drj3
Re: EM1ii hazy at long focal lengths
ChrisRay wrote:
Thanks for taking the time to do some processing on the images. I agree that they can be made to not look "that bad," but then again I would hope for more than that from this gear. And there's always user error but I'd like to give myself a little more credit!
My issue is that that even in-focus areas have mushy detail. Take the fisherman, for example. I'm not looking to count his nose-hairs, but I would expect a lot more definition in the face.
I would not expect much more resolution on the face, it is in shadow and his face is only 12.6 KP.
On the atelope, focus was missed on the head, but even the body has some areas that look decent and others that are mushy, and it's all on the same plane of focus.
And take this example that I took earlier today of my son. This was well-lit and he was standing still, focus was on the back of his head. While it's possible to improve this in post, there really isn't any part of him I would call sharp. Something just seems off.
The above image is not bad, but I agree as I would expect to see more detail in your son's hair at that distance. It appears to be in focus. I don't have the 100-400, so I don't know if that is typical of the lens at that focal length and distance.
Your other images are at a much greater distance where atmospheric distortion is often more important than the lens used, so I was not particularly surprised at their resolution.
I would be surprised if it was a stabilization issue at your shutter speeds, but you could just put the camera on a tripod or a solid surface and compare handheld to tripod images to see if that was the problem.
But I will be taking some more controlled test shots with the Zuiko lens and various IBIS setting to try and get to the bottom of it.
