Is it a good camera? Yes it is. It's a specialized camera though. And, unlike a cooled, tubular CCD camera designed to plug into a telescope via a computer, you can use this camera all by itself (no computer required on site) to capture amazing evening landscapes with wide lenses... or you can mount it to long lenses and telescopes for superb imaging of the night sky. The fully articulated LCD screen means you can shoot close to the ground or attached to a tracking mount (EQ mount). For wider FOV lenses, this ought to produce great shots. For deep space imaging, I think that the examples available online elsewhere show the capability of this camera and there's a few videos on YouTube worth a look. But I'm reviewing this camera with Wide lens sampling... And I don't need to cover all the unnecessary extras I'll probably never use... like 4K video and face-tracking while shooting the night sky. It's an overpowered 30MP version of the well loved 60Da DSLR, only the Ra is both Full Frame and Mirrorless. This means more light hitting the larger cells on the larger FF sensor... and no mirror-slap vibration. Perfect for Astro work.
The Canon EOS Ra (Astrophotograpy model) camera was announced and released in late 2019 with no fanfare. I missed it myself until I saw a reference to it on a Canon website. It was so under appreciated that I had to remind DPreview that it needed to be added to the camera database over a year later. They still have '2018' as the launch date at the time of my review. (((Come on guys!?))) It was announced in November 2019 and was shipped from December 2019. https://canon.ca/en/About-Canon/News/Press-Releases/Press-Releases-2019/2019-NOV-05-EOS-RA-ASTROPHOTOGRAPHY-MIRRORLESS
What makes the EOS Ra different from the EOS R?
Not much. It's a FULLY functioning EOS R with just two notable differences:
(1) A Factory Modified Full-Frame IR Cutoff Filter/Sensor (sensitivity enhanced).
(2) A 30x Magnification in place of the 10x Magnification.
That's essentially it. And for this privilege, you pay a lot more to buy it. In fact, the modded sensor means less use of the other features. You wouldn't dare shoot a wedding with it unless you're known for sepia or creative shots. Canon does NOT recommend this camera for "regular terrestrial photography" although it certainly can be used for this purpose if you don't mind tweaking the color cast on some of your images. This is Canon's FIRST Full Frame Astrophotography camera. The previous models include the EOS 60Da and the EOS 20Da... both of which were APS-C.
The EOS Ra is unique in that the Infra Red (IR) filter layer on the sensor of the regular EOS R has been removed, which enables it to capture light in the night sky that is too faint for most ordinary (unmodified) camera sensors to detect. According to Canon, it is 4x more sensitive to the light emitted by the red 656.3 nanometer Hydrogen Alpha channels - commonly produced by Red Nebulae. The result is that this camera enhances the red tones that are often difficult to captures with ordinary cameras. Coupled with a reasonably large pixel size of 5.36 microns, this camera promises to capture plenty of light and produces low noise at higher ISO settings due to the sensor well-size combined with the number of megapixels on the 30MP sensor.
I occasionally shoot astro and I was interested in a camera like this for use with wide lenses and with telescopes on tracking mounts for longer exposures. There are two schools of thought for those delving into buying a modified camera: Buy an all-inclusive camera with a modded sensor or purchase a 'CCD camera tube' (for telescopes) with internal cooling that can't be used without a telescope and a computer... and isn't suitable for terrestrial photography. An even cheaper consideration would be to buy an EOS RP, toss out the warranty, and get the sensor modified by a company that specializes in this service - (something that is not currently available to me). Your unmodified camera can still capture the night sky... but you'll be stacking images and spending long nights trying to capture the light that the EOS Ra can see in far less exposure times.
EOS Ra with optional (and unnecessary) BG-E22 Battery Grip attached.
Do you need the Canon BG-E22 Extended Battery Grip?
Not at all. In fact, considering the price, you ought to avoid it unless you have to spend a long night powered up. The BG-E22 is more expensive than most of the other Canon grips I've owned. Yes, the EOS R is a smaller camera and having a grip extender gives you more surface area to grip. And yes, everyone with an EOS R recommends buying it. But with the EOS Ra, you may want to cut down on the weight and bulk - unless you are using a motorized EQ Mount for tracking the sky - just in case you need more weight to counterbalance the mount. Some have resorted to sticking a large camera flash on their camera just to add more weight. In that case, buy one. The Canon LP-E6N battery is tough and reliable and is supplied with the camera. It never hurts to carry a spare. But save that money and pass on the BG-E22 unless you really feel you need it. I really needed it.
