Telephoto lens for casual city / travel photography (50-140mm or 90mm)
Started May 14, 2020 | Discussions
PeterPanSyndrome New Member • Posts: 3
Hi,
I'm new to the forum My question is in bold below, the rest is just a bit of context.
When I'm out taking photos, I prefer walking around with just my X-H1 with the 16mm f/1.4. It's heavier than my old x-pro1 with my 23mm f/2, but much more comfortable to carry in my hand.
I always carry a backpack when taking photos. Not because I carry a lot of gear, but because I am fairly clumsy and want to put the camera/lens safely away when I have to take a crowded stairs or when I have to climb up a hill, etc.
I keep my 3 other lenses (23, 35 and 50 f/2) in my backpack, but rarely switch to them. I will still reach for the 50mm from time to time, but in all reality, it will typically not really allow me to zoom in sufficiently enough for what I want. So I tend to just accept the fact that I can't take all shots I want and stick to the 16mm focal length all day long. Pretty much similar to my x-pro1 days when all I had (and loved) was the 23mm f/2
I still think I eventually want to go for a longer lens as well though, just to be able to take those pictures I can't right now. Thinking I can simply leave my 23, 35 and 50mm lenses at home since I hardly ever take them out anyway, and just pack 1 useful telephoto in the backpack instead.
Would adding a 50-140mm f/2.8 as a second lens to my 16mm be a good choice or would you advise the 90mm f/2? My instinct says: 50-140mm. I learned to appreciate the extra stop the 16mm f/1.4 gives me over my old favorite 23mm f/2, but I assume it is less relevant for the telephoto?
I don't know much about photography yet, but I do know I want (1) weather-resistant lenses & (2) appreciate great low-light performance for my everyday lens. Knowing this, would you recommend the 50-140mm or the 90mm?
Peter
 PeterPanSyndrome's gear list:PeterPanSyndrome's gear list
Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR
Fujifilm XF 50-140mm F2.8 Fujifilm X-H1 XF 90mm
Homo erectus
Homo erectus Senior Member • Posts: 1,047
Re: Telephoto lens for casual city / travel photography (50-140mm or 90mm)
5
Look at the size and weight differences. 2.2 lbs for the 50-140 vs 1.2 lbs for the 90. The 50-140 is 6.93 inches long while the 90 is 4.13 inches long (specs from B&H website).
I've carried the X-Pro 2 and 90mm with me nearly everywhere I've gone for the last few years. I don't even think about it, the camera and lens just live in the bag that I take everywhere. I don't think I'd carry the 50-140 unless I knew I specifically needed that lens for what I expected to shoot.
That's just my opinion though. I own the 90 and have rented and used the 50-140 for a week, once. Other people will have different opinions. To make the decision that's best for you, you should rent, or borrow, the lenses and form your own opinion based on your own experience.
Hope that helps.
Il Mostro Regular Member • Posts: 344
The XF 50-140 2.8 is a terrific lens but it doesn't exactly scream "casual city/travel" even when mounted on an X H-1. For the most part, I am using the XF 16-55 2.8 on my X-H1. This is a match made in heaven for me.
However, when going "casual" and lightening the load I am looking for maximum flexibility with ultimate IQ being the trade off. For me, the XF 18-135 is the current solution. I think the XF -16-80 f4 is an even better option (since I don't use the long end all that much) but I already have a sharp copy of the 18-135 that I purchased at a very good price. When used 16-80 prices drop, I will likely add that lens.
If you really do need the reach, nothing wrong with an 18-55/55-200 pairing as a relatively light, compact and very flexible combination.
 Il Mostro's gear list:Il Mostro's gear list
Fujifilm X-H1 Fujifilm 16-55mm F2.8R LM WR Canon EOS 5D Fujifilm X-E1 Canon EOS 6D +39 more
Shinyschnapper
Shinyschnapper Regular Member • Posts: 224
I often carry my XH1 with the 16mm f1.4 on and the 55-200 for longer shots in the bag.  Whilst I really do want the 50-140 I think it is too big and heavy for non photography specific trips (at least thats what I keep telling myself), but then I have my eye on the 80mm macro as well so don't listen to me.
Fujifilm X-H1 & X100V
Fujifilm XF 16-55, Fujifilm XF 55-200, Fujifilm XF 16 f1.4, Fujifilm XF 56 f1.2, Rokinon 12, Hellios 44m-4, Industar 50-2, Pentacon 50 1.8,
 Shinyschnapper's gear list:Shinyschnapper's gear list
Nikon Z5 Nikon Z 50mm F1.8 Nikon Z 24-200mm F4-6.3 VR Nikon Z MC 105mm F2.8 VR S Nikon Nikkor Z 28mm F2.8 (SE) +1 more
Morris0
Morris0 Forum Pro • Posts: 32,175
Hope that helps.
Aperture can be very important with a longer lens.  They need faster shutter speeds to avoid blurring and also a faster aperture lens may produce nicer bokeh.   The 50-140 wins on versatility yet the 90mm f2 has magical bokeh and the 50-140 produces good bokeh.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
holashobby Senior Member • Posts: 1,663
Personally, I'll go for the 50-140 f2.8 over the  90 f2 for travel/city photography even though its heavier. It's a far more versatile lens allowing for a wider variety of shots.
 holashobby's gear list:holashobby's gear list
Fujifilm X-T4 Panasonic Lumix DC-S5 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm 15-45mm F3.5-5.6 OIS PZ +4 more
Homo erectus
Hope that helps.
Morris
I agree.
