18-200 LE or 18-135? for my a6500
Started 5 months ago | Questions
KoolKool Forum Member • Posts: 99
hi everyone
my purpose is looking for a versatile zoom lens, for cool and fun factor anytime, i care less for image quality (but still decently sharp, not too soft, too flawed...)
i also want to ask your experience as well!
thanks!
Sony a6500
TryMat New Member • Posts: 24
Re: 18-200 LE or 18-135? for my a6500
18-135mm for sharpness alone.
Just see DxOmark field map sharpness measurement and you'll notice why (Don't look at scores, you can be misguided by scoring alone).  There is no 18-135mm test but its sharpness is almost similar to 18-105mm
 TryMat's gear list:TryMat's gear list
Fujifilm X-T3 Sony E 18-55mm F3.5-5.6 OSS Sony E 30mm F3.5 Macro Fujifilm XF 35mm F1.4 R Sony E 16-50mm F3.5-5.6 PZ OSS +4 more
davect01
davect01 Veteran Member • Posts: 9,231
Unless you absolutely NEED the extra range,  get the 18-135.   A much better lens.
Former NEX-3, F3, NEX-6 and A6000 owner. Current A6400 owner.
http://davesnex-3photos.blogspot.com/
 davect01's gear list:davect01's gear list
Sony a6400 Sony E 50mm F1.8 OSS Sony E 20mm F2.8 Sony E 18-135mm F3.5-5.6 OSS
Bender79ita
Bender79ita Regular Member • Posts: 321
Re: 18-200 LE or 18-135? for my a6500 [samples]
I'll post you two unedited images at 18 and 135 mm to pixel peep. Only lens corrections were applied. For the zoom range I think this lens is pretty awesome.
 Bender79ita's gear list:Bender79ita's gear list
Sony RX100 III Nikon D810 Nikon D5600 Sony a6400 Tamron SP 24-70mm F2.8 Di VC USD +6 more
Trollmannx Veteran Member • Posts: 6,684
Have the 18-200.
Got the 18-135 for better sharpness in a more compact package. Less range, more fun!
My 18-200 now lie in a drawer somewhere...
rjjr Forum Pro • Posts: 14,768
I own the 18-135 and I used to own the 18-105. When I got my 18-135 I compared it to my 18-105 and the 18-135 was noticeably sharper for stills and the range is much more useful to me.
I let my 18-105 go but if I did video I would have kept it for the constant f4 when zooming and the sharpness was good enough for video.
My policy is to not post images to the 'net.
paul wassermann Senior Member • Posts: 1,663
Agree with others, the 18-135 is my choice by far.  Light weight, sharp, excellent zoom range.  Really only down side is it is really only a good light lens due to small wide open apertures.
 paul wassermann's gear list:paul wassermann's gear list
Sony a7R II Sony a9 Sony a6600 Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM Sony FE 90mm F2.8 macro +6 more
voronspb
voronspb Senior Member • Posts: 1,954
Definitely not the 18-200 LE. Its quality is among the worst in the system, even worse than 16-50PZ, according to some tests. On the other hand, the 18-135 is surprisingly sharp for its dimensions, weight and cost.
Vladimir Gorbunov
 voronspb's gear list:voronspb's gear list
Sony a6500 Sony a7 III Sony FE 55mm F1.8 Tamron 17-28mm F2.8 Di III RXD Tamron 70-180mm F2.8 Di III VXD +8 more
REDunnLev
REDunnLev Contributing Member • Posts: 646
Do you need the extra reach of the 18-200?  If not, the 18-135 is the best choice between the two lenses mentioned.  The 18-200LE is the weakest of all the 18-200 Sony lenses.  I do not have this version but if I needed the reach I would no get the LE version.
 REDunnLev's gear list:REDunnLev's gear list
Sony a6000 Sony a6500 Sony E 16mm F2.8 Pancake Sony E 18-200mm F3.5-6.3 OSS Sony E 30mm F3.5 Macro +7 more
darkmcs Forum Member • Posts: 53
As others have mentioned, get the 18-135!
