"New" EX2f.
Started May 20, 2020 | Discussions
Francis E Senior Member • Posts: 2,129
Re: "New" EX2f.
coldcut wrote:
t seems that the wa conversion lens is not compatible with the exif data output.. Or is there an update? What firmware version is your camera on?
Yes, I noticed and also when used on my EX1. I'm not sure where to find the firmware version. My EX1 crashed while i was installing and Samsung very kindly sent it back to Korea and fixed at no cost even though out of warranty.
 Francis E's gear list:Francis E's gear list
Nikon Coolpix P900 Samsung TL500 Pentax K-x Pentax K-5 Olympus OM-D E-M5 +10 more
coldcut Regular Member • Posts: 125
Re: "New" EX2f.
Hmm, I started up the camera and couldn't find the firmware version either. If I remember correctly, you need to have the Samsung "iLauncher" app installed on a computer and check the firmware while the camera is plugged in.
The exif issue is not a big deal though, just noticed it when checking one of your images.
 coldcut's gear list:coldcut's gear list
Ricoh GR Digital Samsung EX2F Nikon D2H Nikon D200 Sigma SD10
Re: "New" EX2f.
I'm not sure if a firmware update would fix the issue. My EX1 dates from 2011 and has 'conversion lens on' and 'off' in the menu, so it looks as if the lens came out with the camera. As I said, Samsung fixed up the firmware up date, and it still has that fault in the .exif.
Someone else here may know the answer, maybe the OP.
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
Re: "New" EX2f.
Unfortunately, the Samsung "iLauncher" app no longer works. The app tries to open a Samsung URL which no longer exists. I imagine the Samsung URL was 'officially' owned by Samsung's Camera Division which has 'unofficially' announced that Samsung has 'officially' exited the camera market.
"What gets us into trouble is not what we don't know. It's what we know for sure that just ain't so." -Mark Twain
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
Re: "New" EX2f.
Yes, that make sense, or at least explains why it doesn't work. Horrible management of a desktop application though, relying on a now broken URL..
When a product or as in this case a whole product segment reach end of life and support is abandoned, it would be a nice gesture towards the customers to release the software as open source.
At least the parts that didn't migrate into the phone business.
Lawrence Norman
Re: "New" EX2f.
I hear ya brother
Re: "New" EX2f.
A few macro shots from the garden today. Yes, I like flowers and gardening
The EX2F is a good macro tool for quick jpegs. I find that the AF is not as accurate in macro mode as in normal mode. Its a bit hit and miss, sometimes by a small margin, but still noticable. Can be handled with careful setup and MF adjustment, IF you have the time. But it sort of defies the purpose with a compact, automatic camera, if using the time needed to make a proper macro setup, you can use a dslr instead..
Swiss giants
Dahlia
Nigella damascena
Chrysanthemum carinatum
Re: "New" EX2f.
Nice shots. I haven't had my EX2f long enough to spot those issues. I have been very satisfied with cloe ups using my EX1. Different camera, different lens of course.
Re: "New" EX2f.
OP eilivk Senior Member • Posts: 2,580
Re: "New" EX2f.
Swiss giants
Dahlia
Nigella damascena
Great! Especially the first and the last. Have not tried macro that much. Mainly because I found a Canon G12 cheap (with some lens fault I can't see...), no lens cap and really good macro. My first Samsung compact, but I learned to use NX10 quickly. Any special advice with macro focusing?
 eilivk's gear list:eilivk's gear list
Canon PowerShot G10 Ricoh GR Digital Fujifilm FinePix F200EXR Ricoh CX4 Sony RX1 +10 more
Re: "New" EX2f.
I love the Canon G series. Had a G9 for years before it broke. The ex2f is a bit more confusing regarding the buttons and controls. A bit too easy to accidently move the "mode" and "drive" dials, and suddenly the camera behaves in an unexpected manner.
The little function button and menu is great though, quick and easy access to iso and exp. compensation and makes up for the lack of physical buttons.
Re: "New" EX2f.
coldcut wrote:
I've found that using 'Smart Auto' gives the best results with macro focusing.
Re: "New" EX2f.
G10 was the main camera for years. Not used much now. G12 much more useful with the tilting screen. And these G cameras can take a lot of rough use. EX2f more for sunday walks, and meeting ladies... But I will use it more when the light is not so bright.
Re: "New" EX2f.
Francis E wrote:
Thanks! That's good news. I'm not so smart with focusing so.....
Re: "New" EX2f.
So, the Samsung mobile link app for Android gave up when upgrading my tablets android OS 😣. Can't connect for WiFi image transfer. But, I guess that's inevitable, it's not in the Google app Store anymore, I had to download the APK even a few years ago.
Has anyone tried the wifi enabled sd cards? Any compability issues?
markyboy81 Veteran Member • Posts: 4,778
Re: "New" EX2f.
It may still work if you install Samsung accessory service separately.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
