Hand-Held High Res: A Practical Guide
Started May 15, 2020 | Discussions
MEDISN
MEDISN Senior Member • Posts: 1,439
115
Now that hand-held high res (HHHR) has made it to a more mainstream body, I thought I would revisit how/when I’m using this and differentiate from using tripod high-res (HR) aka traditional pixel shift. The requirement that the camera be stationary for HR is perhaps a bit restrictive for those that prioritize mobility. Now there’s an alternative on the EM1X and EM1mkIII, but as with any feature there are caveats to its use.
If I’m honest, 20-something MP, or even 10MP, is by and large sufficient for much of my work given the ways media is consumed today. But in the event you want a little more, there are new and convenient possibilities with these particular cameras. I outlined some general guidance with HR in a separate thread and will focus on HHHR here with a few comparisons to highlight differences between them.
Which Do I Use For ___________?
It’s important to understand the different approaches involved with HHHR and HR, despite the naming convention being similar, they are unique in how they achieve their objectives. While HR, like other pixel shift implementations, moves the sensor in a fixed and pre-determined pattern to boost IQ, HHHR takes a traditional brute-stacking approach, relying on subtle and natural movement of your hands between frames to provide added detail to the scene. I only mention this because it is integral to why the results are different and it may guide you into which approach is best suited for a given setting.
When viewed at the same size as HR, it's clear the advantage of traditional pixel shift (far right), but HHHR certainly offers improvement over the single 20MP frame without requiring the camera to be stationary.
In general, HHHR will provide excellent noise reduction and great detail whereas HR will provide great noise reduction and excellent detail.
This, albeit subtle, distinction will likely guide which strategy you employ. As in the first image above, both are better than standard 20MP frames when they can be used. The choice between them for me falls something like this:
  • Resolution is the #1 priority: HR > HHHR
  • Noise is the #1 concern: HHHR > HR
  • Can the photo be taken from a stationary camera position?: HR > HHHR
  • Is it a long exposure?: HR >>>HHHR
  • Am I in a hurry?: HHHR >>>HR
I should mention on that last bit about timing that both modes require a “BUSY” period for the camera to stack images, so if you need photos in rapid succession, you’re in a bit of a bind. I’ve timed HR “busy” time at ~ 6s. HHHR tend to be a little more variable as it can throw out frames that don’t stack well but expect to wait ~ 10s. I suspect this is directly related to the number of 20MP frames being stacked in each scenario (8 for HR, and 16 or so for HHHR).
Scenes With Motion
Yes, you can have motion in your scene, but the type of motion might dictate which method you use (if either). If it’s a long exposure or slow, consistent moving scene, try HR first.
HR on compact tripod. The lower 1/3 of this image was constant motion as the waves struck the support pillars. HR does much better in this type of environment whereas HHHR will lead to strange stacking artifacts (if the process doesn't fail right away).
If it’s a scene where the subject is relatively still, try HHHR first. I’ve found, HHHR is more forgiving with slight movement (an insect on a flower petal, or a leaf twitching in the breeze). Those mostly still scenes tend to favor HHHR whereas HR can result in artifacts along the moving edge.
Shot at 300mm equivalent - the wind was moving the flower gently but was able to stack successfully.
If there’s a lot of movement in the scene, like waves beneath the pier example above, I use HR and let the moving portions blur out as in the case of a long exposure. HHHR does not do well in these scenarios for two reasons: (1) as the shutter speed gets lower, getting 16 or so consecutive images good enough to stack becomes increasingly difficult. The slowest SS I have managed with consistency is 0.5s but that was indoors in a resting state. (2) if a significant portion of the image changes between frames in the stack the camera will error out. Don’t worry – there’s a fix for this scenario, it’s called Live ND 😊
As with HR, artifacts that might appear around unexpected movement can be masked out by overlaying the standard resolution ORI file (rename to ORF) if need be.
Environmental Conditions
In my previous primer on HR , I mentioned I avoid certain environmental conditions: unpredictable, gusting winds, pedestrian/auto bridges, etc. This is one area hand-held high-res is really handy. Ultimately, the steadier you are the better, but this opens up several possibilities that were not available with HR. My advice is to shoot with as fast a shutter speed as you can get away with – ISO 6400 in HHHR looks very much like ISO 400 in standard resolution.
