Imperial vs metric size for grub screws
Started May 28, 2020 | Questions
il_alexk Senior Member • Posts: 2,867
Need to buy a tiny pointy grub screw, something like in the picture to replace a lost one.
I measured it to be 2.7-2.8mm in diameter, roughly 3mm length. Metric screws come in M2.5 and M3, so I wonder if there is an imperial size that matches that thread better or if I shall go with M3.
Alex
 il_alexk's gear list:il_alexk's gear list
Pentax K-5 IIs Sony a7R III Fujifilm X-A5 Fujifilm X-T100 Pentax smc FA 50mm F1.4 +9 more
craig66 Senior Member • Posts: 1,484
Re: Imperial vs metric size for grub screws
Where did the part with the screw come from? If it was manufactured outside the US, it is almost certainly M3. I just measured the OD of some M3 screws with a micrometer: 2.85 - 2.9mm.
 craig66's gear list:craig66's gear list
Sony a77 II Sony DT 55-300mm F4.5-5.6 SAM Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 500mm F4.5 EX DG HSM +10 more
OP il_alexk Senior Member • Posts: 2,867
Thanks, It's from China. I'll try M3 then
Alex
