Two weeks with the 50mm f/2 - my impressions
Started May 18, 2020 | Photos
chapada Regular Member • Posts: 275
11
I bought the 50mm f/2 because I wanted a prime lens that makes me work more to get a better shot. With my 16-55mm I often felt lazy and it's heavy, so not ideal for walks. I also read that the 50mm f/2 is quite sharp and produces great colors. It surely does. All around I'm having a lot of fun with it. Can't wait to take it with me to the city and try it out there.
 chapada's gear list:chapada's gear list
Fujifilm X-T3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR
Comment & critique:
baobob
baobob Forum Pro • Posts: 18,248
Re: Two weeks with the 50mm f/2 - my impressions
Lovbely shots that however suffer from artefacts easily vsible in sky and foliage probably due to oversharpening
I also own the lens and you should get absolutely clean images
Could you post your settings and processing workflow to go further..
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
OP chapada Regular Member • Posts: 275
I took them with these settings:
https://fujixweekly.com/2019/07/19/my-fujifilm-x-t30-kodacolor-film-simulation-recipe/
Classic Chrome
Dynamic Range: DR400
Highlight: -1
Shadow: +2
Color: -2
Sharpening: +2
Noise Reduction: -4
Grain: Strong
Color Chrome Effect: Off
White Balance: 6300K, -1 Red & -4 Blue
ISO: Auto up to ISO 6400
Exposure Compensation: +2/3
Except for the first one. I quite liked the effect!
baobob
IMHO the grain setting and the sharpening spoils the files just look to sky and foliage full of worms...
I like the shots but not the way they were processed
I haven’t checked out the .RAF files yet but I really enjoyed the contrast, colors and mood the film recipe created. I get what you say about the grain and sharpening, even though I have to admit I quite like it . Should I just set noise reduction and sharpening to get rid of it?
baobob
I usually ser sharpening to -1 and NR to 0 I think then you will get your effect without artefacts
LarsRost Contributing Member • Posts: 663
We all have different opinions regarding noise reduction and sharpening. The value 0 in NR is not my recommendation as it kills details. Sharpening -1 is fine if you plan to sharpen further in post, but if you stick to SOOC JPEGs I would recommend +1 and sometimes even +2 depending on the scene. Personally I often use +1 for sharpening and -2 or -3 for NR and I don't see any disturbing artifacts or noise. I think the issue with the  photos presented here is +2 sharpening in combination with a strong grain setting. I usually never use grain and when I do I reduce the sharpening quite a bit.
 LarsRost's gear list:LarsRost's gear list
Fujifilm X-H2S Fujifilm XF 56mm F1.2 R Sigma 50-100mm F1.8 DC HSM Art Fujifilm XF 18mm F1.4 R LM WR XF 150-600mm
baobob
I try to shoot 160 ISO as much as possible and 200 with the XH1 (which is easier with the iBIS) to get the max of fine details Agree that for PP NR -1 is better
