Direct comparison: X-T2 16-55 vs X-A7 15-45 - f5.6 landscape
Started May 27, 2020 | Discussions
Ian387 Forum Member • Posts: 50
8
There's a new X-A7 in the house and I was curious how well it may perform against the X-T2, given all the talk about X-trans vs Bayer, brick vs pancake and so on.
Here I've taken the same scene at 35mm and f5.6 and processed the raws in Capture One 20 to match each other. First, the shots so people can first draw their own conclusions:
X-T2
X-A7
Given the difference in price, size and weight, at the typical landscape 5.6 aperture the difference to my eyes is much smaller than I would have expected. The centre seems very similar, the A7 15-45 is perhaps a tiny bit sharper on the bottom left, while the T-2 16-55 is sharper on the right side. Zoom out to any kind of normal distance and I doubt it would be obvious which was which.
Now, I love my X-T2 and 16-55 and won't be giving it up, but it shows Fuji continues to punch above its weight at the budget end (and quite literally too - we're talking total body+lens weights of 1162g vs 445g here!).
Other notes: I used the Capture One Film Standard profile for both, since the film simulations seem to be unavailable for the X-A7. I used auto white balance and before processing the X-A7 defaulted much, much cooler than the X-T2. Before processing the X-T2 underexposed by a third of a stop (which I've always noticed and so it proved here too - perhaps protecting the highlights for the pros?)
Anyway, take from it what you will - your eyes may vary!
 Ian387's gear list:Ian387's gear list
Fujifilm X-T2 Fujifilm XF 23mm F1.4 R Fujifilm 16-55mm F2.8R LM WR Fujifilm 50-230mm II Fujifilm XF 35mm F2 R WR
Fujifilm 15-45mm F3.5-5.6 OIS PZ Fujifilm 16-55mm F2.8R LM WR Fujifilm X-A7 Fujifilm X-T2 Sony a7
pifilos Regular Member • Posts: 343
Re: Direct comparison: X-T2 16-55 vs X-A7 15-45 - f5.6 landscape
They are close to my amateur eyes although one thing. Is it just me or anyone else can notice that the left side is more clean for X-A7 and the right side for the X-T2 ?
 pifilos's gear list:pifilos's gear list
Fujifilm X-T2 Fujifilm X-T20 Fujifilm 50-230mm II Fujifilm XF 10-24mm F4 R OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
debo Senior Member • Posts: 2,944
Nice ... thx
I have good luck with a T100 + 15-45 that I bought for my kid to start photog and was surprised by the quality of the combo. Add a 50-230 and it becomes an awesome travel cam!
 debo's gear list:debo's gear list
Fujifilm GFX 50R Fujifilm GFX 100S Fujifilm GF 63mm F2.8 Fujifilm GF 110mm F2 Fujifilm GF 23mm F4 +4 more
chapada Regular Member • Posts: 275
Difference in the corners is visible even without pixel peeping. Most lenses work fine in the center. I don't think your photo shows anything and isn't a great test. Here's a photo I took with the Sony 16-50mm, which is regarded as one of the least sharp Sony APS-C lenses and I could put this next to my 16-55 and wouldn't see much of a difference at first.
 chapada's gear list:chapada's gear list
Fujifilm X-T3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR
maltmoose Veteran Member • Posts: 3,050
Good work. I'm no fan of the 15-45 as by the time you are at 35mm its really starting to show its weakness... and i find it too weak at 45, and yet it still performs OK compared to the 16-55. 15-45 looks sharper for the majority of the photo apart from the right side. Dont see much else worthy to mention.
Now you could say its xtrans or a poor copy of the 16-55 etc but the way some talk about the 16-55 it should be blowing this tiny piece of plastic tat 15-45 out of the water.
in any case i prefer the 18-55 which is a compromise between the two, although its not super resolution and has af issues.. but when nails AF, its not bad, not my first pick for landscapes but neither would the 16-55 be....
i still have the 15-45 btw, 15mm with ois is useful..
Also at 35 mm the 15-45 is at about f5.2 wide open.. typically lenses are better across the frame a bit more stopped down.
a_c_skinner Forum Pro • Posts: 13,047
As you (almost) say there is, at these settings, no practical difference in IQ.