How Do Results Compare?
You’ll notice from the first image above of the audio recorder, the 50MP HHHR files do not render as much detail as the 80MP HR files but both are better than the 20MP files. HHHR files, just like HR, provide for additional latitude in post. In fact, the HHHR files look cleaner in the shadows but you’ll notice there is less detail visible when compared to HR as in this example.
ISO 200, viewed 1:1. Significantly under-exposed intentionally to demonstrate recovery in post. The HHHR shot appears to have less noise on the clock face but also less detail than HR. Both are better than the single 20MP RAW boosted 5EV in post.
If I had to draw similarities, I would say detail in HHHR files typically resembles a 30-40MP FF image (think EOS R, D810). Maybe more toward the 40MP end of that range with a great lens or in a controlled environment. I would love to see Imatest results from HR/HHHR someday, my assessment is purely observational from shooting side-by-side with other cameras.
1:1 views at equivalent AOV/DOF. All handheld at lowest shutter speed I could manage for the FF cameras. The EOS R was shot with the 24-70/2.8 IS @ 35mm f/5.6, ISO 800, 1/6s. The A7R2 was shot with the Sigma Art 35mm @ f/5.6, ISO 800, 1/6s. The Olympus was shot with the 17/1.2 @ f/2.8, ISO 200, 1/6s. The Sony probably should have been at 1/8-1/10th as it still looks a little soft compared to the others.
What Lenses Do I Use?
As with HR, whatever you got! It helps to know the apertures your lens performs best. Often the subject will determine your aperture for you but don’t be afraid to use the lens you have with you. Even a relative mediocre performer like the Olympus 17/1.8 will benefit, the 17/1.2 even moreso.
Original and 1:1 views for Oly 17/1.8 vs 17/1.2 - both handheld
Smaller primes are often easier to balance and stabilize but I have experienced positive results from larger lenses as well. At the extremes of focal length (ultrawide and super-tele) HHHR becomes more challenging, usually requiring higher shutter speeds. Shallow DOF (see yellow flower above) is also challenging as slight shifts in distance can have rather dramatic impact on detailed subjects.
Example at approx 420mm AOV. The 40-150 + 1.4TC isn't the sharpest wide open but worth a try.
What Do I Use HHHR For?
I use it primarily for landscape, architecture, urban scenes, still life, product photography outside the studio, outdoor macro, real estate. If we were to contrast this with how I use HR, you will notice I have eliminated the long exposure scenes like seascapes, light trails as well as tasks like archiving where I am in a well-controlled environment with access to a tripod for HR which provides more detail. If I am shooting long exposure scenes without a tripod then I turn to LiveND but let’s not dive into that here.
Why Do My RAW Shots Look Soft?
The 25/50MP JPG’s produced in camera are excellent but if you want to further play with the RAW, a word of caution; while Adobe Camera RAW will open a high-res ORF file, it’s probably not where I would start. The DPR Studio Scene “simulated RAW’s” are a great example of this. Download the ORF’s and open them in Olympus Workspace – you’ll see the difference. If you’re just after the noise improvement, it likely won’t matter which RAW developer you use on HHHR files but if you want to maximize detail then start with Olympus Workspace.
Same HHHR file converted with Olympus Workspace on the left and ACR on the right.
How Should I Sharpen for Final Output?
HHHR images, just like HR images require more aggressive sharpening than you might expect. Every photograph is different. I have a preset saved as a starting point in Lightroom for both HR and HHHR: Amount: 75, Radius: 2.7, Detail: 3, Masking: 50 and will adjust accordingly from there. I have seen great results from Unsharp Mask in Photoshop and the AI Module from Topaz as well. This part takes some experimenting to find what works for you.
Can’t I Just Upscale the 20MP File?
I’ll leave it to you to decide. Here’s an example of (1) a standard 20MP ORF viewed at 160% to match HHHR size. (2) The 20MP file upscaled using Photoshop’s Preserve Details 2.0. (3) The 20MP file upscaled using Topaz Gigapixel AI. (4) the HHHR ORF converted to TIF in Olympus Workspace. While the Gigapixel image looks pretty good, it does not match the detail in the HHHR file – most evident in the brush strokes on the wooden shelf and the paint texture on the wall above the photo frame.
Can’t I Just Stack 16 images in Photoshop from Any Camera?