Using the EOS Ra for terrestrial (non-Astrophotography) applications.
Canon says it's not suitable for non-astro use. They're absolutely right although that doesn't mean it can't be used at all. I took a walk with the EOS RP during late afternoon in light that I expected to be problematic. The colors were slightly warmer and over-saturated with odd yellow and reds that needed tweaking after downloading. The effect of some shots was a little like looking at images printed in color in a 1960s magazine. They were slightly exaggerated in hue and tone in SOME cases. I've taken images with CPL filters that looked the same. Not all shots needed editing. In fact some were more accurate in color and tonal range than my iPhone was capturing at the time. But around 85% needed attention. Indoor shots were better. Though the shot of my cat below generated brown-red cat beds in the distance that ought to have been blue-grey. Reducing the red/yellow hue in the image corrected it just fine.
The amazing EVF on the EOS Ra produces a very strong Cyan color that was not reflected by the real life scene, nor the subsequent images from the camera. Looking through the Viewfinder (EVF) was a little surreal outside in bright daylight but it was close enough to the actual colors. The LCD screen depicted pretty much exactly what I could see with my eyes. Yet the LCD was a little overboosted with Blue/Cyan. No idea why since the LCD produced more natural tones. Sky shots with pale blue hues were slightly peculiar... slightly over saturated with a very subtle "film look" that demanded attention later after downloading them. Clouds had a slight yellow hue in the white highlights that needed attention in some, but not all, images. I found it very simple to tweak these colors in Lightroom and Photoshop but I'm yet to take pictures of people with this camera. It tracked faces on my television when the lens was pointed in that direction and skin tones from the television were accurately captured. Inanimate objects were fine and the camera operates the same as a normal EOS R in every respect otherwise. I might consider the next incarnation of the R or RP for a future FF camera for normal shooting conditions.
EOS Ra + EF 24mm f/1.4L II USM lens - Image has been color corrected. Shot in JPEG.
EOS Ra + EF 24mm f/1.4L II USM lens - Image has not been edited. Shot in JPEG
Setting Up the Ra for Astro for the First Time...
Below, you can see the EOS Ra set up with an inexpensive USB powered lens heater from Protage and an inexpensive 5Volt 1Amp Power Bank hanging below the tripod in a small camera bag. (Don't use higher 2Amp+ outputs with these things or they'll bake your lens and melt it). This kept my lens from fogging/icing up as dew formed in the night air. Temperature was around 7C. Unlike the EOS M6 camera, the touchscreen on the EOS Ra remained VERY responsive regardless of the low temperature. I never needed to press it more than once to trigger an immediate reaction. This screen is as responsive as an iPhone touch screen and is a pleasure to work with. I used the 2 second built-in timer to reduce any shake when taking images.
I had a prediction of "mostly clear skies" last night, despite the rain. So I drove to the mountains to get away from the light pollution and waited all of 2 minutes for the moon to set. The sky was exceptionally clear although the bright center of the Milky Way (Galactic Core) was still rising from the horizon. Setting up the camera was simple enough. Others have noted that you need to turn off the Eye Sensor or your hand will trigger the EVF and turn off the LCD each time you pass it near the screen. This occurred about 10 times until I dug through the menu and deactivated this sensor. Now the camera uses the LCD when the device is switched on - and the Eyepiece when the LCD is in the closed/stowed position. Responsiveness and menu ergonomics are simply excellent.
EOS R + EF 24mm f/1.4L II USM lens - with lens warmer attached to lens. (taken with EOS M6)
The 30x Magnification.
This is a great addition to the camera and one that makes manual focus much easier. There was still plenty of thermal movement and grain in the Live View at 30x magnification but it was easy to tell if images were in focus or not. The richly detailed LCD enabled greater ability to see color, sharpness and detail when reviewing images. It would be nice if Canon added the 10x option as a firmware update as it seems odd for them to eliminate this function from the EOS Ra.
LCD Display.
