Help with Lumix G7
Started May 10, 2020 | Discussions
Lancruza New Member • Posts: 2
Help with Lumix G7
I'm trying to get video output on the HDMI jack of my G7.  From what I've read, it won't have any output if I'm recording, but I'm wanting to use it a s a webcam and I can't get anything to output over the HDMI even when not in record.  Should it have output when I first turn it on or are there settings to turn on the HDMI jack.  I've tried it on several TV's and monitors...nothing.
Panasonic Lumix DMC-G7
pannumon Veteran Member • Posts: 4,130
Re: Help with Lumix G7
It should work for viewing on TV or monitor, but if you want to record it to a computer or use as a web cam, you need a capture card, and the last time I checked, they were out-of-stock everywhere. Does it help if you switch to playback mode?
There are some relevant settings on the camera, but at least older display devices do not automatically change the input to the one you like (HDMI), you may need to do that manually.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
OP Lancruza New Member • Posts: 2
I've got a Blackmagic mini recorder that works great, but it will not see the G7.  If I plug the G7 into any TV / monitor I have, It is not sending video to it.  Yes...I have selected the proper input an the TV / monitors.  I'm getting nothing.  I have another camera that is working with all these devices.  That's why I'm trying to determine if there is a setting somewhere.  This is an almost new G7.  It has been used very little and the HDMI port has seen little to no use.  It's got me stumped.
Stejo
Stejo Senior Member • Posts: 1,461
There's nothing special to it. It just works.
If it doesn't for you check a different cable. If it still doesn't, contact panasonic service I suppose.
 Stejo's gear list:Stejo's gear list
Panasonic Lumix DMC-G7 Panasonic GH5 Samyang 85mm F1.4 Aspherical IF Samyang 7.5mm F3.5 Fisheye Sigma 18-35mm F1.8 DC HSM Art +7 more
