Back Button Focus
Started May 22, 2020 | Questions
whittle74 Forum Member • Posts: 63
Back Button Focus
Hi All.
Hope you are all keeping safe in these trouble times.
I wondered how many of you use the back button focus option. I currently have the 760D and have been struggling a little with focus on certain things.
The main focus issue i;m having is shooting Railway images, moving locos at around 60-70mph. I'm using a shutter speeds of around 1/640. I was initially using one shot focus mode but recently swapped to AI servo.
I'm not sure if it;s me, most likely or i have an issue with the camera. I'm just not able to get a crisp image.
I read an article on back button focusing and wondered if anyone shot a similar subject using this method?
Thanks Andy.
Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
cdmazoff
cdmazoff Senior Member • Posts: 2,826
Re: Back Button Focus
whittle74 wrote:
Hi All.
Thanks Andy.
Hi Andy... Hmm... Couple things come to mind
1: Are you handheld and panning or are you on a tripod pre-focusing on a certain spot.
If you are handheld, then BBF would work fine and using Servo. You just keep your thumb on the BB tracking your subject making sure it is "acquired" and hen press the shutter when you want (keeping the BB pressed).
If you are on tripod you could still use BBF if you don't move the camera, pre-acquire focus and then take your hand off the BBF... This puts the camera in One Shot.. Then when you train gets into position fire away.
https://www.flickr.com/photos/cdmazoff/
When I'm not playing birds, I'm shooting my accordion....or is it the other way around?
 cdmazoff's gear list:cdmazoff's gear list
Canon EOS 90D Canon Extender EF 1.4x III Canon EF 100-400mm F4.5-5.6L IS II
Ray UK Contributing Member • Posts: 977
Shooting locos at 60-70mph will be a bit tricky for most people, it may be easier if they are coming towards you as opposed to across the field of view. I think you should certainly try a faster shutter speed.
70mph is about 103 feet per second so according to my dodgy calculations during an exposure of 1/640 the loco would have moved almost 2 inches.
if the loco is crossing your field then panning is almost certainly necessary and although you don't mention which lens you are using if it has IS then this might help to avoid any camera shake.
JPAlbert Senior Member • Posts: 1,296
As the poster above this mentioned, you might try using a faster shutter speed.
1,000, or 1,200 or thereabouts...?
david172 New Member • Posts: 7
Shutter speed 400. fstop f7.  ISO 1000.
high speed continuous. AI servo. camera 7D MK11
 david172's gear list:david172's gear list
Canon EOS 7D Mark II Canon EOS Rebel SL2 Canon EF-S 17-55mm f/2.8 IS USM Tokina AT-X Pro 100mm f/2.8 Macro Canon Pixma iP4700 +1 more
