EOS 750D Dummy Battery issues (or low battery indicator)
Started Jun 2, 2020 | Photos
Howardvk New Member • Posts: 2
Hey all
I have the Canon 750D, I'm shooting long videos and needed a Dummy battery for it, so I got this one: https://www.amazon.co.uk/gp/product/B07C1GQR65/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
It works BUT
The low battery indicator is always flashing (which shows up on the video)
Anyone know how to stop it showing?
I'm thinking either there's a setting to stop it flashing on the camera OR there's an issue with the power I'm putting into the dummy battery
Love any help as driving me buts
Comment & critique:
Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
Aoi Usagi Veteran Member • Posts: 3,221
Re: EOS 750D Dummy Battery issues (or low battery indicator)
Are you using a USB adapter/battery that has enough power?
It says:
"USB Power Input: 5V, 2A-4A (at Least 2A Current,Up to 4A if needed)"
Ray UK Contributing Member • Posts: 977
Usually USB 2 sockets are limted to 0.5A and USB 3 are 0.9A so you probably wouldn't get enough power if you are using your laptop or PC sockets.
OP Howardvk New Member • Posts: 2
Hmm ok - thanks.
Any suggestions what I should do?
If there any way to turn OFF the battery low indicator?
Or is there a different Dummy Battery I should use that you guys use that doesn't have this issue?
You cannot turn off the low battery indicator, it is there as a warning.
You ideal way is to use a mains powered dummy battery.
If you need to be mobile then use a rechargeable power bank with a USB output socket, although you do need to make sure that it has a high current output as some power banks are quite low current.
