XT4 - Focus point gets stuck
Started May 6, 2020 | Discussions
Jordag New Member • Posts: 1
Hi
I use my XT4 for more than two weeks now and a recurring problem is that the focus point gets stuck on the screen and it cannot be moved or reset to the middle of the frame. The camera needs to be turned off and on to resolve the issue.
Is anyone else having such a problem?
Jordag
JayPhoto1 Regular Member • Posts: 206
Re: XT4 - Focus point gets stuck
Scheduled to get my X-T4 on Monday so I will (**SIGH**) add this to the list of bugs to check.  Keep us informed and let us know if you learn anything else about this issue.  Thanks.
 JayPhoto1's gear list:JayPhoto1's gear list
Canon EOS M6 II Sony a7S III Sony a1 Canon EF-M 22mm f/2 STM Sony FE 24-105mm F4 +4 more
Morris0
Morris0 Forum Pro • Posts: 32,181
Jordag wrote:
Hi
Jordag
That's frustrating.  I suggest you contact Fuji Support.  They need to hear about things like this and if there are a cluster of reports with the same symptoms then they will get to work solving the issue.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Tim Stiv
Tim Stiv New Member • Posts: 21
Yeah I have the same issue. I’m new to Fuji and thought I was doing something wrong haha.
firmware update soon surely.
 Tim Stiv's gear list:Tim Stiv's gear list
Canon EOS R5 Sigma 50mm F1.4 DG HSM | A Canon RF 24-70mm F2.8L IS USM Canon RF 50mm F1.8 STM
Morris0
Morris
MHF in VA Forum Member • Posts: 64
In my case, the single-point focus indicator isn't stuck, but following each shutter actuation, the point reverts to the upper left-hand corner of the screen.  I'll also await the fix.
 MHF in VA's gear list:MHF in VA's gear list
Fujifilm X-T2 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +4 more
Greg7579
Greg7579 Forum Pro • Posts: 14,044
This happened to me with my GFX 100 and it was a faulty EVF.
You may have to send it in. But try resetting the camera to factory defaults first.  Then play with different focus box sizes. Then manual focus the camera with focus peaking. Switch back to AF and switch between all the focusing options.
Switch between single point and the zones and see what happens. Play with the camera a lot.  Shoot a hundred shots and move that focus point randomly.  Try it in bright light vs low light and see if that changes anything. If it does that is an EVF problem probably.  Shoot single and machine gun fire.
Try it on LCD only without the EVF off.  Try all the EVF settings.
Does the eye detect work perfectly? Move you eye back and forth on the eye cup and see it detects cleanly. Try all the the EVF settings and see if they work cleanly, especially eye detect.
If the focus point still freezes in all of those situations you have a serious fault and New Jersey will fix it.
 Greg7579's gear list:Greg7579's gear list
Leica Q2 Fujifilm GFX 50R Fujifilm GFX 100 Fujifilm GF 32-64mm F4 Fujifilm 120mm F4 Macro +8 more
Greg7579
Tim, try what I said and see it has any effect.  If it does not, then this is a serious problem and you can bet Fuji sees this.
moodlet New Member • Posts: 1
I’m not sure if this is the same reason for why yours is stuck, but I just had this issue and found this thread so I thought I would post how I solved it in case it’s helpful to anyone else.
I just had this issue randomly yesterday and tried all the things mentioned in this thread. I’m not sure if this is exactly what you’re experiencing, but for me, the little button/dial on the back wouldn’t let me change the focus point and it was stuck in the middle of the frame. Though if I went into the settings menu, I was able to change it under AF/MF > Focus Area (obviously very inconvenient when you’re trying to take photos).
I just fixed it by going to Menu > Set up > Button/Dial setting > Focus lever setting > On. Somehow it had turned itself off... but it works now. Hope that helps!
Phosphene New Member • Posts: 2
Thank you so much for this.  Somehow that happened to me too.  Appreciate it!
baobob
baobob Forum Pro • Posts: 18,248
yes sometimes with the XT3
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
Shane11547 New Member • Posts: 1
I have reading all your comments and i think i know what is causing this (focus point getting stuck and cant be moved with joystick) which isn't mentioned and it fixed it for me..
The issue could be that you have the touch sceen set to on & on top of that you ciould have the shoot or af on at the top right of the touch screen and if the case .. you are accidently going to touch the screen at some point shooting and this will lock the focus point.. Just make sure the setting is marked off and presto fixed it for me
Or else just turn off touch screen all together..
Night Pixel
Night Pixel Contributing Member • Posts: 976
Jordag wrote:
Hi
Jordag
Check:
Note: If you have it set to PUSH to Unlock it will lock after every shot.
**** REDACTED ****
 Night Pixel's gear list:Night Pixel's gear list
Sony RX10 IV Fujifilm X100V Fujifilm X-H2 Fujifilm XF 80mm F2.8 Macro Tamron 150-500mm F5-6.7 Di III VC VXD +4 more
sayling Junior Member • Posts: 25
Also don't forget if you have Touch Screen Mode (AF/MF setting 3/3) set to AF, once you touch the screen the XT4 focuses and locks focus and the AF touch indicator shows a green square with AF inside. At this point the focus lever is locked and you can't move the AF point. The only way out is to touch the green square again (or switch off). I think I saw this in a Pal2Tech YouTube video.
I hardly ever use this feature and have my Touch Screen Mode set to Area
Sayling
 sayling's gear list:sayling's gear list
Panasonic Lumix DC-GX9 Fujifilm X-T4 Fujifilm X-E4
