NX 50-150mm S repair still possible?
Started May 24, 2020 | Questions
Capella2 New Member • Posts: 10
Re: NX 50-150mm S repair still possible?
markyboy81 wrote:
Capella2 wrote:
My friend, I have the same focus problem as you and more... When I put my lens in, I don't have image information (everything goes black), but my lens update is still in at 1.01. I can't find the 1.03 update to download anywhere. Can anybody help me ?
Here is the link, you can still access the files via https://matteverglade.com/lenses/nx-firmware/ but you have to use the wayback machine as the links no longer work.
https://drive.google.com/file/d/1XocxGDS1B8JsSzMOdujjJqSFVPj__--u/view?usp=drivesdk
So the problem is the update?
Rudi Senior Member • Posts: 2,047
https://blog.naver.com/lovesumii/222006052054
Rudi.
White Widow wrote:
Hi Barple,
I think I paid around $300 to get my lens fixed. Mine was de-centered and the left side of images was out of focus. I figured that I would get the lens back as new which was still the best deal. But when I got it back I wasn't happy with it and had to send it back once again. Finally, it is as good as new (they claimed to have replaced the entire inside of the lens) and I did not have to pay for the follow up repair.
I imagine that the problems with your lens are easier to fix so it could be considerably cheaper. If you happen to travel to Seoul then by all means you should take the lens with you to get it checked. I hope it works out fine!
Is there still someone who can fix the lens in Seoul?
White Widow Forum Member • Posts: 66
Capella2 wrote:
White Widow wrote:
Hi Barple,
I would contact any regular Samsung service center in Seoul.
 White Widow's gear list:White Widow's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +4 more