Yes, and I’ve done this myself with success. Let’s look at the difference between each approach using the same camera, same lens, same settings, but manually stacking 16 RAW frames in Photoshop (using this guide) vs the out of camera RAW from Olympus HHHR.
1:1 view at ISO 1600. 16 image manual stack in Photoshop on the left, HHHR ORF on the right.
Both are very good at suppressing noise at ISO 1600 and I’m not sure I could tell them apart in real world use. The big difference is how we arrived there. The Olympus in camera HHHR provides a ready to share ORF or JPG in ~10 seconds, no computer, cables, $oftware, or additional time involved.
Final Words
HHHR in a relatively compact camera like the EM1mkIII is exciting for a number of reasons. Mainly it broadens the envelope for what a crop sensor camera can do on the go. What I’ve learned is that like any camera feature, there are circumstances that will benefit and those that are best avoided. Standard 20MP frames will provide more than enough utility for most use but having a 50MP option for some uses is certainly attractive as are the noise benefits. Ultimately, with these features in the hands of more users I hope to see more creative ideas and uses shared here. Feel free to post questions, suggestions and tips below. I do ask that we try and keep commentary constructive and on topic. Thank you. -IM
Jan Chelminski Senior Member • Posts: 2,466
Re: Hand-Held High Res: A Practical Guide
Here, as elsewhere, I find your assessments to be quite consistently, wise and accurate.
An excellent resource for those contemplating what these exposure modes might have to offer for their own photography.
Thank you, a great job, as usual.
Jan
"The camera introduces us to to unconscious optics as does psychoanalysis to unconscious impulses"
"The art of the critic in a nutshell: to coin slogans without betraying ideas. The slogans of an inadequate criticism peddle ideas to fashion."
- Walter Benjamin
"Drawing is a constant correcting of errors, maybe a great deal of creation is exactly that."
- John Berger
"...to photograph is to frame, and to frame is to exclude."
-- Susan Sontag
andrew bentley
andrew bentley Forum Member • Posts: 56
Thanks, really interesting read. I always forget about the noise benefits of HHHR.
 andrew bentley's gear list:andrew bentley's gear list
Canon Extender EF 1.4x III Canon EF 100-400mm F4.5-5.6L IS II Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM
Lichtspiel
Lichtspiel Senior Member • Posts: 2,821
Excellent article with suitable images to prove your points. A pleasure to read, even without owning an HHHR capable camera yet. Thank you for taking the time!
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Sony FE 20mm F1.8G Samyang AF 75mm F1.8 FE Samyang AF 35mm F1.8 FE Tamron 70-300 F4.5-6.3 Di RXD III +2 more
Chris DC Contributing Member • Posts: 523
I thank you for your tutorial on HR and HHHR. I concur and have observed similar findings albeit I have not gone to such outstanding lengths to help inform the rest of us.  Many Thanks!
I have gotten the most benefit out of HHHR for doing macros in dimly lit places at high iso and high F-stop.  I have also used the HR mode on a tripod for some scientific work.
As you said, a very helpful feature to have alongside in camera focus stacking.  Sure, one can do the same with a tripod and multiple shots but it is darn powerful to do it in-camera and on the fly.
CDC
Ruairi
Ruairi Senior Member • Posts: 1,494
Very handy
Thanks for doing that.  Should clear a few things up.  Might rely on HR mode for product shots and save some money on renting MF in the future.
Yet to figure out why my tele moon shots fail in HHHR though.
 Ruairi's gear list:Ruairi's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Olympus E-M1 III Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +14 more
Brandon birder Veteran Member • Posts: 4,894
Thanks for a really well written and illustrated report. Very useful.
Bookmarked
 Brandon birder's gear list:Brandon birder's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-100mm F4.0 +1 more
mwhyte
mwhyte Regular Member • Posts: 218
All I can say is thank you...Probably the most informative “article” on HR and HHHR mode I have ever read...Thank you for taking what must have taken many many hours to write the content and make the images...It is most appreciated...
 mwhyte's gear list:mwhyte's gear list
Olympus E-M1 II Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +2 more
Nikko aus London Senior Member • Posts: 1,219
Hi medisn
With an EM1.3 in transit, please allow me to add my thanks for all your hard work and patient explanation.  This is the best of the internet.
