On shoot today canon t7i displayed ! in viewfinder.
Started May 22, 2020 | Discussions
brian Regular Member • Posts: 114
I thought it may be a card error but all pics dowloaded ok without any faults.  Anybody able to help me find out what this means/  Thanks Brian
Canon EOS Rebel T7i / EOS 800D / Kiss X9i
Aoi Usagi Veteran Member • Posts: 3,221
Re: On shoot today canon t7i displayed ! in viewfinder.
Are you using spot metering, monochrome, custom white balance, or high ISO Speed NR?
OP brian Regular Member • Posts: 114
Shooting real estate i normally use iso 100 or more if demanded focus is auto smooth
if video called for sometimes iso can be really high exposure is manual.
Forgot Sometimes I use custom WB
Digirame Forum Pro • Posts: 41,857
If you do a search for Canon's exclamation point in the viewfinder, you will find some people's answers to this. Don't specifically put T7i in your search, so that you don't narrow it down too much. Try reading those articles and see if it would apply to your Canon T7i. The exclamation point is a warning. One person cleared the exclamation point in the menu under WB shift/Bkt and hit clear all.  I'm not saying that will help you, but it's a start.  Other people referred to the manual.  I haven't the time to research all of the options, but I hope you find what I wrote helpful.
AshleyMC Senior Member • Posts: 2,228
5
Read the fabulous manual.
The “exclamation point” icon is a warning that you've set one of four possible things:
1. monochrome mode — you are losing all colors and will not be able to restore them, unless you are shooting Raw
2. manual WB correction — you may not get the color fidelity you are expecting
3. ISO expansion mode — you may have high-ISO noise in your image
4. "spot" metering — youmay not get the metering for your overall image
Thank yo, thank you. All who assisted me in the problem with camera setting. I followed the advice given and camera now has a clear non problem screen
Gordon Whittaker Contributing Member • Posts: 927
Please re-word this. It doesn’t make any sense!
Gordy - Reading, MA - USA
 Gordon Whittaker's gear list:Gordon Whittaker's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 24-105mm f/4L IS USM Apple iPhone XS
Why?  He already got the answers he was looking for.
Agapeman Regular Member • Posts: 108
It seemed clear to me. All Brian said is that he is seeing an exclamation mark in the viewfinder. And the replies to him gave him the fix he needed to make it go away.
 Agapeman's gear list:Agapeman's gear list
Canon PowerShot G12 Canon G3 X Canon EOS 550D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II +1 more