Also, OIS creates possibilities. The 50-140 has it. The 90 doesn't. I've never really missed it when using the 90 but it is certainly a useful feature. Especially as focal lengths get longer.
chapada Regular Member • Posts: 275
For casual city and travel photography I recommend you buy the 50-230 or 55-200. The 50-140 is really heavy.
 chapada's gear list:chapada's gear list
Fujifilm X-T3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR
dccberry Senior Member • Posts: 1,239
I sold the 90 and bought the 50-14. Never looked back. The lens is great optically, and not as heavy as some people would make it out to be.  The main advantage of the 90 is the "stealth" factor if you want to remain inconspicuous.
 dccberry's gear list:dccberry's gear list
Ricoh GR Nikon D810 Nikon D850 Fujifilm X-T3 Fujifilm X-T4 +10 more
georgehudetz Veteran Member • Posts: 6,299
I'm in the same boat, BUT when I sold my 90, I was shooting with an X-T2, which, of course, does not have IBIS.  The OP is shooting with an X-H1 so that's not an issue here.
I do recall doing some city shooting with the 90 and it was fantastic.  But I love my 50-140.
To the OP, it sounds like you enjoy shooting with primes over zooms, in which case I'd suggest getting the 90.
But if that really isn't a driving force, and you don't mind the size/weight of the 50-140, then I agree with others - it's a much more versatile lens, and the compression you get at 140mm is really nice to have - opens up interesting compositional opportunities.
 georgehudetz's gear list:georgehudetz's gear list
Panasonic Lumix DC-S1R Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Sigma 14-24mm F2.8 DG DN Panasonic Lumix S Pro 16-35mm F4 +4 more
mike lix Senior Member • Posts: 1,453
There´s a clear winner. :-) With samples
14
PeterPanSyndrome wrote:
Hi,
Peter
I´ve got both the XF 16 (that you have) and the XF 90. And while I would call the highly praised XF 16 as versatile, for me the XF 90 is the one of the main reasons, maybe even the main reason itself, to shoot Fuji. To me there´s no better lens in Fuji lineup if overall image quality and look of the photos is your thing. Being weather sealed and fast focusing are great additions. It´s a pure joy to use this lens. Here are some of my samples (I know they are mostly animal oriented, but you get the point about the rendering ) :
mike
www.instagram.com/michal.placek.fotograf
www.facebook.com/michal.placek.fotograf
500px.com/mikepl500px
 mike lix's gear list:mike lix's gear list
Fujifilm X-T2 Fujifilm X-T3 Fujifilm 16-55mm F2.8R LM WR XF 90mm Fujifilm XF 100-400mm F4.5-5.6 OIS WR +2 more
a_c_skinner Forum Pro • Posts: 13,047
Yes, the 55-200.  You don't need WR, it is largely superfluous provided you've got a bag and casual and travel means not having a camera on show, at least for me.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
Re: There´s a clear winner. :-) With samples
I've always enjoyed a 70-200 equivalent lens, and Fuji's offering is out-standing - but you sure make an argument for the 90/2. And here I thought I was all set, no GAS or nutin'. . .
[g]
...Bob, Bovina NY
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
[g]
LOL I was thinking the same thing.  Amazing photographs.
OP PeterPanSyndrome New Member • Posts: 3
So many delightful photos at https://500px.com/mikepl500px
You sold the idea of a 90mm f/2 to me .. picking it up on Saturday !
Thank you.
Mupepe Forum Member • Posts: 84
My vote is for the 55-200. Not big and versatile. My copy works flawlessly, has reasonably fast AF and very good IQ.
 Mupepe's gear list:Mupepe's gear list
Sony a7R II Fujifilm X-E3 GoPro Hero5 Black Nikon AF Nikkor 50mm f/1.8D Samyang 14mm F2.8 ED AS IF UMC +9 more
pdxa4 Regular Member • Posts: 193
I recently purchased a 90mm f2, while I'm getting used to it - the photos I've already captured are really wonderful. It's not really that large.
I'm not sure if I would define it for street photography, but as a portrait lens it is special.
Fujifilm X-T3
Nikon D7500
Nikon AF-S DX NIKKOR 10-24mm
Nikon D90
18-105mm AF-S VR DX Nikkor
35mm f/1.8G AF-S DX Nikkor
Fujifilm S7000 TCON-17
Manfrotto 190DB
Manfrotto 141RC
 pdxa4's gear list:pdxa4's gear list
Fujifilm X100V Nikon D7500 Fujifilm X-T3 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G +9 more
Lens_Goat
Lens_Goat Contributing Member • Posts: 811
I auditioned the 50-140 last year and absolutely loved it. It's still on my list but I just picked up the 90 f/2 -- got it used, I think I paid $597. It's a fantastic lens. Can't go wrong with either. One thing which deterred me from getting the 50-140, outside of price, is its size. I imagined I would be less inclined to take it out. The 90 f/2 isn't exactly "light" and with the lens hood on it's rather long but it definitely possesses a magnitude of portability over the 50-140. It's fun to compose within the constraints of a single long focal length. A welcome challenge. However, 50-140 may be more practical for event work.
 Lens_Goat's gear list:Lens_Goat's gear list
Fujifilm X-T3 Fujifilm GFX 50S II Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +2 more
David Lal Forum Pro • Posts: 13,570
Jsi dobrý! [You are good!]
Michael, these are persuasive images and my favourite is your #4 of the dog giving her paw but the attractive girl with the dogs, #5 is a close second.
For me, a fixed 90mm lens for city photography is not flexible enough so I usually use a 16-85 on a Nikon DX camera if I don't mind being noticed but I'm here in a Fuji  forum because for stealth when I want to be unnoticed I use a Fuji X100F (fixed 23mm lens).
By the way, you have a great country which I have visited many times, especially Brno.
georgehudetz wrote:
[g]
Haha, thank you guys!