People on here always reply that a test is worthless but two images taken at the same time of the same scene in the same light is exactly the test that makes sense to me at least.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
It’s not a good test because the image is largely empty, so you can not compare the edges of the frame, if you just look at the right side you can tell how less sharp it becomes. There are not many colors either, just blue, brown and green. The focus is far in the back, where everything is concentrated in the center. It is taken in bright daylight, where even $100 lenses are nicely sharp in the center. This makes the photo a poor basis for a comparison.
It is though a good test if that is the sort of use to which you put your gear, that is my point. Testing always needs to be for the sort of use to which the gear will be put. Of course if what you shoot isn't scenery in good light there will be other tests that make more sense. I could take this to absurd lengths and say if you always have sky in the top left then that corner isn't relevant to testing but that would be silly! There are lots of people whose output is scenery in good light.
As so often in these discussions the question is are we talking about equipment or photographs?
Of course what it certainly says is the 16-45 is a pretty good lens and for the price excellent.
Andrew Skinner
JayPhizzt Senior Member • Posts: 2,374
X-T2
X-A7
I believe this could at least partly be because of X-trans. The 15-45mm seems like a great performer for the price, though. What you should do however is put the 16-55mm on the X-A7 instead and see how it compares with the 15-45mm when used with a bayer sensor.
sshapiro Senior Member • Posts: 1,018
I got the 15-45mm about six months ago and have been impressed by the quality of the images. It is a nice low-cost 15mm prime for users who don't have something wider than 16mm. I plan to pair my 15-45mm with an X-T100 that is being converted to infrared (590nm) by LifePixel.
My understanding is that the higher-end bodies, such as the X-T2 and X-T3 don't have full firmware compatibility with the lens, so the lens resets the focal length to 15mm when those cameras are turned off. I have used the lens with both an X-T100 and X-T20, and that behavior does not exist.
biza43 Forum Pro • Posts: 15,074
"Landscape" apertures are great equalizers. It has been so for at least 30 years. I remember using the lowly Canon 18-55 kit zoom to getsome great photos at f/8.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
15mm prime is a common suggestion for that lens.  I do wonder if I've been a fool with the lenses I've bought.
Andrew Skinner
I have the 14 and the "15mm prime" I have had good luck with both hence I tend to carry my 15mm prime these days on family trips. The 14mm has 0 distortion and optically better etc but its hard to beat the cheap kit for casual photog
And-roid
And-roid Senior Member • Posts: 3,208
X-T2
X-A7
Hi, I am very interested in this camera, x-a7 and I believe another is the same, x-t200. Can you post any more samples and the original camera jpg if possible of x-a7?
Thank you for this comparison.
X-T2
X-A7
I agree 16-55 on the xa7 and 15 45 on xt2 with same processing same 35 focal length.  I think this will be a useful comparison.
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 9,169
That's true.
Let's go super low quality lens on an old sensor: The 16mm pancake from Sony. Maybe one of the weakest lenses on earth. At f8 all is still somehow nice though. And that's on the 12MP sensor of the NEX5 or was it 14MP. Don't know anymore.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Sony RX100 IV Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R +7 more
Well, I was more just thinking about comparing the lenses on the bayer sensor to get rid of the whole X-trans issue But you can of course compare both on the X-trans sensor as well.
Ok yea. But both lens on both sensors of same scene would be useful but even both on xa7 would be good, but I dont own a bayer fuji yet...
CAcreeks
CAcreeks Forum Pro • Posts: 18,941
Yes, true. Nice shot, Ian!
More importantly, the center is sharper from the X-A7 and XC 15-45 than from the X-T2 and XF 16-55. Is this due to Bayer sensor, or lens? I dunno.
We know the 15-45 is excellent at wide angle, but 36.3mm ain't exactly wide angle. Lenstip tested only at 15, 28, and 45. I have not seen another test of the 15-45.
Does either lens test as de-centered?
CAcreeks
Another nice landscape with 15-45
This is from DPreview's X-T200 sample gallery. I just learned about the basic adjustments module in Darktable and tried to improve upon their ACR to taste. The out-of-camera JPEG is overly washed-out in comparison.
good center sharpness, could use better lens corrections