People forget that the LCD is a very important aspect of enjoying any camera. The screen on the EOS Ra is a fully articulated one that can be folded down to protect itself or extended in any direction as required. With 2,100,000 dots on the LCD screen, you get a high definition view and you can't really see the individual pixels. It's bright and clean and seems to reject fingerprints fairly well. Whilst you won't use the EVF for astro work, it's very wide and smooth with no flicker... giving the impression you're using an optical viewfinder. Zooming in on one of my shots I could see the stars were out of focus just after I removed a NiSi Natural Night Filter after taking the first few shots (see violet image below). I would likely not have noticed this on my other camera LCDs. Refocusing took 4 seconds of my time. 30x magnification is ideal for Astro.
Vignetting with this lens (Canon EF 24mm f/1.4L II USM lens) ...
Canon suggest that the EOS Ra camera offers a lot more choice for terrestrial landscape photography using "true" wider lenses on this camera for wide coverage. I had also been assured by Canon that my EF 24mm f/1.4L II USM lens would work fine with the EOS R camera via the optional EOS R Control Ring Mount Adapter. This was not entirely accurate because it vignetted regardless of the Lens Correction applied in-camera. As you can see from the first image below, Vignetting occurred in all my astro shots but none of my terrestrial images (above). I could crop the images but this was "hard vignetting" and not simply correctable Light Falloff. Yes there's a very thin filter on my lens in the first image but on any of my DSLRs this lens only very barely vignettes. It's certainly correctable on my other astro camera, the EOS 6D.
I contacted Canon today to see what their thoughts were. They replied that the distance between the lens and sensor due to the Mount Adapter was likely the reason for the vignetting. That's obviously part of the problem although I'm not sure it should be happening at all. At the very least, you would think that it would have been addressed during the design of the EOS R. It happens with wide APS-C lenses from other makers too. I believe it is known to happen with two RF lenses, including the highly praised RF 50mm f/1.2L lens... which seems odd. Before taking the camera out last night to take these pictures, I took 22 pictures at home and on the street with this same lens at f/1.4 and only one showed vignetting in one corner. The images above showing my cat and a plant weren't cropped and they were taken at f/1.4 ... I can't quite explain why it was so bold with astro shots. But there's several options at hand... One solution is to internally crop the images using the in-camera 1.6x crop setting in the camera menu. My own solution was to simply crop the images manually after downloading them. I don't expect this issue to occur with longer lenses, especially with smaller apertures and longer focal lengths.
EOS Ra + EF 24mm f/1.4L II lens + NiSi Natural Night Filter (note excessive vignetting).
A White Balance of 4300 Kelvin was used. Image has NOT been cropped). The violet hue is from the use of the NiSi filter. Shot in JPEG
Image Quality
The image quality (sans any vignetting) is excellent. The faint increases in sensitivity to non-nebulous areas of the Milky Way saw greater illumination and backlighting, which in turn revealed far more detail in the dust lanes. You can imagine what the results will be like when you add higher magnification with a tracking mount (EQ Powered Mount) to a camera like this. Ignore the coma in the corners of this lens (which is typical of the lens).
The noise from the averaged-out pixels on the sensor was remarkably low and grain was smoother than I expected. It was certainly less prone to noise, grain and stuck pixels The images I have posted here haven't been edited beyond a crop, and show what is coming out of the camera.
SETTINGS:
* I shoot JPEG . All of these images were shot in JPEG (not RAW).
* I selected the 'Fine Detail' setting from the User Defined Settings for use with the EOS Ra camera for all shot.
Sensitivity
The EOS Ra was as sensitive as advertised. I was able to capture AirGlow in shots (not really shown here due to the '10x image max' request) which I haven't been able to do before. Since this was around 11pm and more than 6 hours after sunset, it is a form of chemiluminescence associated with oxygen molecules which creates a subtle green glow in the air. It was subtle in the images I took because, like an Aurora, the presentation isn't always particularly bold. I haven't posted an example of it here but it was interesting to see that this camera was capable of detecting it and my other unmodified camera could not. However, I've seen glimpses of it with non-modded cameras.
Images of the Great Nebula in Carina showed a pink-crimson structure with bolder and more dominant colors than usually seen with other cameras. Aiming at the Galactic Core (aka The Bulge) of the Milky Way, I could see more detail in the dust trails than usual. Nebulous areas on either side of the Great Rift were distinctly more visible. The Lagoon Nebula (M8) and Swan Nebula were notably more saturated. The region around Rho Ophiuchi (where the bright orange-yellow star Antares is located) showed amber light reflecting off a nearby dust-lane called the Bernard 44 Dark Nebula strand. I could even see some blue light radiating from the Rho Ophiuchi region itself and that was good to see in such a compressed image from a wide lens. The coma towards the edges of the images is typical of this lens on a Full Frame camera with a wide FOV. I note that the RF 35mm f/1.8 IS STM lens produces even stronger coma, making it unsuitable for astro if you're a stickler for sharp stars. I really look forward to using longer lenses with this camera on an EQ tracking mount.
