iPhone, I am carrying the Powershot G16 just in case I need some minimalistic telephoto reach. I also have plenty of woods and mountains around here and nothing in terms of organized parks (we do have one 30 minutes from my place but you are not authorized to get out of the car which limits very much the capability of taking wildlife pictures). In my testing, I used both my 7D and my Powershot G16 (both in RAW mode). So here are my questions.
1. Were your DSLRs on a tripod at all times?
2. Was your iPhone on a tripod as well? I bought an iPhone tripod bracket that is very useful for night shots. I discovered today that I could manually push the exposure to 10 seconds using the built-in phone photo app but I haven’t tested it yet. My experience is that where I needed a tripod for my 7D and my G16, I can get away handheld with the iPhone. I am sure this is affecting a bit the level of details of these pictures since we know that the iPhone 11 is stacking/combining photos in its post processing routine.
3. Do you think that the iPhone 11 is a dramatic improvement over previous iterations of the iPhone? For me it is. I can now fit a camera in the small compartment of my Sea-Doo.
My conclusion
1. The original 7D is showing its age and aside from its AFMA function, I never really fell for it. I still like to use my original 350D and my 40D was also doing the job. Number of pixels is not very important for me. I have printed 3 MP photos at 9x12 successfully with older Powershots in 2003.
2. The iPhone 11 is beating my iPhone 7 in every way. And I am barely scratching the surface about the Night Mode, the Pano mode and the Portrait mode in one single device. If I could afford to spend money on just anything, I would sure get a new DSLR camera just to see the improvements but that won’t happen anytime soon.
3. You mentioned that it would be nice to try doing a manual HDR photo using the 5DIV or the 7D. I thought of that too but now I am getting it in an instant. I believe that what we’re seeing here is the dawn of computational photography and that in the years to come, there will be dramatic improvements of this technology. I often make the analogy with automobiles: the next generation (our grand children although I have none, not even children, long story...) after us will probably not know gasoline engines and being required to actually drive 100% of the time.
4. Unless you want to do professional photography or need some action shots and telephoto shots, yes you could now get away with an iPhone. I have a friend of mine who never bought a camera in the past 12 years. She’s been using iPhones for 12 years for her family shots. Of course, she was amazed at the time when I dropped in with a DSLR but now with the iPhone 11, I am sure she is perfectly happy. But truly, maybe she will be one day missing a perfect family portrait on the wall. Fortunately, the iPhone can now achieve that if you stay within a printing size of 11x17 maximum.
5. I have decided to embrace this new “computational photography” technology and as crazy as it might sound today, I strongly believe that it is part of our future. I’m happy that we’re finally talking about it.
I really appreciate the time you’ve spent on this comparison. It is currently out of my reach.
There is always something to shoot/snap, you just have to know how to do it and have the right gear.
Benji
 benjilafouine's gear list:benjilafouine's gear list
Canon PowerShot S5 IS Canon PowerShot SX110 IS Panasonic Lumix DMC-FZ35 Canon PowerShot G16 Canon EOS 40D +12 more
Funny. You’re a dinosaur!!!!
Benji
Re: Addendum
I sure do understand that I will not take these shots with an iPhone (sorry for the low res).
Benji
Iron Mike
Addressing the comments and a couple more snaps
I had mentioned in the first set of images that I was curious about skin tones for portraits, but forgot to bring it up again. I have a version of the iPhone11 Lightroom dng conversion with my hand in it that I didn't post. The raw files processed Lightroom do well for skin tones (at least better than the 7D), as seen below.
Comments
I had an iPhone 6 before this, and it was more obvious when it was using the HDR. I think that the camera on the 11 is definitely an improvement over the 6, but still has a ways to go before it's any sort of replacement for my DSLR.
I don't remember the banding from when I first started using the 7D but it definitely became a headache for me towards the end of my time with it. I'll post a shot below where I included the sky, and after bringing the exposure down the banding is very obvious even at ISO100 (look at the sky at 100% for vertical lines). I almost never shot the camera above ISO400, even ISO800 was getting too noisy for my tastes.
The banding can be removed by careful use of software such as the NIK Define 2, but would have a strange effect on the edges that needed to be masked out in photoshop and I haven't updated it since google sold it to DXO. I'm just glad to be done with all that.
I've been making some 16x20 prints lately on a Canon PRO-1000, and the increased resolution of the 5DIV is appreciated.
Questions
Yes, all DSLR shots were taken on a tripod.
I've been looking for a bracket for the phone, but don't have one yet. At ISO32 and the lens at f/1.8, the shutter speed of the phone was reasonably high and I wasn't too worried about shake. I had the phone braced against the tripod just incase. I'm not put out by the level of detail the phone creates (relative to it's MP count) especially in the raw shots, although the default cam seems to go a bit overboard with the noise reduction / HDR algorithm. I guess there could be some camera shake, but I don't se any directional blur in the images.
Yes, it's clearly better than the iPhone6, especially when I can take control of the exposure parameters in Lightroom and the DR of the scene isn't too extreme. The smart HDR in bright light is OK. Having a bit more reach with the telephoto (actually NORMAL 52mm) lens is a welcome addition.
My conclusion
I've done a bunch of manual HDR on both the 7D and some on the 5D. I rarely need to do that anymore because the 5D files are generally good enough to get the data I need in one snap. I often use luminosity masking in PS these days as well instead of HDR, if I have to bracket exposures.
I was actually curious about taking bracketed exposures on the iPhone using raw files in Lightroom mobile and then combining them back in Lightroom Classic to get an HDR file with more control. But, honestly, if I'm out with a tripod I probably would have my DSLR with me anyways and just use that.
There were a couple of occasions when hiking in the mountains this past summer where I wanted to grab some shots along the trail and this phone would have come in handy. I couldn't really pull out my DSLR from the pack, and the iPhone6 shots I took at the time were just OK. I think the 11 will work nicely when out canoeing this year as well.
This biggest limitation for me actually will continue to be portraits. I like to use off camera flashes for my portraits, and that will continue to be much easier with the DSLR.
I probably still have some more testing I'd like to do, comparing the iPhone to the DSLRs in low light conditions.
No worries, thanks for reading and providing your comments.
Best Regards,
Mike
Re: Addressing the comments and a couple more snaps
Comments
Questions
My conclusion
Best Regards,
Mike
This is the bracket I purchased.
Ailun Phone Holder Tripod Mount Adapter Rotatable Digtal Camera Bracket Selfie Monopod Adjustable Clamp Compatible with Galaxy S10 S10plus S9 S9plus S8 S7 S6 and More Black https://www.amazon.ca/dp/B072KNBV21/ref=cm_sw_r_cp_api_i_QMo2EbDP4G7V4
Benji