Nikko
 Nikko aus London's gear list:Nikko aus London's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 8mm F1.8 Fisheye Pro Olympus 12-100mm F4.0 +1 more
Bassaidai Contributing Member • Posts: 681
Great article with excellent coverage and examples.
Very well done, thanks for the effort and time you put into it and for posting it here!
Bass
If things appear to good to be true - they're usually neither of both.
 Bassaidai's gear list:Bassaidai's gear list
Panasonic GH5 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +8 more
bluevellet Veteran Member • Posts: 3,593
Bookmarked and saved!
nt
 bluevellet's gear list:bluevellet's gear list
Nikon Z6 Olympus E-M1 III Sigma 35mm F1.4 DG HSM Art Olympus 17mm F1.2 Pro Nikon Z 50mm F1.8 +12 more
ABCMO Regular Member • Posts: 308
Thank you for creating this guide.  It, and its companion HR guide, do just what the title in the subject line states:  provide practical guidance for using the HHHR and HR features.  Especially insightful are the post processing recommendations for the raw files produced.  I’m now going to try opening the raws in Workspace first and saving as TIFFs.  Up to this point, I’ve found the OOC jpegs, with some processing, better than anything I could do with the raws in a DxO/Lightroom combination in post.  So I’m anxious to give the recommended post processing workflow a try.
Thank you again for this stellar service to the m4/3 community.
Al
Quickoo Forum Member • Posts: 82
Great Thread, thanks!
ZodiacPhoto
ZodiacPhoto Veteran Member • Posts: 3,067
Thanks and a question
Huge thanks for the excellent report - great job!
Did you (or somebody else) tried HR and HHHR on waterfalls?
How do they work - any artifacts?
Thanks again!
http://www.zodiacphoto.com
No animals were harmed while making my avatar
 ZodiacPhoto's gear list:ZodiacPhoto's gear list
Sony RX100 VI Olympus OM-D E-M10 Sony a7R II
MEDISN
OP MEDISN Senior Member • Posts: 1,439
Re: Thanks and a question
10
Thanks again!
Appreciate the kind remarks from everyone - I hope my experience has been helpful to others and helps avoid some of the frustrations I worked through.
This question from ZodiacPhoto is a good one and I think would best illustrate the difference in consistent motion scenes like waterfalls, waves, etc.
I don't have a waterfall handy but I do have an espresso machine
Entire frame above from single shot JPG
close ups of standard res, HHHR and HR
On the left is a 2s, single frame exposure using a Breakthrough 6-stop ND filter.  On the far right is a pixel shift (HR) shot at 1/4s shutter speed (no ND filter).  As we know, there are 8 frames taken in rapid succession so the total scene recorded is ~2s in length.  It looks very much like a larger, more detailed version of the image on the far left.  Now look at the image in the middle - HHHR.  This is 1/8s of a 16 frame stack so the total exposure is ~2s just like the others.  But notice the areas I circled in yellow.  This best illustrates why I say to avoid HHHR for constant motion scenes.
ZodiacPhoto
Thanks a lot!
elfroggio
elfroggio Veteran Member • Posts: 3,117
Terrible I was just starting to get over the gas and now you restarted it, that's not fair. The boss, aka she who must be obeyed, will kill me...
Lasse Eisele
Lasse Eisele Senior Member • Posts: 2,017
Thank you
Very useful post. Bookmarked, of course.
I have tested the manual stacking method and it works very well, perhaps even better than HHHR, but the stacking in PS is annoyingly time consuming on my iMac. I guess I will have to get a Mk III sooner or later.
On the other hand, I have found that the files from my E-M1 Mk I and Mk II respond surprisingly well to upsizing with a pass of Topaz Denoise and/or Topaz Sharpen. Upsizing with Gigapixel is likely even better. Do I really need more than that? Probably not, but it feels good to zoom in on a sharp high resolution image.
Regards
Lasse
Thanks again!
Rob Trek did a YouTube video on using HR mode of an OLY m5ii on waterfalls. Worked quite well but there are artefacts.
zwagner New Member • Posts: 12
Eh just do what I did, order the E-M1 III and then create a detailed summary of the reasons why you must have the camera in order to accomplish the type of photography you do.
No, it didn't really work. She pretty much reamed me for it. But... I still have the camera. ;D