LCD Display on the EOS R
The flip-LCD on the camera showed the twinkling stars in any and every direction. Aiming towards the coalsack nebula (visible in the first image below), I could easily see the brighter glowing areas around the Carina Nebula on the LCD screen. They were faint compared to the Galactic Core. Scroll down and you can see the LIVE VIEW on the LCD screen (this isn't a play-back image) showing even color and detail on the screen.
EOS Ra + EF 24mm f/1.4L II USM lens - I didn't think to focus on the foreground because I assumed the landscape would be silhouetted. Note the Large Magellanic Cloud (Dwarf Galaxy) in frame as well as the bright crimson Carina Nebula (Great Nebula in Carina)..Auto White Balance used. Lower portion of the image was edited to conceal washed out (illuminated) grass from a passing car. This is three vertical images automatically stitched together in Photoshop with no editing or enhancements other than the correction. Airglow and light pollution from distant city lights (from Sydney) are visible. Shot in JPEG
EOS Ra + EF 24mm f/1.4L II USM lens. The Galactic Core of the Milky Way. (Straight from the camera without editing.
*The image has been cropped to eliminate vignetting and resized for posting). Brightness on the lower half is from light pollution from the city of Sydney. Shot in JPEG.
EOS Ra + EF 24mm f/1.4L II USM lens. No edits. Only cropped to remove vignetted corners.Shot in JPEG. Two possums got into a fight in the dark behind me and scared the heck out of me as I was taking this photograph. Misses a massive meteor as the shutter closed.
A Live View of the Milky Way on the LCD display PRIOR to taking a photograph with the EOS Ra camera. I was rather surprised by this and it made photographing the night sky a pleasure.
Afterthoughts... What I LIKED about the Ra:
If you would like to own a Full Frame mirrorless modified camera and would prefer your warranty intact, this is the camera for you. Canon could possibly have stripped out most of the other features (eg eye tracking, video, histograms etc) and sold this camera - at a lower price and a different model name. It produces smooth images of the night sky with surprisingly low noise and offers a sensitive sensor that can show you the Milky Way on the LCD screen in real time. You can attach an intervalometer if you want to use exotic BULB exposures. You can also use a "dumb remote" that costs a lot less and set the time with your watch. Celestron is making Astrograph telescopes for Full Frame cameras now and you can capture some great images using a regular telescope. The argument that there's no backlit buttons on an astro camera is negated by the LCD and surface design of the camera because I found it easier to navigate the buttons in the dark on the Ra in Day 1 compared to my other cameras I've owned for years. Seeing the Milky Way on the LCD with traces of color was useful and VERY welcome (see last image above).
Battery life was superb. Button placement is good. The EVF is large, bright and smooth. The LCD is highly responsive & nicely detailed for playback ...and the 30x magnification was very much appreciated. The EOS Ra is an impressive camera - Just like the EOS R that spawned it. The Canon menu is easy to navigate and the physical build of the camera is user-friendly and ergonomic. The weather sealing is assuring... especially with moisture and dew in the air at night. Expandable ISO runs from 50 to 102,400. Shutter Speeds run from 30 seconds to 1/8000 sec... useful for daylight and Solar photography (NEVER point at the sun without suitable protection for your sensor). At just 660 grams (without optional grips or lenses) it's lightweight. It also has a rated lifespan of over 200,000 shutter actuations. And that protective curtain comes down to protect the sensor when changing or removing lenses... which is unique and welcome in the camera world. So many positives. I was not frustrated by any aspect of use and enjoyed shooting with it enough to want an unmodded R. I had no use for the touch-bar or Control Ring on my lens adapter mount (as yet).
Negatives:
* Menu had hidden features that I needed to consult the User manual to find.
* No volume control (beyond ON/OFF) for the camera function 'Beep'. (???)
* Bold Corner Vignetting on my EF 24mm f/1.4L II USM lens.
None of those negatives should deter you from buying this camera. This model is a mild luxury for those who want to explore the universe a little further.
