Thunderbird Flyover - Learning to edit
Started May 14, 2020 | Discussions
CAcreeks
CAcreeks Forum Pro • Posts: 18,940
Re: Thunderbird Flyover - Learning to edit
Orbit220 wrote:
James H MacAllister wrote:
Try adjusting the curves in Capture One. Here's a quick (limited, due to jpg) curves adjustment done in Paint Shop Pro (too cheap for PS).
https://drive.google.com/file/d/1n8J2t73itcYmbUp3FIVPoxFGZFfFRNOR/view?usp=sharing
Here is my attempt at sharing the raw of what seems to be the most popular and exciting shot. Let me know if this does not work. I appreciate everyone's feedback. How would one go about adjusting the curves in Capture One? If it is a complex topic I would be happy to search the web, but if I can gather good advice here I would appreciate it
Thanks, that was fun!
Darktable's lens profile helped to reduce vignetting. Filmic module gave more separation to the contrails than base curve. I went for the underexposed -.33 EV look with higher contrast. I'm not sure you like it, but I do.
freyabo
freyabo Regular Member • Posts: 148
jshen808 wrote:
Orbit220 wrote:
Thank you all for your kind words and suggestions. As far as editing the images, any thoughts as to how you would make the subject "pop" a little more? I am particularly thinking of the first image where the jets have been zoomed in on the most. I have Capture One as my primary editing software, if that helps
There are many post processing softwares available.
And there are some freewares that's available as well.
Can hangout at the "Retouching" forum to learn more.
https://www.dpreview.com/forums/1006
Below is an edit to your picture on my ipad pro.
1. Original
Original
2. Processed (to taste)
And below is a screen capture of my ipad pro,
the editings is done by using up & down sliders.
Screen capture of my ipad pro
Cheers!
What software is that?
"In a time of universal deceit, telling the truth is a revolutionary act."
George Orwell
I am a camera
Erik Baumgartner Senior Member • Posts: 6,893
I went for the crop the hell out of it approach.
The wide view:
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP Orbit220 Junior Member • Posts: 35
Here I just upped the light falloff (under the Lens tab by default) to 120. And again adjusted the curves. The curves tool is a straight diagonal line, the top of which are the highlights and the bottom the shadows. By selecting any point along the line and moving it up will bring it toward the highlights (brighter). And moving it down will bring it toward the shadows. For instance, if you select the middle of the line and drag it down you will darken the mid tones. Pulling down the top of the line will darken the highlights; and vice versa. You can adjust the color channels in the same manner to adjust color tone. Just play with it, you can always reset it if you don't like the results.
Great explanation, thank you for taking the time to do that. A few follow up questions. What does light fall off do? I am playing with it myself and can't seem to notice a difference. Furthermore, is using the curves tool similar to using the "high dynamic range" tools? For instance, would increasing the highlight slider have the same effect as moving the right side of the line and moving it up? Or does moving the highlight slider to the right increase the "highlights" of the shadows, midtones, and highlights globally?
 Orbit220's gear list:Orbit220's gear list
Fujifilm X-H1 Sony a7 IV Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR +6 more
James H MacAllister
James H MacAllister Regular Member • Posts: 150
To put it short the light falloff adjustment correct for vignetting which is the darkening of the corners and edges of an image which occurs to some degree with all lenses. Higher end lenses typically have less vignetting. While adjusting the slider, pay close attention the the corners. You may not notice the corners and edges being darker than the center until you make the adjustment. Often after the adjustment it becomes obvious and you won't believe you didn't notice it to begin with.
 James H MacAllister's gear list:James H MacAllister's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
liggy
liggy Contributing Member • Posts: 839
Quickie edit jpeg via Snapseed :)
30 seconds . Not subtle but a bit more lively.
Snapseed is free and I love it.  Seriously took about 30 seconds.  Crop.  Bump Structure. Lift Shadows. Cut Highlights. Up Ambience.  Done. :).
 liggy's gear list:liggy's gear list
Leica Q2 Sony a9 II Fujifilm GFX 100S Sony a1 Fujifilm X-T5 +26 more
CAcreeks
Re: Quickie edit jpeg via Snapseed :)
liggy wrote:
30 seconds . Not subtle but a bit more lively. Snapseed is free and I love it. Seriously took about 30 seconds. Crop. Bump Structure. Lift Shadows. Cut Highlights. Up Ambience.
Nice work! Do you run Snapseed on an Android tablet or iPad?
Some of the other software used here transformed the clouds into fake-o camera style pseudo clouds - blown out, too white - instead of the way clouds really look.
liggy
Thanks!  2017 iPad Pro.  Older but still more than capable.  I have Affinity Photo but the Fuji jpegs are so good that Snapseed does pretty much everything other than focus stacking and pano stitching.
I don’t know about where you live, but in my neck of the woods, puffy white clouds in direct sunshine are intensely bright and intensely white, the very brightness parts of which should absolutely be rendered as nearly pure white,  just like in real life. Dark, bluish, mid-toney and HDR-like is decidedly not the way bright, sunlit clouds really look like in my reality.
liggy
lol... where I love the clouds look like this most of the time.
CAcreeks
This is a really good one, with the railing cropped out. I like how planes are flying toward the camera. You got a good copy of this lens.
Picked it up second hand for $140, if you can believe it. I was trying to use the railing to show just how close they were. Amazingly flew right over my head, set off car alarms. I really wish I had zoomed in more on this shot but was nervously preparing for them to shoot right over me