I've had the 18-200LE last year, and returned it after a few days.  It was an OK lens, but not sharp at all.  The 18-135 is a lot sharper!
 darkmcs's gear list:darkmcs's gear list
Sony a7 III Tamron 17-28mm F2.8 Di III RXD Tamron 28-200mm F2.8-5.6 Apple iPhone 11 Pro
XRAY51 Junior Member • Posts: 45
I am the exception. I have had the 18-200 LE for at least 5 years, before the 18-135 came out.  As can be seen above, most people go for the 18-135. I won't, because I like the 18-200 LE. I use it for travel and as a general purpose lens. I did look at an 18-135, but I prefer the longer reach and versatility of the 18-200 LE. I probably take at least 80% of my images with it. I am happy with it. Here are a few.
Bougainvillea  from the front yard.
Hawk in a wildlife refuge, South Africa
in the area of the three gorges, China.
Very aggressive bull Elephant, South Africa. We were backing up very quickly but he still almost caught us.
Dune number 7, Namibia
Curacao waterfront. Sometimes I like to use the paint effect in the Sony cameras.
Oops. The third one from China was the 16-50PZ. All of the others are with the 18-200LE.
missingendpoint Contributing Member • Posts: 721
Not even a question.  The 18-135.  If you >really< need to get to 200, then the original 18-200.
Photo-maestro New Member • Posts: 13
18-200 is not so good, much softer than 18-135.
But I prefer different zoom, for me the best option is 18-105 G. Little shorter than 18-135, but better build (better materials, this is G series) and constant aperture F4 across all focal lengths. Price and IQ of both (18-135 and 18-105 G) is similar, but IMO 18-105 G is still best option for Sony E / APS-C.
M.
 Photo-maestro's gear list:Photo-maestro's gear list
Sony Alpha NEX-7 Sony a6000
M.
I have both 18=105 and 18-135. For just general, good light use, the 18-135 is my choice as it is smaller, lighter. The 18-105 is a better video lens with constant aperture, internal zooming so length doesn't change (better for gymbal use). However I personally do not like the power zoom feature..zooming electronically just doesn't work well for me.  And if you turn the camera off, it resets to 18mm rather than staying at the last used focal length.
M.
I agree that PZ is not the best feature and sometimes it is annoying. But I like 18-105 G for its build quality, images it produce and the constant F4. And the price is acceptable, not in range of newest F2.8 zoom from Sony.
M.
Euell Veteran Member • Posts: 4,523
Seriously, if you are thinking about the 18-200, wouldn't you be better off with a single-lens zoom camera?  Why are you even looking at the A6xxx or another interchangeable lens series?  If you want convenience buy it.  If you are looking for a high zoom range, there are loads of single-lens cameras out there that will do a nice job for that with both wider and longer zooms.  And, many of them, such as the RX100 series really take nice pictures.  And, so-called superzoom cameras have a range way beyond 18-200.  You should be looking there before you buy an expensive lens like one of the Sony 18-200's, which will probably not provide any better photos than some of the fixed-lens alternatives.
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony a6500 Sony a7R III Canon EF-S 17-55mm f/2.8 IS USM +13 more
Good advice if you never want to try some more exotic lenses like the Sigma 16mm 1.4, Laowa 65mm macro,   I went through two versions of the RX10 but ultimately just enjoy the flexible system approach.  A used first version is around $400 a true bargain.
I take your point, but where interest is limited, why buy into a system, the capabilities of which will remain mostly unused ?  None of the Sony 18-200 lenses are cheap.  While I would be the last person to discourage someone's burgeoning interest in photography, I have the impression that the purposes for what many use their photographs are so limited that they may as well use a smart phone or a cheap point-and-shoot and save a lot of money.
I could be one of those...but...I just enjoy using the equipment, fiddling with the images, printing an occasional one, changing my desktop screen every day, and sending images to my kids and friends.  My most fun, to date, has been taking some equipment with me along on my golf outings and photographing wildlife along the course and my friends labors on the links.
Here are two images from golfing..one with Canon (quite some time ago), and the other with a sony RX10.  I just slide the camera under the "dash" of the golf cart and I'm ready to shoot if something comes along.  I didn't notice the mouse until I imported the image into lightroom.
In this picture below I call it "three birdies"  A pigeon, a hawk and my 4 on the par 5.
