Darktable, Windows Build and Needs Old NX Photos
Started May 30, 2020 | Discussions
ttbek Veteran Member • Posts: 4,869
Darktable now has a windows build:
https://discuss.pixls.us/t/darktable-for-windows/4966
That's probably old news to most of you by now. That link is old, they aren't on merely 2.4 anymore, get the latest at the usual source: https://www.darktable.org/install/
What I actually want to draw attention to is that they need photos: https://discuss.pixls.us/t/raw-samples-wanted/5420
They don't call out specifically NX photos (low demand probably), but if we want to keep good support in Darktable for older NX cameras, they could use the samples https://raw.pixls.us/?missing#repo Checking the list at the bottom, they could use samples for:
Samsung NX5
Samsung NX10
Samsung NX11
Samsung NX1100
Samsung NX20
Samsung NX2000
I don't think their SRW formats are much different, but just in case. They describe what sort they need, no people, etc... please read and send them what they need to keep supporting these cameras.
Non-NX Samsung Cameras they could also use samples from:
Samsung EK-GN120
Samsung S85
Samsung WB550
Unfortunately I don't have any of these models.  For anyone that does, let's help them help us... or at least have less of an excuse not to right ^_^.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Samsung HZ15W (WB550) Samsung NX10 Samsung NX11 Samsung NX1100 Samsung NX20 Samsung NX2000 Samsung NX5 Samsung S85
kypfer Contributing Member • Posts: 985
Re: Darktable, Windows Build and Needs Old NX Photos
This software seems to have ground to a halt two or three years ago. Doesn't seem to have been any updates since 2017.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Huh? Regular updates and a major one here https://m.dpreview.com/news/1259748478/darktable-3-0-released-with-new-features-bug-fixes-and-major-gui-update
Edit - FWIW I have been using it regularly for over a decade IIRC, certainly for everything NX since I bought NX1000.
OP ttbek Veteran Member • Posts: 4,869
I'm going to echo Otto.  3.0, a major release, was just last December... which is not 2-3 years ago.  Lots of improvements, they're in the link Otto gave.  I don't really get where you're coming from as the project is active even adding features not just in support mode.
Sorry, must have clicked on the wrong link ... it doesn't appear to be available for 32bit Windows anyway, so nothing lost
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
I just own the 2 newest NXers so I can't assist
I never knew about this gem for Windows, so I installed it, thank you
Read on if interested...
I use DXO Photolab as my RAW editor; provides DXOMARK's Body/Lens Database for RAW auto-correction. Interestingly though, no 10mm f/3.5 Fisheye.
Darktable's Body/Lens Correction is limited [for this niche feature] BUT look what I found on the first row below.
A quick review, no new Samsung Lenses e.g. 16-50 S f/2-2.8, big brother 50-150 S f/2.8, and older 18mm-200 Movie Pro.
I found this on the Darktable Feature Page:
https://www.darktable.org/about/features/
"lens defect correction using lensfun"
"What gets us into trouble is not what we don't know. It's what we know for sure that just ain't so." -Mark Twain
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
"lens defect correction using lensfun"--
Yep, they use the lensfun database, so taking the appropriate imageset and other calibration info and submitting it to lensfun will get your lens added. Kind of an involved process though. Here is a how to of sorts: https://pixls.us/articles/create-lens-calibration-data-for-lensfun/
Lawrence Norman
Great read, thank you, and we know Darktable pulls from:
https://github.com/lensfun/lensfun
Looking at my Photolab installation, each Body/Lens data file resides in a .caf file (I doubt it's Apple's 'Core Audio Format"). Used a few tools to open a .caf file and learned more
