IBIS test on Sony A6500 and Tamron 70-180/2.8
voronspb
OP voronspb Senior Member • Posts: 1,898
Re: Video with IBIS operation on Sony A6500 and Tamron 70-180
Euell wrote:
will wait until the issues the OP has pointed out are resolved by Tamron. Spacebo, Vladimir !
You're welcome! In the first place we need waiting for June FW update.
Vladimir Gorbunov
 voronspb's gear list:voronspb's gear list
Sony a6500 Sony a7 III Sony FE 55mm F1.8 Tamron 17-28mm F2.8 Di III RXD Tamron 70-180mm F2.8 Di III VXD +8 more
Euell Veteran Member • Posts: 4,353
Would be interested to know if any other lenses exhibit this issue, which is particularly inconvenient in a telephoto zoom.
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony a6000 Sony a6500 Canon EF-S 17-55mm f/2.8 IS USM +14 more
voronspb
And NOW the IBIS works fine at 70 mm!
Firmware V2 resolved the problem with poor IBIS operation at 70 mm:
It took 3 hours to record and prepare this video.
Vladimir Gorbunov
«Often the difference between a good and a bad sample of the same lens is bigger than that between two different lenses» — Bastian K.
Joachim Wulfers
Joachim Wulfers Veteran Member • Posts: 4,104
Re: IBIS test on Sony A6500 and Tamron 70-180/2.8
voronspb wrote:
I also own the 18-135 mm OSS lens, so I can make a similar test tomorrow for comparison between OSS and IBIS. Spoiler: I wasn't really happy with OSS on 18-135, as sometimes it makes soft photos at 1/125 s.
I own the A6600 an I have tried to photograph with OSS on and IBIS off or vise-versa. I have not found any setting in the A6600 to do that. I believe that when you shot off the IBIS in camera, the OSS on the 18-135 is also shot off. This believe is based on the fact that when I use the 70-300 G and I want to shot off image stabilization in the menu I receive a message that it has to be shut off on the lens.
Maybe you can tell me how you compare between OSS and IBIS
 Joachim Wulfers's gear list:Joachim Wulfers's gear list
Fujifilm X100T Sony a6000 Sony a6600 Sony E 18-200mm F3.5-6.3 OSS Voigtlander 21mm F4 Color Skopar Pancake II +12 more
voronspb
On native lens it's impossible to compare directly, OSS is always supported by IBIS. I meant that I could compare the OSS-equipped lens vs. IBIS only.
On Metabones adapter you can choose between IBIS and IS, and it's impossible to run both of them simultaneously.
Vladimir Gorbunov
Sympa Senior Member • Posts: 2,379
I think the following can be done:
180mm OSS lens on A6000 (OSS only)
180mm unstabilized lens on A6500 (IBIS only)
180mm OSS lens on A6500 (OSS + IBIS)
I would be curious about this. It could even be done with 55-210 and the Tamron.
 Sympa's gear list:Sympa's gear list
Sony RX100 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS Canon EF-S 10-18mm F4.5–5.6 IS STM +2 more
voronspb
While V2 firmware fixed the problem with IBIS operation at 70 mm, still the problems with in-lens sound and periodical glitching on A6500 persist. Therefore I was urged to ship my lens to the service, it was done today.
Vladimir Gorbunov
How to tell (US) pioneers: they're the ones with the arrows in front.
voronspb
That well worth it.
Vladimir Gorbunov
Nice pics.  I'm waiting for the bugs of which you informed us, to get ironed out.
BrentSchumer
BrentSchumer Senior Member • Posts: 2,426
There is a Youtuber called Arthur R that found his A6500 was less stable with OSS + IBIS than with either option utilized alone.
Overall, these results don't surprise me.  The A6500/A6600 IBIS is widely reputed to be weaker than the FF cameras and other manufacturers (e.g. Panasonic, Fuji).  Another reason why I'm waiting on the A6700!
 BrentSchumer's gear list:BrentSchumer's gear list
Sony RX100 VI Sony a6400 Sony E 50mm F1.8 OSS Sony E 10-18mm F4 OSS Sony E 35mm F1.8 OSS +2 more
Not precisely accurate. He had two inconsistent results. With a telephoto mounted, he found that IBIS plus OSS was a bit better than OSS alone.  In low  light with another lens, he did find the OSS alone to be very slightly better than when combined with IBIS. https://www.youtube.com/watch?v=5opiwmCaXEM
While I do like his videos, it is very tough to test image stabilizers, as unless you have special equipment, it requires hand holding, which can be quite inconsistent.
