Underwater live streaming camera
Started May 15, 2020 | Questions
jaxwiththecrax New Member • Posts: 1
Hi folks,
I live in a coastal town, and love spearfishing. It is pain in the ass figuring out how clear the water is, and would love to set up a remotely operated underwater live streaming camera. I have been doing some research but know nothing in this field, and am having issues finding adequate equipment for this type of project. The camera would need to be battery/solar power operated, and every piece obviously waterproof. I would attach the set up off one of the jetties (large piling of rocks). Please let me know your suggestions!
-Jackson
kelpdiver Veteran Member • Posts: 5,564
Re: Underwater live streaming camera
jaxwiththecrax wrote:
Hi folks,
-Jackson
It's a tough ask, and I suspect the required answer costs more than its worth. But your best bet may be to look for marine bio departments that have web cams on their web portals. Topside surfcams are also essentially the same problem, just without the camera being placed UW. Or if you have any navy buddies, if they have implemented such (and can give any information). Each of these has the need. But a big lead battery with a panel next to salty wave action? Might have marine regulations against this as hazmat as well. If the panels can provide enough voltage in most cloud conditions, maybe the battery is unnecessary, but you'll likely have more intermittent operation.
Your waters - is the viz consistent top to bottom, or can you have a surface muck and then it clear below? Or more prone to lousy viz because the waves or tides stir up the sediment on the bottom? If you tend to have consistent viz, and you're pretty close to the jetty (< a mile or two), could consider the drone approach. Put some large Xs at fixed depth, fly over, and see how many you see. Sort of borderline on the FAA VFR rules, however.
Instead of a camera, perhaps its enough to have light intensity sensors at different depths?   That would be lower power, lower bandwidth.
Are there any NOAA buoys broadcasting data? If you know the tides, the buoys, and the historical patterns, then you can take wind, swell, and temp info to make forecasts. For Monterey, California divers, I hosted the WAM (Wave activity model) in the early 2000s before it got a more perm home.
https://www.garlic.com/~triblet/swell/wamglance.html - not sure this is still being well maintained, as sadly Chuck passed a few years ago.
https://www.garlic.com/~triblet/swell/Inet1XMP.html - how to read info, specific to this area, but perhaps some value to your's.
NedStudio
NedStudio Forum Member • Posts: 82
Your apparatus would have to have two separate components, linked by a cable. Wireless transmission underwater is, how can I say it politely, difficult ? Assume for now that wireless transmission from underwater cannot work, then build a system with two components:
. an underwater webcam, or a regular webcam in an underwater housing. video and power linked by cable. Possibly use a POE (power over ethernet), and you'll have one cable connection
. an over-the-water system for power (solar, battery) and for transmission via cell tower or wifi.
I haven't stumbled yet on a manufacturer who did this, so you'll have to erect the set yourself. If you're handy, consider a raspberry pi as your core system.
 NedStudio's gear list:NedStudio's gear list
Canon PowerShot S110 Canon EOS D60 Canon EOS 550D Sony Alpha NEX-7 Sony a7R II +7 more
